vwhelmot Samba Member
Joined: May 04, 2006 Posts: 645 Location: united kingdom
Posted: Tue May 09, 2023 8:55 am Post subject: Re: Okrasa / Judson |
| Probably not tbh |
Posted: Sat Jun 03, 2023 3:52 am Post subject: Re: Okrasa / Judson |
PatJr Samba Member
Posted: Sat Jun 03, 2023 5:23 am Post subject: Re: Okrasa / Judson |
car-art
I couldn't even drive it out of fear of getting a finger print on the door handles _________________ #############################################
1970 Transporter a orange one
Posted: Sat Jun 24, 2023 3:15 am Post subject: Re: Okrasa / Judson |
Posted: Sat Jun 24, 2023 3:17 am Post subject: Re: Okrasa / Judson |
| Its up and running and after just a few short drives i can tell that its going to be a lovely little motor. Its so smooth and seems to have plenty of torque. It also starts instantly when hot and doesn`t leak which is a first for me. |
Joined: June 24, 2015 Posts: 894 Location: Rialto. CA
Posted: Sat Jun 24, 2023 11:21 am Post subject: Re: Okrasa / Judson |
| vwhelmot wrote: |
Have you thought about having your intake manifold ends recast ..for the 36hp market??? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1328 Location: Central Washington
Posted: Sat Jun 24, 2023 11:41 am Post subject: Re: Okrasa / Judson |
| [email protected] wrote: |
| vwhelmot wrote: |
As awesome as that idea sounds- if you saw the amount of custom work he's done to make those fit the already expensive Okrasa heads you'd see that the market would be *small*.
I'm sure a couple people would make them work, but the skill involved to create that setup is waaaay beyond the average person. _________________
| hitest wrote: |
| Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Mon Jun 26, 2023 3:22 am Post subject: Re: Okrasa / Judson |
| I really don`t think there is a market for getting these manifolds cast tbh. Its not only that but the tinware modification required might put people off plus some still think that this is not a good way to gain more power choosing the simpler route of twin carbs. |
Posted: Mon Jun 26, 2023 2:21 pm Post subject: Re: Okrasa / Judson |
| vwhelmot wrote: |
Single zenith ndix or a single idf or solex p11 this manifold okrasa ends would be cool |
Posted: Tue Sep 19, 2023 2:01 am Post subject: Re: Okrasa / Judson |
Few little modifications, stock wheels with Firestone crossplys and made another bigger belt tensioner.
Posted: Tue Sep 19, 2023 10:25 am Post subject: Re: Okrasa / Judson |
It's looking nice with the stock wheel setup ...
Have you thought about maybe installing a 40hp judson pulley single belt setup ..the 40hp single pulley would allow less strain on the crank than the dual 36belt system...judson realized that problem and went with a single belt .... |
Posted: Wed Sep 20, 2023 1:34 am Post subject: Re: Okrasa / Judson |
Never thought about changing the pulleys etc tbh. I`ve always liked the twin belt set up, i tend to run the belts fairly loose.
Cheers |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14239 Location: Southampton U.K.
Posted: Wed Aug 06, 2025 4:47 pm Post subject: Re: Okrasa / Judson |
| Any updates ...how's the hp ....what's the pros and cons on the build ...what are the next changes ..if any .... |
Posted: Mon Aug 11, 2025 7:04 am Post subject: Re: Okrasa / Judson |
Cheers for the interest. only done a few modifications over the last year or so. I restored a weber 32pci carb and fitted it after finding out that it has the same stud spacing as the original 29pci. The extra bore and venturi size has improved its breathing no end and noticed a change in power. I`ve been enjoying driving it, not very often but when i do its the smoothest ,quietest bug ive ever been in.
Posted: Mon Aug 11, 2025 7:11 am Post subject: Re: Okrasa / Judson |
| I wonder what that 32 pci came from ..it looks differnt than any other solex 32 pci ..the 32 pci usually has a bigger accelerator pump this one looks to have a stock 28 pci one ...body looks a bit different too..... |
Posted: Mon Aug 11, 2025 7:46 am Post subject: Re: Okrasa / Judson |
| Its a Weber 32pci. The solex 32pci will not fit on the judson housing because they have a wider bolt spacing. The Weber is an odd carb but it works great. |
Posted: Mon Aug 11, 2025 8:01 am Post subject: Re: Okrasa / Judson |
| Oh i see differnt brand .....looks like from what I just searched I've seen a few selling in brazil .... |
