Mrdriver10 Samba Member
Joined: April 20, 2023 Posts: 2 Location: Fredericksburg virginia
Posted: Thu Apr 20, 2023 7:11 am Post subject: What is this? |
I’m in the process of rewiring the car. Found this under the dash and can’t figure out what it is. 1966 type 3 notchback
Any help is appreciated. |
andybla Samba Member
Posted: Thu Apr 20, 2023 7:31 am Post subject: Re: What is this? |
| blinker/flasher relay |
Posted: Thu Apr 20, 2023 7:54 am Post subject: Re: What is this? |
| andybla wrote: |
Would you happen to know what the terminals mean? Cause all I’ve searched about that they don’t have l1 l2 l3 l4
I couldn’t find a wiring diagram that referred to those terminals |
GjMan Samba Member
Joined: June 05, 2004 Posts: 834 Location: Grand Junction, CO
Posted: Thu Apr 20, 2023 11:17 am Post subject: Re: What is this? |
Did you check the wiring diagrams in the Technical section?
And, oh, welcome aboard. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23598 Location: Kimball, Mi
Posted: Thu Apr 20, 2023 11:45 am Post subject: Re: What is this? |
| Mrdriver10 wrote: |
It's a 12 volt relay. No idea what it does, as most 66 type 3s are 6 volt. My first guess is that one of the cars PO's was trying to fix an electrical problem and didn't know what he was doing. It wouldn't be the first time something like that happened. At this point in time, it might have been an "extra" part he carried out to the car, and just left it behind. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Ossipon Samba Member
Posted: Thu Apr 20, 2023 12:06 pm Post subject: Re: What is this? |
I dug around in my pile of junk and found a 91/18 relay. It looks like a 91/17 except it has push on and not screw downs.
According to the what someone wrote on the side, 98/18 is for Fog lamps and fanfare horns. The diagram on top is almost identical except it uses 80,85,86, and 87 instead of L1, L2, L3, and L4.
OR
Just a Flashing relay
https://picclick.co.uk/Hella-91-17-Blinkgeber-Flas...11668.html _________________ Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Apr 27, 2023 10:24 am Post subject: Re: What is this? |
Instead of starting a new topic, thought I’d jump on here, since my question is kinda the same. Found a box of engine tin and noticed something new (to me)
The one on the left is two pieces.
What’s that from? _________________ Everything known to man has been written.
Readers are Leaders! |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36422 Location: Conejo Valley, CA
Posted: Thu Apr 27, 2023 10:43 am Post subject: Re: What is this? |
| Guess: Type 3 industrial engine? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Thu Apr 27, 2023 11:05 am Post subject: Re: What is this? |
| Mrdriver10 wrote: |
91 indicates lighting system. 30 is battery +, 31 is ground, L1,2,3 and 4 are light out terminals, S1 and S2 are signal inputs to energized breaker points. Looks like what we have here may be an early add- on hazard flasher unit. Only USA cars (and maybe Canada) got these in 1966/67. Since the NB was never officially imported, this may have needed to be installed to get it into USA. This could explain the screw type terminals- this could have been sourced from an aftermarket accessorizer prior to importation.
M630 was for 12 volt electrical systems, first available optionally in 1962 if memory serves. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Thu Apr 27, 2023 7:27 pm Post subject: Re: What is this? |
I don't think it's a flasher, my bet is fog lamp relay _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Pelle Samba Member
Joined: February 07, 2004 Posts: 215 Location: Sweden
Posted: Fri Apr 28, 2023 4:17 am Post subject: Re: What is this? |
| Air-Cooled Head wrote: |
What’s that from? |
They are "widened" by the factory to fill the wider engine compartment introduced in August 1963. |
Posted: Fri Apr 28, 2023 8:33 am Post subject: Re: What is this? |
Thanks! _________________ Everything known to man has been written.
KTPhil  Samba Member
Posted: Fri Apr 28, 2023 10:17 am Post subject: Re: What is this? |
| I think mine are not the widened style ('71). Are you sure that's it? |
Posted: Fri Apr 28, 2023 11:26 am Post subject: Re: What is this? |
| KTPhil wrote: |
Your 71 would use 1 piece already widened cooling tin. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22695 Location: Escondido CA
Posted: Fri Apr 28, 2023 12:15 pm Post subject: Re: What is this? |
| Bobnotch wrote: |
| KTPhil wrote: |
Your 71 would use 1 piece already widened cooling tin. |
The original piece in question is a 64/65 piece and is a cross over from single side draft carb to dual carb. The SSD trim was adapted for the dual carbs. The engine bay was widened due to the dual carbs in 63 as said. Anyone who has stuffed a dual carb motor in a 62/63 knows how tight it is already. If it had the electromagnet cut offs it would hit the engine bay metal - necessitating the removal of the cut offs. Even the carb linkage may hit. So when the engine bay was widened the tin was widened - Single port - two year only modified tin. _________________
| t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Apr 28, 2023 1:17 pm Post subject: Re: What is this? |
| notchboy wrote: |
| Bobnotch wrote: |
| KTPhil wrote: |
The original piece in question is a 64/65 piece and is a cross over from single side draft carb to dual carb. The SSD trim was adapted for the dual carbs. The engine bay was widened due to the dual carbs in 63 as said. Anyone who has stuffed a dual carb motor in a 62/63 knows how tight it is already. If it had the electromagnet cut offs it would hit the engine bay metal - necessitating the removal of the cut offs. Even the carb linkage may hit. So when the engine bay was widened the tin was widened - Single port - two year only modified tin. |
Used until the heater system was modified to include thermostatically controlled mixing boxes, at which point they redesigned the tin and elbows sometime in August 1964. So the modified wider tin was only in use about a year. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
Those who can- do.
