Accelerator cable....
davebuckholts
davebuckholts is offline
PostPosted: Mon Nov 01, 2004 7:32 am    Post subject: Accelerator cable.... Reply with quote
Isn't there suppose to be a sleeve for the acc. cable from where it exits the tube in the back to the front of the engine tin? I have to replce my pressure plate and notice the acc. cable cutting into my bellhousing.
My '66 RHD Japanese bug build..which has stalled!
http://www.thesamba.com/vw/forum/viewtopic.php?t=471759&postdays=0&postorder=asc&start=0
TeamSpatula
Samba In The Rain
TeamSpatula is offline
PostPosted: Mon Nov 01, 2004 7:47 am    Post subject: Reply with quote
There should be a sleeve that goes through the fan shroud housing, but I've never seen one between that tube and the main cable housing. Maybe the end of the tube is crooked, and is aiming the cable incorrectly so it rubs?
<---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com
Clara Premium Member
Clara is offline
PostPosted: Mon Nov 01, 2004 8:26 am    Post subject: Re: Accelerator cable.... Reply with quote
you can either use old gas line, or get a bowden tube for a bug and shorten the bug tube 1/2 inch. having the tube makes the pedal feel nicer, as well as protecting the tranny.
Andrew
Andrew is offline
PostPosted: Mon Nov 01, 2004 8:51 am    Post subject: Re: Accelerator cable.... Reply with quote
I just went to Home Depot and got a piece of flexible tubing. Been working fine for me. The old gas line idea is pretty good, though, as most people will have that lying around after changing their gas lines.
-Andrew
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Nov 01, 2004 10:44 pm    Post subject: Re: Accelerator cable.... Reply with quote
Hi Dave,
No & Yes. Try this info we posted on the type2.com vintage bus list, and now in the archives there:
http://www.type2.com/archive/vintagebus/064591.html
Eric&Barb
Thompson2
Thompson2 is offline
PostPosted: Tue Sep 24, 2019 9:48 pm    Post subject: Re: Accelerator cable.... Reply with quote
So I picked up one of the bug tubes and was set to trim it as described, but wanted to see if there was a particular method to the madness. Just hack off 1/2” of the straight end? I tried to pull the end off and trim just the sleeve, but it won’t come off without some struggle... should I wrestle it off?
And how critical is the 1/2”? On the straight end, it necks down at 10mm... is that sufficient?
Eric&Barb
PostPosted: Wed Sep 25, 2019 7:15 am    Post subject: Re: Accelerator cable.... Reply with quote
Then install the accelerator bowden tube, and if too long, the cable will be too short.
In Stereo, Where Available!
Thompson2
PostPosted: Wed Sep 25, 2019 9:49 am    Post subject: Re: Accelerator cable.... Reply with quote
Is there a portion of your response missing or have I not had enough coffee? Not sure what you're saying... I get the part about if the tube is too long the cable will be too short... but you started with "Then"... was there a lead in that got lost?
Eric&Barb
PostPosted: Wed Sep 25, 2019 10:51 am    Post subject: Re: Accelerator cable.... Reply with quote
The last post was mostly referring to the above. The only way to tell for sure is to install and see if it all works out or the accelerator bowden tube needs to be shortened.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Wed Sep 25, 2019 10:59 am    Post subject: Re: Accelerator cable.... Reply with quote
Pull the sheath out of the straight crimped end, not the flared end. You may need to jam a screwdriver around there to uncrimp it a bit. It will not be a surgical process...more violence will be required. Whatever damage you do to the sheath will be hidden when reinserted into the crimp.
If you want to be 100% sure of how much to shorten it, then reinstall the engine and test-fit the sheath until it fits with only a tiny amount of slack. I used the recommended amount posted here by Clara and it worked fine.
Thompson2
PostPosted: Wed Sep 25, 2019 11:35 am    Post subject: Re: Accelerator cable.... Reply with quote
Makes sense. I'm hoping to avoid having to pull / reinstall.
Thompson2
PostPosted: Wed Sep 25, 2019 11:38 am    Post subject: Re: Accelerator cable.... Reply with quote
Yup... straight end was my focus last night... Made the most sense.
That was what I was wondering about the process side of it. Just didn't want to screw it up and have to order a new tube and revisit this... ready to get her out on the road before the rain starts in earnest.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Wed Sep 25, 2019 2:56 pm    Post subject: Re: Accelerator cable.... Reply with quote
Like this?:
https://www.thesamba.com/vw/classifieds/detail.php?id=2294939
as far as I am aware there isn't a reproduction out there.
Roads Scholar
Member# 2059
rking6
rking6 is offline
PostPosted: Wed Sep 25, 2019 3:16 pm    Post subject: Re: Accelerator cable.... Reply with quote
I just installed (Throttle Cable Rollers by Butty Bits) it solved my Bell housing from being scared by the cable on my 1963 EZ..... Check it out...
Resto Bus Parts [email protected]
Good Luck BB King
Eric&Barb
PostPosted: Wed Sep 25, 2019 3:39 pm    Post subject: Re: Accelerator cable.... Reply with quote
tasb wrote:
Like this?:
Try a WWW search for "VW 111721551". Found airheadparts has a supply of new ones.
Updated for future searches:
131721551
Thompson2
PostPosted: Wed Sep 25, 2019 3:43 pm    Post subject: Re: Accelerator cable.... Reply with quote
tasb wrote:
Like this?:
Like this:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D131%2D721%2D551
And probably this with it:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-311-721-579
Also available from WW or most any place that carries air cooled parts. I picked mine up locally.
Leica356
Leica356 is offline
PostPosted: Wed Jul 12, 2023 6:50 pm    Post subject: Re: Accelerator cable.... Reply with quote
So there are two different length tubes for the beetle. 623mm and 610mm. Is the 610mm the one that needs to be shortened 1/2 inch to fit a bus?
ted698
ted698 is offline
PostPosted: Thu Jul 13, 2023 4:56 am    Post subject: Re: Accelerator cable.... Reply with quote
I just slipped a length of standard 6mm nylon airhose over the throttle cable.
Its not fixed either end, but long enough to stop the cable sawing its way into the gearbox.
Cheap and effective.
Tahlequah Premium Member
Tahlequah is offline
PostPosted: Tue Aug 01, 2023 2:36 pm    Post subject: Re: Accelerator cable.... Reply with quote
i put one on and didnt know to cut until i read this, was planning on removing because it's pushing my front engine tin open when i hit the gas. ty samba nerds
