intermittent no start - (was rapid turning over once)
atomatom
atomatom is offline
PostPosted: Wed Nov 15, 2023 9:54 pm    Post subject: intermittent no start - (was rapid turning over once) Reply with quote
so, today i did a dump run in the van. all went well in the dumping part, stuff begone. however, when i went to leave, with encroaching seagulls, van did not spring back into life.
what happened instead was a rather strange rapid turning over. as if there was no compression. not a slow laboured churn, but a rapid, bip bip bip.
seagulls encroached. a staff member mentioned 'this happens regularly'. and i cried, 'this van is not ready for the dump'.
after 10 minutes of personal contemplation and a few tries, the van caught, and i drove away. seagulls were more interested in whatever muck was on the floor than me or the van.
but i'm now wondering what the heck that was all about.
i did change the oil a few days ago. checked level, around 1/2 full as per. maybe i have a stuck valve? i guess i'll do a compression test. van drove me home, some highway bits at 100kmh, reasonable power.
1.9wbx, as in my sig.
84 Vanagon Westy, 1.9L, California raised but defected to Canada.
harvgwen
harvgwen is offline
PostPosted: Wed Nov 15, 2023 10:40 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
Was it just the starter spinning quickly, and not the engine at all? If so perhaps a new starter?
1986 Westfalia Vanagon, 2.2 Subaru
Okanagan Valley, British Columbia
atomatom
atomatom is offline
PostPosted: Wed Nov 15, 2023 11:09 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
hmm, good question. it was quite loud in there, so i'm not sure, but maybe that was it. it sounded like more than just a whir though, more like bip bip bip than jug jug jug, if that makes any sense.
Abscate
Abscate is offline
PostPosted: Thu Nov 16, 2023 3:45 am    Post subject: Re: strange no start - rapid turning over Reply with quote
I didn’t think it happened with a Boxer engines but if you flood an engine you can lose compression from loss of ring sealing. See Thanksgiving syndrome or lawnmower syndrome ( bmws, Volvo, VAG water cooled products)
I thought it was a legend until it happened to me in an E83
atomatom
atomatom is offline
PostPosted: Thu Nov 16, 2023 7:11 am    Post subject: Re: strange no start - rapid turning over Reply with quote
https://www.brickboard.com/AWD/volvo/1381779/S70/easy_fix_lawn_mower_syndrome.html
plausible i suppose, although i drove it for 15-20 minutes on the highway before arriving at the dump, but perhaps my injectors are leaking. engine was certainly hot when shut down.
i'll check injectors and compression on the weekend. maybe something is still wrong and gives some clues. or maybe it was just dump gremlins.
hardway
hardway is offline
PostPosted: Thu Nov 16, 2023 2:00 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
I have seen dozens of engines lose compression. They used to say that they were "washed down". Observing this compression loss has caused automotive engine theorists to modify their theory of how compression rings work. The current theory is that the rings must float freely in the ring land. On the compression stroke the piston moves up and the ring due to inertia and the air pressure above the ring is forced to the bottom of the land. The increased gas pressure then gets between the ring and piston and forces the ring outward against the cylinder wall.
If for whatever reason the gas pressure does not force the ring outwards then the gas pressure can push the ring in towards the piston and gas can escape the combustion chamber between the ring and cylinder wall.
Engine oil helps the initial sealing of the ring. The theory is that excess fuel dilutes the oil and allows the gas to bypass the ring and not push it outwards. Once the engine has been cranked and fuel delivered without the ring sealing it gets worse. The engine is flooded.
Newer engine types with low tension rings are more likely to have this happen. I have only seen this happen on an engine that was being started when cold. But that does not mean that it can only happen on a cold start. Overfueling could exacerbate this problem.
As I said I have seen this many times. To get the engine to start I have induced vacuum leaks, shut off fuel delivery or held the throttle open. Holding the throttle open is the traditional method of clearing a flood. That is why the software engineers use it as a "clear flood " command.
In extreme cases I clean and heat the spark plugs with a propane torch and put oil in through the spark plug hole to seal the rings.
harvgwen
harvgwen is offline
PostPosted: Thu Nov 16, 2023 3:30 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
Doesn’t it seem odd that this has never happened before, but suddenly, one time it happened presumably on several cylinders at the same time? (It seems for the engine to rotate quickly, most or all of the cylinders would have lost compression). I’m still suspicious that the starter never actually engaged the engine. I’m looking forward to finding out the eventual outcome.
djkeev
djkeev is offline
There are ignition parts that fail when hot.
