Schuylersister Samba Member
Posted: Thu Apr 13, 2023 9:23 am Post subject: Bushing Snot |
Is this the best or what are other folks using to install urethane bushings? |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 801 Location: Out exploring
Posted: Thu Apr 13, 2023 9:35 am Post subject: Re: Bushing Snot |
That's what I used on my urethane bushings. Seems to be holding up pretty well so far.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
shagginwagon83 Samba Member
Posted: Thu Apr 13, 2023 9:48 am Post subject: Re: Bushing Snot |
I have roughly 5 years on my suspension and the snot is holding up well.
_________________ "Jo Ann" - '83.5 Westfalia EJ22e w/Peloquin |
10degnorth Samba Member
Joined: March 07, 2018 Posts: 483 Location: Bend, Oregon
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4573 Location: East Kootenay, British Columbia
Posted: Thu Apr 13, 2023 10:23 am Post subject: Re: Bushing Snot |
Formula 5 Prelube 9-11104 from Energy Suspension.
Good price and extremely tacky stuff. Used on my Syncro suspension rebuild with poly bushes in 2018 and still quiet as a mouse.
Highly recommend. _________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Thu Apr 13, 2023 10:40 am Post subject: Re: Bushing Snot |
10degnorth wrote: |
Just did my front and make the mistake of not putting any snot on and now it squeaks. Any recommendations on how to get some in there without redoing everything? |
Unfortunately to do it right you would need to disassemble it.
OlisGarage Samba Member
Joined: June 01, 2022 Posts: 244 Location: Indianapolis, IN
Posted: Thu Apr 13, 2023 10:45 am Post subject: Re: Bushing Snot |
Schuylersister wrote: |
I installed powerflex bushings in my mk1 rabbit convertible a few years back. Used the powerflex grease. No squeaking, but it didn't seem like anything special.
Bought bushing snot for the pwoerflex bushings on the vanagon. This stuff seems to be of very high quality. Super sticky!! Buy a box of cheap thin gloves and swap them often is my advice. If it gets all over tools it's super hard to remove.
I think it will perform very well. I have not driven the van yet though since the suspension upgrade. Still need to wrap up the engine. _________________ 1981 VW Vangagon TDI (in progress)
1984 VW Rabbit Convertible (daily)
2003 VW Jetta Wagon TDI (recovering from a hit and run) |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18834 Location: Retired South Florida
Posted: Thu Apr 13, 2023 10:53 am Post subject: Re: Bushing Snot |
thatbaldwinlife wrote: |
10degnorth wrote: |
nate |
In theory, if you mark the camber eccentric washers before disassembly, and reassemble with the washers in the same location, camber should not change.
With the tire off, you should be able to remove the upper control arm bolt and lube the bushings. My feeling is when the inner metal sleeve is sized properly, the suspension bushing should move around the sleeve when the control arm bolt is torqued to spec. So you could slip the inner sleeve out, lube the ID of the poly bushing and the OD of the metal sleeve and reassemble. |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1125 Location: over by 'der
Posted: Fri Apr 14, 2023 4:18 am Post subject: Re: Bushing Snot |
I'm still finding sticky wrenches in my tool box 4 years later, but never any noise from the front end. I would say that yes, it is the best. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Joined: January 01, 2007 Posts: 17871 Location: sticksville, ct.
Posted: Fri Apr 14, 2023 7:01 am Post subject: Re: Bushing Snot |
bushing snot FTW
the only thing on the planet that will clean it off is diesel fuel, kerosene or real deal parts washer fluid (which is basically kerosene) _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Apr 14, 2023 8:29 am Post subject: Re: Bushing Snot |
skills@eurocarsplus wrote: |
bushing snot FTW
the only thing on the planet that will clean it off is diesel fuel, kerosene or real deal parts washer fluid (which is basically kerosene) |
Guess I'm not that in on the acronym FTW so ? |
jlrftype7 Samba Member
Posted: Fri Apr 14, 2023 9:17 am Post subject: Re: Bushing Snot |
bushing snot FTW
For The Win.. FTW
I used Bushing Snot on my Poly Radius Bushings, and Nitrile Gloves....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri Apr 14, 2023 10:02 am Post subject: Re: Bushing Snot |
Ha, Ha! I love that! That's exactly what it's like. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Nick La Trique Samba Member
Posted: Fri Apr 14, 2023 5:52 pm Post subject: Re: Bushing Snot |
Yep, so awsome that I also thought FTW when my nitrile gloves broke...
Even 99% rubbing alcohool found on the lower shelves in drug stores, and lots of shop towels require some work to remove that stuff on hands and tools.
Heck, I changed the steering column bushings to Powerflex and had some all over my arms and my face.
Great product sold by Chrisopher at t3technique, and has now become quite a no-brainer on my westie and my car.
Next time, I'm wearing a disposable hazmat suit  _________________ '89 Westie, unmolested, in the family since 2002, 1 PO.
"Take a break. Never quit" |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Fri Jul 07, 2023 7:07 am Post subject: Re: Bushing Snot |
Is a 2 oz jar enough to do a pair of 2wd UCA PowerFlex bushings? Or, maybe it's best to have a 7 oz jar on hand?
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Posted: Fri Jul 07, 2023 7:42 am Post subject: Re: Bushing Snot |
for the price difference, I just bought the big tub
the smaller one would probably be just fine _________________
Jake Raby wrote: |
Brian wrote: |
mtnhome  Samba Member
Joined: July 17, 2010 Posts: 614 Location: Summit County, CO
Crankey Samba Member
Posted: Fri Jul 07, 2023 9:19 am Post subject: Re: Bushing Snot |
I did my bushings a long time ago. Back when Christopher was loogie, i don't remember if loogie sent snot or something else, but he did send special grease with my name on the container.
Still feels good driving but yeah it's started to squeak a little at curb entries. I got snot on my transaxel front mount but that's just a year old now.
I will probably add some new t3 products to the process of re greasing. I went to Fosters frame and axel in Seattle for the job and I will go back there. It could be as much as 15 years ago. |
do.dah Samba Member
Joined: August 27, 2015 Posts: 814 Location: Washington
Posted: Fri Jul 07, 2023 11:38 am Post subject: Re: Bushing Snot |
Vanagon Nut wrote: |
Neil. |
More is better. I use that shit on everything now. |
