Seat belt bolt removal
70bus Premium Member
70bus is offline
PostPosted: Sat Apr 29, 2023 9:06 pm    Post subject: Seat belt bolt removal Reply with quote
Ok, what diabolical SOB at VW came up with the seat belt nuts that can’t be reached at the same time as the head of the bolt? Not all of us have helpers. Not only that, the bolts are really long, so I of course have no socket that can reach the nut… not to mention the fact that the bolt tilts and throws the wrench off the nut. I can mostly get the ones by the door opening (tho they are so rusty I can’t budge them) but the ones in the tool well are stumping me for solo removal. Considering a hacksaw might be easier.
Not really a question - more a rant. Two hours, three busted knuckles, and about 4 turns total per nut, even after soaking in liquid wrench for days.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
PostPosted: Sat Apr 29, 2023 10:21 pm    Post subject: Re: Seat belt bolt removal Reply with quote
On your '65? Aren't the "nuts" welded onto the reinforcement plates?
My '63 has big plates with round "nuts":
70bus is offline
PostPosted: Sun Apr 30, 2023 1:38 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Looks like just a hole. Possible the wheelwell nuts have broken loose as they definitely spin. Toolwell I can’t tell because I can’t do both at once. Might try to get a video from below while I turn bolt head in well to see.
Wheelwell nut
Toolwell nut
Bolt head by doors
Craig K
70 Neunsitzer
65 Pritschenwagen
busdaddy
busdaddy is offline
PostPosted: Sun Apr 30, 2023 2:57 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Aftermarket, and a really shitty job at that, not even a big washer to prevent it from pulling through, those belts were only decorative.
Clamping a big pair of vise grips on that will catch on something to hold it while you turn from above, but sawing it off would be my first choice.
Слава Україні!
70bus is offline
PostPosted: Sun Apr 30, 2023 3:47 pm    Post subject: Re: Seat belt bolt removal Reply with quote
At least they used the factory belts lol
Craig K
70 Neunsitzer
65 Pritschenwagen
busdaddy
busdaddy is offline
PostPosted: Sun Apr 30, 2023 5:57 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Those are aftermarket as well, common ones sold by most North American dealers (and likely VWOA), but not from a factory in Germany. Rebranded Air Associates belts (or a similar brand), found in many other makes too with the appropriate sticker applied to the buckle.
Better markup than pushing the customer to opt for the German belt upgrade, just like radios. Sadly the zitty faced kid tasked with installing those didn't read the instructions properly. Rolling Eyes
Слава Україні!
70bus is offline
PostPosted: Sun Apr 30, 2023 6:47 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Thanks for that; went and cleaned off the rust and paint and found they ar Hickok belts.
I put retractable 3-points into my bay; might have to investigate that here, since I'll need someone to do welding anyways...
Craig K
70 Neunsitzer
65 Pritschenwagen
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Apr 30, 2023 8:10 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Search of the internet for "Nut splitter tool":
https://duckduckgo.com/?t=ffab&q=nut+splitter+tool&ia=web
In Stereo, Where Available!
70bus is offline
PostPosted: Sun May 07, 2023 6:04 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Found my nut splitter, split the nut... stayed on the bolt! LOL. I'm gonna have to do most of them twice, and pound off the pieces. If it wasn't so loud under the wheelwell with a Fein tool I'd just saw the bolt in half!
Craig K
70 Neunsitzer
65 Pritschenwagen
Huetti_1989
Huetti_1989 is offline
PostPosted: Sun May 07, 2023 10:28 pm    Post subject: Re: Seat belt bolt removal Reply with quote
You can cut the bolt and nut with an angle grinder, clamp the upper side to hold the bolt.
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
busdaddy
busdaddy is offline
PostPosted: Mon May 08, 2023 7:55 am    Post subject: Re: Seat belt bolt removal Reply with quote
If the nut is split it must turn now, clamp some locking pliers on it and unwind the bolt out from above.
Слава Україні!
70bus is offline
PostPosted: Mon May 08, 2023 5:14 pm    Post subject: Re: Seat belt bolt removal Reply with quote
Got them off by buying a Makita impact wrench with deep sockets and a waaaay bigger visegrip. Even the split nuts resisted the impact wench for a few seconds. They weren't, but I was beginning to wonder if they were welded on...
Craig K
70 Neunsitzer
65 Pritschenwagen