Coil is #1
Hall pickup is right behind it.
I've experienced both.
Ghia
Vanagon
Beetle
atomatom
atomatom is offline
PostPosted: Thu Nov 16, 2023 4:24 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
thanks folks.
some more clues; had a 99% successful road trip this summer in +30C (100F+) temps. heat soaked engine acted up after waiting at a construction stop sign leaving princeton, bc. the symptom there was a loss of power - maybe the same as this time? it was very intermittent, as if running out of fuel, but van kept on going, just scared the whole family. when i got home, i swapped in a spare coil. intermittent problem gone - but who knows. maybe this is the same thing.
you may well be right djkeev, that i still have more dying electronics to replace and it wasn't the coil after all. i have a complete spare engine, so maybe i'll look at swapping the hall sensor - not sure that is so easy - i will go check your saga for ideas. https://www.thesamba.com/vw/forum/viewtopic.php?p=10088796#10088796
however, despite all of the possible electrical woes above, it really felt like the engine was spinning awfully quickly during this extended dump stop - rather than just not firing. i'm going to check timing, valves, fuel injectors, and so on this weekend.
harvgwen - i agree, odd. however, even if it was just one cylinder, that would reduce the effort by 1/4 - would not need to be all.
atomatom
atomatom is offline
PostPosted: Sun Jan 21, 2024 4:29 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
this is still plaguing me. van starts fine when cold. when hot, sometimes starts, sometimes not.
i just replaced the o2 sensor today, thinking maybe it was fouled from my over filling oil. i think it probably was, but i think this was just a cause of running rough rather than no start.
while testing today, i drove to get the van warmed up, then stopped on a hill. tried to start, failed. bump start, no problem. and the idle is fine after bumping! i did this three times in a row with a few minutes apart - same situation.
i bought a cheap-ish new coil replacement from rockauto. however, i have not installed it. i'm not convinced it is the coil either (i already swapped a used one i had), but i might try that next. i don't have a new hall sensor, but i could try looking at that next. however - given the van runs fine after a bump, would this really make a difference?
is there anything else i can do to make it right from my oil overfilling - or maybe that was a coincidence to these woes.
van smells like fuel when it won't start, so i don't think it is the pump. that leaves air or spark, right? should i pull the air box off and see if there is oil in the intakes or something?
i'm stumped and annoyed because i can't really use my van like this. i live on an island and there is no greater sin than being a stalled car on the ferry.
atomatom
atomatom is offline
PostPosted: Sun Jan 21, 2024 4:30 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
also, starter motor is spinning engine, not weak, etc
atomatom
atomatom is offline
PostPosted: Wed Jan 24, 2024 1:10 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
finally got a chance to go fix it today as i had a trip to the city yesterday (in the bulletproof 2004 ford focus). i picked up a battery booster, as i had drained the battery in my desperation the previous day.
so, cool head, get the booster out, but think i'll have a look in the engine bay just in case. newly done work - replace the coil - so, check the coil. there it is. and what, this small wire on the top, unplugged. bah! plug it in, and vroom vroom. if only all of life's fixes were this. shockingly, i would say quite a few of my van ones are like this.
i guess the replacement coil connector isn't exactly the same size as the OEM one. i'll probably cut the connector and find one that fits on more securely. the current one has a large plastic housing making it harder to push on tightly.
anyway, life is good again. however, i am yet to see if my intermittent wont-start is cured. part of me was happy it didn't start at all, so i could figure out what was dead, but this was installation error.
atomatom
atomatom is offline
PostPosted: Wed Jan 24, 2024 4:56 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
a few more test drives and things seem much better.
as part of the coil replacement, i put new spark plug wires in. i guess the last set was 10 years old. i have a new rotor cap but didn't put that on yet.
no sign of the no-start symptom yet. so, maybe it was the coil dying. time will tell.
E1
E1 is online now
PostPosted: Wed Jan 24, 2024 5:31 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
I can’t speak to the “why” details, but this sounds like a solenoid/Bendix issue… often caused or simulated by poor cold cranking amps on the battery.
