My 61 panel (and a 66 panel digout)
Page: Previous  1, 2, 3 ... 17, 18, 19, 20, 21, 22  Next
Huetti_1989
Huetti_1989 is offline
PostPosted: Wed Aug 03, 2022 12:02 pm    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
Nice!
What „glue“ do you use?
Welding looks better, i don’t want to do some teaching here to anyone, but may turn up the amps at the welder and of corse more wire, you should listen the welder - not brtbrtbrt, so chhhhhhhhhht to make flatter welds, you would see they are stronger, easyer to weld and you not need to grind that much!
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
karl h
karl h is offline
PostPosted: Thu Aug 04, 2022 12:16 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
i use teroson 9220
61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 ragtop on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Sun Aug 07, 2022 2:11 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
next: the cargo doors
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Sep 15, 2022 3:13 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
jackpoints fitted
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Wed Oct 05, 2022 12:39 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
some more parts back from the blaster
the doors are perfect except minor holes on the bottom
upper door hingepins have to be replaced too
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Mon May 08, 2023 3:04 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
these are the last two spots that need welding on the body, there were some pinholes because of the sandblasting
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 3:45 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
i had to find out how to make the safari recess in the upper windshield frame next
first i marked the metal left and right with a sharpie where the hinge is, window
centered
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 3:46 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
then, using a dremel with a tiny cutoff disc i cut 10mm outward of these marks
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 3:48 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
using a rounded off chisel
and some visegrips to not desort the lip, i knocked the metal inward and upward very carefully
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 3:49 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
the result was
trial fit
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 3:51 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
and welded shut. i used a mini abrasive disc and a rotary file (the one i port my heads with) to even out these
68 ghia vert
86 Caravelle
04 new beetle vert
scarabee
scarabee is offline
PostPosted: Thu Jun 15, 2023 6:01 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
Huetti_1989 wrote:
Nice!
-Christian
Thanks for this tip, Huetti_1989! Love the silent sound effects.
karl h
karl h is offline
PostPosted: Thu Jun 15, 2023 7:31 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Mon Jul 17, 2023 11:55 pm    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
working on the cargo doors
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Thu Jul 20, 2023 12:27 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Fri Aug 04, 2023 7:22 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
painted the underside today
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Mon Aug 07, 2023 12:09 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
cabin primered
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Tue Aug 15, 2023 11:07 pm    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
Cool
68 ghia vert
86 Caravelle
04 new beetle vert
karl h
karl h is offline
PostPosted: Fri Aug 18, 2023 11:30 am    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
68 ghia vert
86 Caravelle
04 new beetle vert
Chad M
Chad M is offline
PostPosted: Thu Aug 31, 2023 5:30 pm    Post subject: Re: My 61 panel (and a 66 panel digout) Reply with quote
Looks great Karl!
I just found the thread today and powered through it, you've accomplished a lot in the last decade!
Page 18 of 22
