RockStock Samba Member
Joined: November 26, 2004 Posts: 4221 Location: England
Posted: Thu Sep 29, 2022 11:33 am Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
[Top hole to side of seat - 35mm
That’s 30mm, EB 😉 _________________ -StockRocks- |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71580 Location: Phoenix 602
Highbody Samba Member
Joined: January 04, 2022 Posts: 6 Location: North east ct
Posted: Fri Sep 30, 2022 8:53 am Post subject: Re: Bus Rear / Back Seat information thread |
Thank you!!! This saves me a lot of issues! I feel like this question fit the thread well! |
willvision Samba Member
Posted: Tue Oct 04, 2022 5:39 am Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
Highbody wrote: |
flemcadiddlehopper wrote: |
Anyone have an idea of the distance the screws for the rear seat mounting brackets are from the top and side? I don’t want to cut a million holes |
Top hole to top of seat - 65mm
Top hole to side of seat - 30mm
Distance between 2 holes - 15mm
Hi all and thank you for this tread.
Is there a kind of plate behind these holes to screw the bracket in?
I have a 69 model but a late Bay rear bench i'm guseeing if i can't fix it to the original bracket.
Thanks,
Will |
Posted: Tue Oct 04, 2022 8:57 am Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
Yes, there are plates welded to the seat frame |
Wow awesome thank you!
I was searching the information everywehre, and the answer was here on thesamba.
Thank you guys
@EverettB: any chance to find this plate somewhere so i could weld it to the frame of my late backrest? Thanks. _________________ AirCooled MAGAZINE
www.facebook.com/aircooledmagazine/ |
John Ghia Samba Member
Posted: Sun Jul 02, 2023 2:44 pm Post subject: Re: Bus Rear / Back Seat information thread |
I’m looking for information about the edge protector on the top back of this seat.
I assume they come on Kombis & Standards
What year, all? When did they start?
Are Bay window edge protectors the same?
How long are they in mm?
Thanks _________________ BUS BOYZ |
Cam.goslin Samba Member
Posted: Tue Sep 05, 2023 9:41 am Post subject: Re: Bus Rear / Back Seat information thread |
What do I have here? Was told this seat is pre 63 but I am not sure..
Posted: Tue Sep 05, 2023 2:23 pm Post subject: Re: Bus Rear / Back Seat information thread |
It looks like a 56-57 Standard (Green/Green Bus) middle seat.
This color was used from 55-58 but 55 has a slightly different seat base and a '58 seat back would be curved instead of "flat"
I can't tell for sure in your photo so:
Is the seat back rest flat vs a '58 only curved seat, which would have a little bow in it.
1959-61 upholstery example that is NOT flat:
(Same seat design, just different color) _________________ How to Post Photos
Trevor P Samba Member
Joined: January 21, 2004 Posts: 894 Location: Saskatoon, SK, Canada
Posted: Tue Sep 05, 2023 6:26 pm Post subject: Re: Bus Rear / Back Seat information thread |
Cam.goslin wrote: |
If you're interested in selling I need a backrest for my 56 pgsg project. _________________ 53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
Posted: Wed Sep 06, 2023 6:16 pm Post subject: Re: Bus Rear / Back Seat information thread |
The back rest is flat. So this must be a 56-7 rear seat? |
Posted: Wed Sep 06, 2023 9:53 pm Post subject: Re: Bus Rear / Back Seat information thread |
Yes, although it would work and generally look correct for 1955 too.
It's just that 1955 has a slightly different seat base design, the center leg is more "sharp".
I think your seat bottom has a couple pipes added? (one seen in red paint)
Guess: They were probably added so that it would sit upright for people to sit on at some point, I've seen that done with middle seats in the past. _________________ How to Post Photos
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3856 Location: Twin Cities, MN
Posted: Mon May 27, 2024 6:52 pm Post subject: Re: Bus Rear / Back Seat information thread |
I have a split rear seat back that is 66 or 67 (is there a way to tell?) and I need to install the three luggage bar uprights. The pristine upholstery is already done and the upholstery shop did not mark where the uprights go.
