empiracer Samba Member
Joined: December 17, 2002 Posts: 1110 Location: Issaquah / Seattle, Wa.
Posted: Sun Apr 02, 2023 5:56 pm Post subject: Pre 55 Fuel reserve extension handle ? |
post ‘55 reserve switch rotates 90° between the on & reserve
1955 and earlier Beetles the reserve switch rotates 180° between on & reserve is there a such thing as a proper reserve extension handle for a ‘55 down beetle? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1322 Location: Central Washington
Posted: Mon Apr 03, 2023 9:52 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
If there was one what what would be physically different?
I have an O.G. extension on my 54', and fairly sure the little label trim thing I have is from a 356. But the extension works the same. The only *different* version of the extension I've ever seen is that one with the U-joint type thing built in. That would help with the 180* swivel, but I sort of don't think that it's original?
Not sure...looks old enough?
https://www.thesamba.com/vw/classifieds/detail.php?id=2559063
| hitest wrote: |
| Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Mon Apr 03, 2023 10:09 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
I don’t expect there would be any physical difference to the lever , only the tag would be labeled to show the 3 positions spread over a 1/2 format instead of 1/4
That ring is def 356 and is the correct orientation to the 55 and earlier Beetle, but reversed ?
The blank tag option seen in your link i suppose is a good option but not so helpful in remembering which position is which
Posted: Mon Apr 03, 2023 10:37 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
early
late
Bub Samba Member
Posted: Mon Apr 03, 2023 10:41 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
Your lever is pointing DOWN! Refer to manual for correct position and specification SIR!
I think the usual thing for knowing which position is which is just to hope you flipped it back to AUF last time, then kick it 180* and hope you get lucky.
OR* You install a low fuel light that is turned on by the reserve switch when you put in on reserve...for us cheap-o's who don't have the fancy Motometer gauge with the light or the bell.
Oh yeah! U got my Fenders? Can you email those to me? I'm basically done with everything, that's the last thing I've been waiting on for show season APPLE BLOSSOM SOMBRERO TIME!! _________________
| hitest wrote: |
Posted: Mon Apr 03, 2023 11:45 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
Here's an early one , kinda odd
Dan22 Samba Member
Joined: August 30, 2019 Posts: 686 Location: Battle Ground, WA
Posted: Mon Apr 03, 2023 3:19 pm Post subject: Re: Pre 55 Fuel reserve extension handle ? |
It is a great idea having a visual indicator of being on reserve. My mom used to tie a bright red cloth over the steering wheel spoke to indicate reserve.
My memories of driving the car is you gotta be quick to flip that lever with your foot without losing too much speed. The lever being up at the dash and visible makes a lot of sense and maybe quicker to flip.
Oh, the personality of these cars......!  _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4790 Location: St Charles, MO
Posted: Mon Apr 10, 2023 2:04 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
Yeah, "quickness" is helpful with the reserve tank handle. I have the stock original fuel tap on my June of 1955 produced Deluxe Sunroof Beetle, no accessory extension lever. Since buying it back in 1993 I have only run out of fuel while the tap lever was in the main tank position while driving along at speed a couple of times. As the engine started to starve for fuel and make the low fuel level issue obvious to me, I quickly took my right foot off the accelerator and used my foot to swing the metal tap lever on the forward wall to the reserve position and the engine quickly received fuel and resumed full operational power and speed. The system and design worked fine! Just hit the next gas station for fuel and definitely remember to return that tap lever to the main tank position again.
I don't think I'd trust the strength of the accessory tap extension levers over simply using my foot, and I have two accessory tap levers in my collection. I just never felt the need to install 'em.
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Bub Samba Member
Posted: Wed Apr 12, 2023 7:44 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
I had to add a warning light, turns on on any position that isn't AUF.
| hitest wrote: |
Costa66 Samba Member
Joined: July 20, 2019 Posts: 107 Location: Fresno, CA
Posted: Fri Apr 14, 2023 8:25 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
| Bub wrote: |
That is CLEAN! I love it.
Josh |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 394 Location: Minnesota
VWNate Samba Member
Joined: October 04, 2016 Posts: 443 Location: Sunny So. Cal.
Posted: Fri Jul 07, 2023 1:06 pm Post subject: Fuel reserve extension handle ? |
7.7.2023
Who sells these or the Chinese repops ? .
I need one for my daily driver '59 Bug .
Also a mileage counter for the dash board, someone's GOT to have these affordably .
TIA, _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
kaieric  Samba Member
Joined: August 15, 2022 Posts: 137 Location: saarbruecken/germany
VWNate Samba Member
Posted: Fri Jul 26, 2024 7:25 pm Post subject: Mileage / KM Counter |
THANK YOU ! .
As it turned out I bought one of the black ones and added a small rare earth magnet to it, the wheels were not very well held from turning, sometimes they'd change as I was driving so I took it apart and Lo ! the thing holding the wheels from turning was simply stiff paper so I cut a rectangle of thin plastic and now it works perfectly like it should .
I'm off to peruse that website's pages of cool Farkels . _________________ -Nate
splitpartsunlimited Samba Member
Joined: January 18, 2006 Posts: 1323 Location: Good Ol`Buenos Aires, Argentina
Posted: Thu Nov 28, 2024 5:56 pm Post subject: Re: Pre 55 Fuel reserve extension handle ? |
| empiracer wrote: |
Left one seems to be a resin repro , are there any real ones somewhere? _________________ in my Garage:
1951 crotch cooler split
1958 convertible
1971 1302 convertible
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring |
angel b Samba Member
Joined: April 20, 2025 Posts: 3 Location: Buenos Aires
Posted: Sun Apr 20, 2025 8:53 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
| empiracer wrote: |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 927 Location: Moreno Valley
Posted: Sun Apr 20, 2025 9:12 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
Ha , i see one of the pics here is one of my old classifieds pics showing the U joint .
its no longer available as is this , recently sold it . i purchased it as a repo , but it was rather nice with enameling ..........sold it to MoneyMike here on the samba
Posted: Sun Apr 20, 2025 11:38 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
[quote="empiracer"]post ‘55 reserve switch rotates 90° between the on & reserve
1955 and earlier Beetles the reserve switch rotates 180° between on & reserve is there a such thing as a proper reserve extension handle for a ‘55 down beetle?[/quoteHi , could anybody let me know the connecting rod’s overall lenght from the end of the thread to the loop that engages the lever bracket? I have some lose parts but no rod . |
Posted: Sun Apr 20, 2025 11:40 am Post subject: Re: Pre 55 Fuel reserve extension handle ? |
Posted: Sun Apr 20, 2025 5:22 pm Post subject: Re: Pre 55 Fuel reserve extension handle ? |
i am also looking for a genuine fuel lever extension for my split , does such beast exist ? if so , any for sale ? _________________ in my Garage:
1958 convertible
