For those who are buying Mansispeed or are running Mansispeed
dub84
dub84 is offline
PostPosted: Fri Aug 25, 2023 2:04 pm    Post subject: For those who are buying Mansispeed or are running Mansispeed Reply with quote
Hey everyone,
It’s been few years since frequenting the forums… but I’ve just taken ownership of a 1990 Vanagon Westfalia GL… for years I’ve been thinking about a Subie swap but have stumbled upon the sensational mansispeed EFI kit…
For the layman such as myself… can anyone answer the following:
Does running the stock injectors create that much of a downside? Can I run stock injectors and be satisfied with the improvements?
Same question for rockers…
I’m just wondering if I can be happy with mostly stock items or if I am essentially cheaping out on hidden gifts with the extra parts.
Cheers,
Parker
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Fri Aug 25, 2023 2:09 pm    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
I sure wish I were in your shoes of having the Mansi EFI and then having to think about stock rockers and injectors... I didn't know Mansi was dev'ing the EFI when I was going with the Gold injectors and rockers. What I found with them seemed to me to be a vast improvement over stock. I am still trying to save up for that EFI though. Looks good on paper. Not too spendy, etc. [hitting the Like button]
Wildthings
Wildthings is offline
PostPosted: Fri Aug 25, 2023 2:14 pm    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
No experience with their kits but I would be wanting to know what the torque curve looked like between 1500 and 4000 rpms compared to stock as that is the speeds you are most apt to be running.
dub84
dub84 is offline
PostPosted: Fri Aug 25, 2023 2:23 pm    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
Not in the situation yet, saving my roubles one day at a time… just wondering if I can get away with running stock injectors and not hating myself for it lol…
As far as the rockers… my knowledge doesn’t extend past knowing what the advantage would be (my apologies)
*EDIT* I suppose running the kit itself would still be a modest improvement over the digifant system and I could add the injectors and rockers down the road?
0to60in6min
0to60in6min is offline
PostPosted: Sat Aug 26, 2023 7:47 am    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
I have Mansispeed injectors and rocker arms on my tintop Syncro since 2018.
Smooth idle, good acceleration on stop and go, easy to pass on freeway from 55 mph to 70 mph. I'd think there's some power gain but I don't know the percentage.
OEM injector, single port.
Mansispeed injector, 4 ports.
MarkWard
MarkWard is offline
PostPosted: Sat Aug 26, 2023 8:17 am    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
In general, any standalone engine management would need to be “tuned” to each engine. This would include a lot of variables. I don’t find that one tune fits all engines. VW, did a pretty good job with their stock tunes.
So basically injectors are rated at volume per hour or minute at 43 psi. “Bigger” injectors flow more fuel for a given on time. So, you’d want to compare flow numbers to see if one flows more or less fuel. This is adjusted in the tune with a standalone system to a point.
Another consideration is spray pattern and atomization. I have to imagine the four port injector does this better. At wide open throttle, injector pattern is probably less important.
No comment on ratio rockers other than what was mentioned, if they move the torque up into a range you don’t normally operate, not much benefit.
Jake59
Jake59 is offline
PostPosted: Sat Aug 26, 2023 9:41 am    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
This performance question would be a good one to put directly to Marco.
And because I already had his rockers inplace at the time I did my upgrade to his EFI and installed Manispeed injector at the same time as the EFI upgrade, I can not answer your question precisely.
However with performance set aside I can say the vast number of "gremlins" we chase in "why my van isn't running well" or "not running at all" can be attributed to the 30-40 year old EFI design, aging sensors and general wiring issues. With Marco's new EFI You are eliminating things like the AFM sensor and the Hall sender, both of which have given me trouble in the past. There is an updated TB sensor and the O2 sensor which are much improved, coil over plugs so no more rotor and spark plug lead issues (yes I was down for several months chasing what ended up being a bad spark plug lead) and atlast having a USB port connected to a tuning software is a major jump forward. What I am saying is 80-90% of the reasons people look at newer power plants (Subi, Tico, Bostig etc) is to get into the 21st century technology. You are now going there directly to 2022 by installing these new EFI kits
There has never been a question (in my mind) about the WBX mechanics (after the head gasket was solved) and it is a big reason I like to drive a Vanagon, that lower torque curve the sound and general feel of an opposing flat 4 engine design.