What to do?
Does anyone have measurements they can provide of the screw locations?
I have the long luggage bar but I'm considering shortening it because the bus it's going into is a January 67 deluxe. However I think the seat is out of a 66 21 window.
How do I find these brackets under the board in the back?
Stocknazi Samba Member
Posted: Tue May 28, 2024 12:22 pm Post subject: |
olliehank47 wrote: |
kenshapiro2002 wrote: |
I'm confused...jail bars aside did we ever figure out if the '67 rear seat is in any way unique? Width? Mounting points? |
As I understand the discussion, the seat back and bottom are the same width as earlier seats. The luggage bar on the back of the deluxe seat, however, appears to be shorter on the 67 and the spacing of the bar uprights appears to be different as well. Mounting points are the same as earlier seats. |
The 66 seat will have the brackets for the uprights in a different position with shorter bar.
Since the upholstery is done, you are limited to using whatever type bar is correct for your seat back. _________________ WANTED:
Thomas Jefferson |
Posted: Sun Jul 07, 2024 10:53 am Post subject: Re: Bus Rear / Back Seat information thread |
Upright spacing, 1956 flat-back rear seat
Middle post is centred
They are 540mm spaced
So this is probably true up to the 66/67 shorter bar
Who can measure the upright spacing on a 66/67 rear seat? _________________ -StockRocks- |
Buskraut  Samba Member
Joined: March 22, 2011 Posts: 70 Location: San Jose, CA 95125
Posted: Sat Jun 21, 2025 10:30 pm Post subject: Re: Bus Rear / Back Seat information thread |
I'm installing my newly reupholstered rear seat into my '65 and can't figure out why I can't get the clamps to tighten the legs firmly to the floor. Stock seat frame, OG short rear clamps (no nubs), OG floor. Of course I could cheat and use a shim of some kind under the legs, but my understanding is the legs should be metal on metal on the floor. This is a 2-clamp seat, and both side have the same gap. What the heck am I missing?
_________________ Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK |
Posted: Sun Jun 22, 2025 7:35 am Post subject: Re: Bus Rear / Back Seat information thread |
You’re using middle seat clamps!
Rears are more shallow |
House Minutia Militia
Posted: Sun Jun 22, 2025 9:09 am Post subject: Re: Bus Rear / Back Seat information thread |
Buskraut wrote: |
OG short rear clamps |
Yes, double check this… |
Posted: Sun Jun 22, 2025 11:09 am Post subject: Re: Bus Rear / Back Seat information thread |
Those look like short rear seat clamps. This is a replacement floor correct?
Maybe the stamping or the mount is a little off?
This might actually be an advantage as you can add a couple pieces of inner tube/rubber/plastic under the legs to keep them from sitting directly on the floor. The bottoms of the legs don't age too well around these parts anyway. _________________ WANTED:
Thomas Jefferson |
Posted: Sun Jun 22, 2025 11:43 am Post subject: Re: Bus Rear / Back Seat information thread |
Thanks for everyone's help.... I figured it out. My bus came with a grab bag of mounts, and I (wrongly) assumed the short ones were for the rear. Turns out there are (at least) 2 different middle seat mounts, both of which are carried by CIP1 who tipped me off. The short ones I have are stamped 111881285.
For those looking to sort out their mounts (lengths are for the shoulder where the bolt goes through, not including the arch):
221885865A: ~15mm (don't have any to measure)
111881285: 21-23mm
221883865A: 26-28mm
CIP1 claims the 111... version was used on both bugs and busses, but I'm guessing it was only for bugs since it's a 111 prefix (yes, I know could also be for busses), but also not listed in the bus OACDP.
Stocknazi, its an OG floor, but great idea about adding a rubber strip under the legs rather than grinding down the clamps. _________________ Erik S
'03 Eurovan MVWK |
