soulsurfer26 Samba Member
Joined: March 22, 2010 Posts: 24 Location: Netherlands
Posted: Tue Mar 28, 2023 2:08 pm Post subject: Frame number |
| Is there anyone that can shine a light on the use of the frame number on a chassis(not the vin...)? |
finster Samba Member
Joined: May 26, 2012 Posts: 10534 Location: not far from the madding crowd
Posted: Wed Mar 29, 2023 2:15 am Post subject: Re: Frame number |
I'm not sure what you're asking and the photo you posted yesterday isn't showing. the number on the frame tunnel should match the one on the vin plate. by 'use of the frame number' do you mean using it to register the car? _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1034 Location: belgium Caesars camp
Posted: Wed Mar 29, 2023 3:58 am Post subject: Re: Frame number |
On a vw..
The whole car is identified with the vin nr - Stamped on the tunnel and type plate and used to register the car itself on a licenseplate. The frame nr can been seen as the engine nr, front beam nr, gearbox nr, key nr and is to identify the part itself.. A NOS chassis has no VIN nr stamped but only a frame nr as that is used at VW to register it as a part. It is not used to register it as a car.
Frame nr is to be found on a split near the vin nr, 90° stamped in the tunnel or on the crossmeber left side rear of the pan. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
VWLady Crazy VW Lady
Joined: March 13, 2004 Posts: 3866 Location: Twin Cities, MN
Posted: Wed Mar 29, 2023 2:06 pm Post subject: Re: Frame number |
On my October 1949 the frame number was stamped perpendicular to the chassis number under the rear seat.
I've also seen them IIRC on the tunnel around the e-brake/shifter area. |
Posted: Thu Mar 30, 2023 1:12 pm Post subject: Re: Frame number |
| finster wrote: |
| I'm not sure what you're asking and the photo you posted yesterday isn't showing. the number on the frame tunnel should match the one on the vin plate. by 'use of the frame number' do you mean using it to register the car? |
I meant the extra number, not the vin  |
| peter schepens wrote: |
On a vw..
Frame nr is to be found on a split near the vin nr, 90° stamped in the tunnel or on the crossmeber left side rear of the pan. |
Thanks Peter, that helps! |
Posted: Thu Mar 30, 2023 1:13 pm Post subject: Re: Frame number |
| nlorntson wrote: |
That's the one I meant. thanks. |
Posted: Thu Mar 30, 2023 11:54 pm Post subject: Re: Frame number |
| soulsurfer26 wrote: |
On a vw..
Geen dank, graag gedaan  _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
sinclair Samba Member
Joined: July 01, 2004 Posts: 445 Location: New Forest UK
Posted: Fri Sep 29, 2023 3:31 am Post subject: Re: Frame number |
On a vw..
Is it possible to accurately date the chassis by this number? |
SplitPersonality Samba Member
Joined: September 26, 2004 Posts: 631 Location: Norway
Posted: Tue Oct 03, 2023 11:23 am Post subject: Re: Frame number |
The frame number was perpendicular to thw VIN until end of 1949. Then it moved to the front face of the left, rear, triangular outrigger on the pan.
This number can be used to date the floorpan just like we date engines, transmissions and front suspensions. |
Posted: Tue Oct 03, 2023 11:33 am Post subject: Re: Frame number |
| SplitPersonality wrote: |
thanks. When you say pre end of 49, does that include KDF or is it 45 onward? |