Curent ride: 87 2WD Westy, 2012 Jetta Sportwagon 2.5S
Past Rides: 62 (23 window) Bus, 64 Ghai convertable, 68 single cab, 72 Super Bettle, 78 Bay window Bus, 84 GTI.
therastavan
therastavan is offline
PostPosted: Sat Aug 26, 2023 8:36 pm    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
A 4 port injector is not necessarily going to give better performance than a single on the Vanagon. Would be great if Manispeed would give printouts showing what if any power increase their injectors offer over cleaned OEM ones because I think what is happening with a lot of owners is that they upgrade to the Manispeed over dirty OEM injectors and notice the obvious power increase. But the question is whether they would notice a difference between the two if they had simply cleaned their original injectors with a service like Mr. Injector.
0to60in6min
PostPosted: Thu Aug 31, 2023 2:52 am    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
The OEM injectors one mine were not dirty. The engine was freshly rebuilt (under 2K miles) and the rebuilder sent them out for cleaning and calibration.
ronL
ronL is offline
PostPosted: Thu Aug 31, 2023 5:47 am    Post subject: Re: For those who are buying mansispeed or are running mansispeed Reply with quote
Last year i replaced my original 1991 ( 88,000 mi) injectors with Marco's (mine were not even that dirty) and I noticed a difference in performance immediately. More power in the mid and upper range it made my camper a pleasure to drive again. Part of this upgrade included new wires, new fuel lines and filter starting from the tank and cleaning all the grounds in the van. Marco is the man...hoping to complete the job with his new EFI over this winter. All this seems a better alternative to a new engine, and way les expensive.
Bub
Bub is offline
PostPosted: Fri Sep 01, 2023 11:51 am    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
I have had Mansi's EFI since last year. Initially installed on an old engine i was going to rebuild, and went through some tunning issues after I swapped in a 'temporary' engine.
In some troubleshooting Marco actually told me that while he does prefer his injectors- since they're a thing he knows and has no suspicions about- but that any good working injector should be fine for his system. Your old injectors should provide as good a result with Microsquirt as they do on DIGI.
However, when you do these modifications/ upgrades if there is any troubleshooting to do, having a good known injector can save some headache.
I eventually got a set from an injector rebuilder service, Marco has no issues with that.
A new or rebuilt part should work well with just about any setup designed to fuel a WBX engine.
Must admit his kit is fairly awesome. The biggest downside is that the best, and almost ONLY, source of information about it is through him directly. So if you have issues you can't really isolate yourself you have to bug him and after a while you can feel like a burden, because he's a seriously nice guy.
I'm hoping he puts together a little tips and advice type thing so we can begin to manage the FI system without bugging him. Knowing why/when/how the LED blinks is good info. And also what sensors rely on what other sensors to work properly (like The AC idle compensation parameters do not seem to work if the TPS isn't accurate, and stuff like that).
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
valvecovergasket
valvecovergasket is offline
PostPosted: Fri Sep 01, 2023 5:39 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
All of that stuff is pretty readily available MS info, if you feel like you're overwhelming him with questions
Bub
Bub is offline
PostPosted: Fri Sep 01, 2023 5:46 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
Can you show us where? Because I’ve asked and a lot of the parameters specific to Mansis’ setup. I’ve done some tuning before, but with modern stuff using NEFmoto, and this is entirely different and more simple if anything.
But certain things are critical- such as the TPS being accurate below 12%- and without that single bit of knowledge you can go crazy changing whatever you want. The fact that it runs and drives fairly GREAT even with TPS unplugged kinda makes it harder to isolate little issues.
mcdonaldk
mcdonaldk is offline
PostPosted: Sat Sep 02, 2023 12:00 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
Only using the injectors. Made a big difference in performance. Nothing measured, just the seat of my pants feel. Well worth the the money. JMHO
9.5isCanadian
9.5isCanadian is offline
PostPosted: Mon Sep 18, 2023 9:31 am    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
This is a long read but I wanted to be clear and provide some worthwhile information in case there are people on the fence regarding this kit.
