Darthmjh Samba Member
Posted: Fri Oct 15, 2010 3:50 pm Post subject: 1960 Front Apron |
I have a February 1960 European convertible bug and during a previous restoration the front apron was changed for a later one. I am trying to put the correct one on. Every 1960 I look at has a 3 rib apron, but looking at another post on these forums someone suggested that an early 1960 would have a 4 rib apron the same as a 59.
Do you think that my bug should have a 4 rib apron as it was made in February?
Thanks for looking |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sat Oct 16, 2010 4:05 am Post subject: |
Mine is a January 1960
_________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Dud Samba Member
Posted: Sat Oct 16, 2010 4:58 am Post subject: Front apron |
My February 1960 is identical to the one in your picture |
Posted: Sat Oct 16, 2010 5:01 am Post subject: |
Thanks 58Dub and Dud
I noticed that the slot for the cable is thin unlike this one (pic taken from Samba ad) Its a lot bigger at one end.
This is the same as the pattern part I bought. I think I will re-profile slot to look the same as yours.
Many thanks for your help |
Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 1068 Location: Newbury Park, CA
Posted: Sat Oct 16, 2010 12:26 pm Post subject: |
Darthmjh wrote: |
I just pulled a early 60' apron off and it has the same thin profile slot for the cable:
_________________ - Chris
58' PGSG |
Posted: Sat Oct 16, 2010 12:36 pm Post subject: |
Thanks Chris
I have another question.
I have odd rear fenders. Unfortunately I have no pictures, but can only describe them. On one side, from the rear (from the rear apron) to the side the sweep/angle is very curved like a 45 degree angle whereas the other side is quite flat and then sweeps almost at a 90 degree angle. Which is correct for my year of car ?
I apologise if my description isn't great |
MANNAXMAN Samba Member
Posted: Sat Oct 16, 2010 1:35 pm Post subject: |
Darthmjh wrote: |
That's an aftermarket front apron. See this post by potentvw here, immediately followed by my post with pictures. Not only is the hole a different shape, but the stamping of the finger/rib pattern isn't as crisp. |
Posted: Sun Oct 17, 2010 1:30 am Post subject: |
Thanks MANNAXMAN |
Posted: Sun Oct 17, 2010 10:41 am Post subject: Re: Front apron |
Dud wrote: |
Hi Dud, PM sent. |
el_fela Samba Member
Joined: November 28, 2012 Posts: 32 Location: La Plata, Buenos Aires, Argentina
Posted: Fri Dec 12, 2014 6:38 am Post subject: |
Dude, I have 2 1960 cars (well, actually 2 car bodies). One is built on November 1959, chassis number 2781xxx and has 3 ribs:
The other I don't recall. I could take note of chassis numbers and take some pictures, if anyone is interested. I tend to forget this kind of stuff, so PM me if you don't hear from me soon !
Felipe |
jays58s Samba Member
Joined: August 23, 2004 Posts: 2166 Location: Nor-Cal
Posted: Sun Jan 23, 2022 8:22 pm Post subject: Re: 1960 Front Apron |
I have a 1960 that is chassis number 274**** and has a 4 finger front apron, and it only has 47,000 original miles. |
dasbulliwagen Samba Member
Joined: April 18, 2022 Posts: 9 Location: North Carolina
Posted: Thu Sep 28, 2023 4:20 pm Post subject: Re: 1960 Front Apron |
I recently cut the front apron off of my 1960, with vin 276****. It is a 4 finger, and I have no reason to believe it has been replaced, as it's a very clean car. Here's a pic.