Typically, the fast crank is because the flywheel’s not being engaged to spin properly, from either thing above.
Go to a parts store and have a load test done on the battery, if only to discount that and know it’s in spec or within maybe 10% of it. It’s not a voltage question of the battery, but one of the battery’s labeled CCA (cold cranking amps) not being met (likely by a significant amount).
By your description, I seriously doubt it’s a major engine concern.
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
Wildthings
Wildthings is online now
PostPosted: Wed Jan 24, 2024 7:33 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
You can typically use vise grips to tighten a female spade even if it is totally covered in plastic. Start with the vise grips adjusted so they put no pressure on the sides of the female spade and then using repeated testing slowly tighten the adjusting screw on the vise grips. Done correctly as some point the female spade will have just the right amount of grip on the male spade.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Jan 25, 2024 10:19 am    Post subject: Re: strange no start - rapid turning over Reply with quote
Nice find on the fault.
Suggestion: keep the old plug wires if they Ohm out ok. New parts quality is not great, sometimes.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
atomatom
atomatom is offline
PostPosted: Thu Jan 25, 2024 10:47 am    Post subject: Re: strange no start - rapid turning over Reply with quote
E1 - i did suspect the starter, but aside from my first incident, it seems like it is actually turning the engine over. i've been too chicken to turn the ignition with clutch/gears engaged in case it breaks the starter teeth. however, i have pulled the engine lid off and it sounds like it is turning over. the original situation in the dump was strange and i was kind of panicking so i didn't pull the lid off then. i just sat and tried again after a few minutes.
wildthings - thanks, and yes, probably better to tighten up the existing connector. i found that it actually sits better on the coil if i placed it on the other tab (the top connectors on the coil, my van only uses one of them; the plastic connector has slots for two, but one is unused).
(not my coil, but this is how the connector (green wire) is now attached and it seems way more snug, which is counterintuitive)
neil; i seldom throw anything out, but i really should! i will try a multimeter test and chuck them if they are obviously bad. i measured coil resistance but not the wires. nothing was conclusive there, but the new coil was about $60 and both the used ones i have on hand were around 40 years old. (of course, i'll keep the old ones! but maybe write BAD? on them Very Happy )
to recap:
* had an intermittent ignition problem, since the summer, but it was very intermittent.
* replaced coil with other used part (unknown quality)
* overfilled the oil, which i think fouled the o2 sensor
* drained 500ml or so of oil
* no start symptom remained, with van starting after sitting a while. seemed random as to when this happened, sometimes it was fine.
* replaced o2 sensor, thinking it had been fouled with oil (i can post a pic, but not sure if it is obvious)
* replaced coil with new one and spark plug wires. i heard you are supposed to do both as a bad coil can damage the wires.
* limited testing so far, but seems to run smoother in any case.
so, like most van problems, there was a bunch of things wrong, vanagon comorbidity, but hopefully addressing each of these in turn has routed out the gremlins, for now.
Vanagon Nut
PostPosted: Thu Jan 25, 2024 10:58 am    Post subject: Re: strange no start - rapid turning over Reply with quote
I *think* the second open spot on white connector to coil is for a wire to tach (?). If so, and no tach installed.....
If one wanted redundancy, install another "locking" terminal in white housing, connect that to the single green wire? A bit of a "fussy" idea though.
Rhetorical thought: does either nut holding male spade connectors to coil ever come loose?
Neil.
(VW Gas I4)
VE7TBN
Wildthings
PostPosted: Thu Jan 25, 2024 11:29 am    Post subject: Re: strange no start - rapid turning over Reply with quote
With that heavy of a plastic insulator around the wire terminal, it would be hard to get to the female spade to pinch it a bit. The plastic is not all that hard to remove from the terminal. I typically just use something like a jewelers screw driver to disengage the tab, but you can buy a set of special tools for this purpose, maybe Harbor Freight has a set??? They can surely be had easily enough on line.
E1
E1 is online now
PostPosted: Thu Jan 25, 2024 1:33 pm    Post subject: Re: strange no start - rapid turning over Reply with quote
The fast-crank you described is something I’ve never seen over 100,000+ miles as a daily driver.
Just because it hasn’t happened since doesn’t mean that’s fixed. That part of your case has no bearing on the parts you’ve replaced.