Received my kit this past weekend and installed it over Friday night and Saturday.
The kit is of most excellent quality with attention to detail evident throughout. Each component is professionally built and packaged.
I thought I’d post up my overall experience with the kit for anyone that may be interested.
To start my base line van is an 87 high top Get-Away.
Last winter I put an new top end on including 2.2 cylinders and pistons, new heads complete, entirely new coolant system front to back, including GW thermostat housing. GW throttle body MansiSpeed injectors, Kyle Automotive harness. New wires, cap, rotor, plugs, air filter. Compression was an acceptable to me 160 range. All this is to say I was starting off in a pretty good place power and build wise.
Many in this thread are asking about “more power” to which I’d say that I don’t feel I have gotten any significant increase in power but that is not to say there’s been no improvement. For sure there is an increase in midrange usable power. This in turn makes for a very much improved “drivability” sense.
There’s a long climb near where I live that I routinely use as a gage for engine tuning / improvement. It has a light at the bottom so I can always start off in a known state. Stopped waiting for the light.
Wednesday before my kit arrived, I hit the Test Hill.
After the light turns green it was 35 seconds to high gear, 1 minute 45 seconds to the top of the climb holding high gear (just barely on the 2000rpm mark) terminal speed on the high side of 85 kph (if I lean way over and look at the speed-o I could almost say 90k).
Sunday, after driving around Saturday afternoon and evening with the MS-700 kit installed to ensure all was good, I drove to The Hill.
This time it was 22 seconds to high gear, pulled strong all the way, 1:22 to the top with a terminal speed of a solid 95 maybe even 100kph. 2200 / 2300 rpm.
None of these “test” are 1/4 mile drag simulations. Just pulling off the light normal accelerating in a daily driver method. The times are so close that I could easily have been more casual on the first day v/s the second day.
I then spent the rest of Sunday driving along a narrow lake view twisting road. Van stayed comfortably in high gear with speeds ranging from 60k to 80 / 90 where appropriate. It was nice to not have to jockey the box at each rise in the road or down shift through corners. The motor pulled well to allow for a relaxed cruise along the lake.
I’d definitely say the kit has changed the motor for the better. With out question worth every penny for me if not just for the improved way the motor sounds, runs and feels.
With all that said.
I was bummed that it still doesn’t idle smoothly, I have it set to 950rpm, as close as I can using the lap top rpm display but the fluctuation prevents a clear view. As of now it will sit at 950 +/- but will rise to 1050+/- and drop as low as 850 or so, I never really know. The timing advance swings from zero to as high as 40 deg advance. The motor stumbles, rpm drops, and the cycle repeats about 40 seconds between each cycle.
The second downer is that it won’t start without the gas pedal. I’d have expected it would kick over and start without that.
So all in all only two bummers but I’ll take the good with the bad and be happy with the other vast improvements the kit has provided.
I’ve started searching for tuning guides and such to see if I can ‘tune’ the starting enrichening. Interestingly I’ve just read that needing the gas pedal can either mean that it is currently too rich or too lean as depressing the gas pedal kicks the system into ‘flood clearing’, so turns off injector pulses to clear any excess fuel. I dunno I’ve only just started the learning process.
Good times ahead.
EDIT: I want to be clear that I understand this is a tunable system and in no way feel the product is defective because it won't idle smoothly etc. That part of the process is my responsibilty to learn how to tune it. Anecdotally, when it was rolling on the idle I did my usual walk to the back to see what what going on. Except now there's nothing to inspect. Walked back to the lap top and realize I've got some learn'n to do. Laughing
9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi
valvecovergasket
PostPosted: Mon Sep 18, 2023 12:51 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
theres a flood clear TPS threshold - beyond that it turns the injectors off. typically 75% or greater.
below that, needing throttle is a sign youre too rich. if i were to guess randomly, id assume that thats the case.
i think ive mentioned the idle tuning things in other ms/manispeed threads, theres a lot of moving pieces there.
definitely not an easy task to nail every engine config with a drop in kit covering a wild variety of engine/actuator conditions and installer/base tune skill sets.
