schortie Samba Member
Joined: February 07, 2021 Posts: 23 Location: Michigan
Posted: Tue Jun 06, 2023 11:36 am Post subject: Blanket stuck in rear bench latch. |
The latch is locked but the pull knob never went back into position. Seat won't move and neither will the blanket. What's the fix?
I tried to search but grew impatient - as is my nature. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4835 Location: Bemidji, MN
Posted: Tue Jun 06, 2023 12:03 pm Post subject: Re: Blanket stuck in rear bench latch. |
sit on the seat and pull the latch hard then stand and lift the seat up all the while holding the knob out. if you're light, get two people! _________________ -dan
www.thefixitworkshop.com |
Posted: Tue Jun 06, 2023 12:28 pm Post subject: Re: Blanket stuck in rear bench latch. |
I'll give it a shot, but since the knob is already "pulled out" with the seat locked, I'm not sure it's the way. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6254 Location: Portland OR
Posted: Tue Jun 06, 2023 12:31 pm Post subject: Re: Blanket stuck in rear bench latch. |
just yank on it. _________________ 89 Westy 2.1 Auto |
fxr Samba Member
Joined: December 07, 2014 Posts: 2329 Location: Bay area CA
Posted: Tue Jun 06, 2023 12:37 pm Post subject: Re: Blanket stuck in rear bench latch. |
Do you mean 'pull out' or 'pull up'?
My latch knob is very definitely 'lift up'. No 'out' involved. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Jun 06, 2023 12:53 pm Post subject: Re: Blanket stuck in rear bench latch. |
My knob pulls out and, as stated, did not go back into the "in" position it should be in when the bench seat is locked down. So the seat is "locked" and the knob is "out". I'm not able to lift the seat or flatten the bench into the bed. |
elizer Samba Member
Joined: May 02, 2016 Posts: 1480 Location: Northern Virginia
Posted: Tue Jun 06, 2023 1:10 pm Post subject: Re: Blanket stuck in rear bench latch. |
Can you try getting like a ruler or something flat there _________________ 91 syncro westy fas tdi |
Posted: Tue Jun 06, 2023 1:32 pm Post subject: Re: Blanket stuck in rear bench latch. |
No, there is no room and there is no movement in the seat at all. It's locked in place. |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Tue Jun 06, 2023 2:33 pm Post subject: Re: Blanket stuck in rear bench latch. |
it might be possible to remove mattress and fish a coat hanger in from the back to hook/engage the latch mechanism _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Tue Jun 06, 2023 3:40 pm Post subject: Re: Blanket stuck in rear bench latch. |
if the blanket is the problem, is it caught in the latch or just putting upward tension on the latch?
if the latter, cut the hanging part of the blanket off, assuming not an heirloom wool one, and tap the blanket back into the storage area with a putty knife and mallet. _________________ -dan
Posted: Tue Jun 06, 2023 4:54 pm Post subject: Re: Blanket stuck in rear bench latch. |
It's completely caught in the latch. I'll likely cut the blanket regardless, but while not an heirloom, it is a great wool blanket.
I'm wondering if there's a way to disassemble the bench from the outside? Without a saw of course.
Unless I get this figured, I guess I'll be sleeping upstairs for a while. It's a rude 3am pee run from up there. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32695 Location: Reading Pennsylvania
Posted: Tue Jun 06, 2023 5:29 pm Post subject: Re: Blanket stuck in rear bench latch. |
schortie wrote: |
that's what a Gatorade bottle is for. _________________ -dan
jimf909 Samba Member
Posted: Tue Jun 06, 2023 7:28 pm Post subject: Re: Blanket stuck in rear bench latch. |
This may be one of the most frustrating Vanagon events. Next step is to figure out how to ensure it doesn't happen again.
I removed the latch to make opening the seat a one hand affair and love the convenience.
See this thread for the ideas along those lines (I'd still like to use a gas spring and a non-jammable latch)
https://www.thesamba.com/vw/forum/viewtopic.php?t=721523 _________________ - Jim
Abscate wrote: |
Posted: Thu Jun 08, 2023 3:03 am Post subject: Re: Blanket stuck in rear bench latch. |
djkeev wrote: |
You have the camper foam on plywood seat?
Pull out on the knob fully, get a construction flat pry bar and push, bang it in between the seat bottom and the latch.
Odds are high that this wedge action alone will unjam the blanket in the latch and pop the seat loose.
Dave |
This sounds like it may be the way. Wish me luck when I give it a shot this afternoon.
Thanks for all the replies. |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Sun Jun 11, 2023 7:37 am Post subject: Re: Blanket stuck in rear bench latch. |
Well? Are we unstuck now? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
steve244 Samba Member
Posted: Sun Jun 11, 2023 11:06 am Post subject: Re: Blanket stuck in rear bench latch. |
cmayna wrote: |
Well? Are we unstuck now? |
I've been sitting on the edge of my bench seat waiting for the results. _________________ - Jim
Abscate wrote: |
bobhill8 Samba Member
Posted: Sun Jun 11, 2023 11:50 am Post subject: Re: Blanket stuck in rear bench latch. |
Let me just issue a blanket statement: If this hasn't been covered before, get down on your hands and knees and pull the blanket up toward your chin. Roll to one side in the fetal position and rest your head on your tool bag. Dream of the blanket coming free. If you need help, ask Mr. Sandman. Be careful who you ask for help. Don't get fleeced. _________________ 1986 Westy
1971 Squareback |