9.5isCanadian
PostPosted: Mon Sep 18, 2023 3:48 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
Thank you for the intel. I'll search out these other threads and read through. I know of an original thread regarding Mansispeed stuff so I'll start there.
Thumbs Up
2018 BMW R Nine T
2012 Golf tdi
marcotheturbosteamengine
marcotheturbosteamengine is offline
PostPosted: Tue Sep 19, 2023 3:56 pm    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
With all that said.
Good times ahead.
First off thank you for buying my kit, if there is any problems I’m 110% behind sort it out and working with you to resolve it. To be honest with you Idle is the trickiest part, as every engine is only just slightly different and idle adjustment is very sensitive to these differences, most engines it will just idle and be perfect with the standard tune, but a very few need some tweaking, my system works in a very different way than the Stock ECU, it actually tries to compensate for idle variances so the engine doesn’t stall, that’s what you might be experiencing an up and down scenario, but be assured this be adjusted, this actually helps when just riding the clutch in traffic and also pulling away, it makes the engine very drivable when working correctly.
I used tunerstudio, which is very easy to configure and use, which allows you to look at every sensor and also change some of the tune, there is a section in this that’s called dataloging, all you have to do is enable data logging so the laptop starts recording and then attempt to run the engine, get it to idle and recorded a datalog, with that log you can send that to me and I can change all the specifications thats needed, and send you back a revised tunning file, this resolved 99% of the problems. It might sound complicated but it’s actually very very simple and easy, a powerful tuning tool to get your engine running absolutely perfectly, that other FI kits do not have.
As you mentioned earlier, it took you 35 seconds to get into Top Gear before and now it takes you 22sec, that is a huge improvement to an engine you really haven’t changed physically.
9.5isCanadian
PostPosted: Wed Sep 20, 2023 7:07 am    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
EDIT: I want to be clear that I understand this is a tunable system and in no way feel the product is defective because it won't idle smoothly etc. That part of the process is my responsibility to learn how to tune it.
>snip<
, get it to idle and recorded a datalog, with that log you can send that to me and I can change all the specifications that's needed, and send you back a revised tunning file
>snip<
Hi Marco. Thank you for the very generous offer of helping me with a new tune. I sent you a pm.
So took the van out on another back road drive and approached The Hill from the other direction (as you'd expect the hill climbs a plateau then drops off the other side. Coming from the south it's got a light at the bottom, heading south its all open highway) and this is where the biggest improvement shows up.
Instead of pinning it and frantically racing to the bottom with hopes of carrying enough speed to hold high gear, this time I hit the bottom at a reasonable 10 over the posted 100k
Gradually poured on the coal as the hill steepened and darn it if I wasn't flex'n on the little sedans and hatch back cars floundering up the hill.
Suckers ........ Laughing
Easily held 100k up and over the top like a boss.
Cool
Ok, enough outta me on this. You all get it, I'm a strong advocate for this kit.
Lastly I'm wonder'n if someone should start a MS-701 tuning thread so we can post up our tweaks and results. This might take the load off Marco and let us begin holding our own hands with this. I have no doubt there are many here that have mad skills with tuning software in general and this kit specifically.
Just a suggestion.
Peace.
2018 BMW R Nine T
2012 Golf tdi
valvecovergasket
PostPosted: Wed Sep 20, 2023 8:02 am    Post subject: Re: For those who are buying Mansispeed or are running Mansispeed Reply with quote
the big thing there will be sharing msq files and datalogs.
one of the microsquirt threads has some more general MS chat in it
i dont know how weird manispeed is about sharing msq files also. i know some folks get weird about that, feeling that that info is "proprietary"
