Tee Dub Samba Member
Joined: June 02, 2005 Posts: 144 Location: Probably in the shop,but maybe takin' a nap...
Posted: Wed Sep 07, 2005 7:06 am Post subject: Unusual Rear Suspension ? / Need Help |
| My project car is a '56. PO's were building a race car and installed a '61 transmission with what looks like Porsche 356 C disc brakes all around. The bottom rear shock support goes out to the rear of the axle instead of the front and I can't visualize how to get a shock on there. Anyone here have any ideas or seen this setup ? |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3913 Location: Eastern WA
Posted: Wed Sep 07, 2005 8:29 am Post subject: unusual rear suspension / need help |
Swap axle tubes from one side to the other . The 356 either has a different upper shock location , or they are installed backwards . If you haven't bent the metal brake lines you might switch the brakes to the other side as well (put the caliper to the rear of wheel , not front as it is now) TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed Sep 07, 2005 9:24 am Post subject: |
Hi Troy ! Thanx for your interest in my problem. Swapping the tubes was my first inclination. I haven't taken them apart yet, but just visualizing it, it seems that the trio of bolts at the spring plates would no longer line up ?
I too thought the calipers should be at the rear. I hope I can find a way to use this setup. Do you think I should use a dual circuit master cylinder ? Do you know which application ? |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
74Standard Samba Member
Joined: March 25, 2005 Posts: 317 Location: San Antonio
Posted: Wed Sep 07, 2005 12:35 pm Post subject: |
| Tee Dubber wrote: |
| Hi Troy ! Thanx for your interest in my problem. Swapping the tubes was my first inclination. I haven't taken them apart yet, but just visualizing it, it seems that the trio of bolts at the spring plates would no longer line up ? |
Aren't the trio bolts symetrical? I mean it looks like if you just take the bolts out and rotate the whole assembly you should be able to get it to line up... Could be wrong, never put one in wrong just to see if it would line up.  |
Posted: Wed Sep 07, 2005 3:42 pm Post subject: |
I dunno '74...... seems to me if I reverse the tubes, that third bolt would be hanging way out the rear alone non ?
Thanx for the lead Meanirish ! |
Posted: Wed Sep 07, 2005 3:58 pm Post subject: |
| Tee Dubber wrote: |
I didn't say reverse them, I think that was what Teeroy was talking about doing. I said rotate them, take the bolts out, and just rotate the mount towards the front of the pan. The holes should still line up.
Maybe I'm looking at the picture wrong, but that's what it looks like to me. Also, you should be able to rotate the caliper mounts to the rear the same way. Those holes are symetrical also. |
Posted: Wed Sep 07, 2005 4:03 pm Post subject: |
| Thanx for sticking with me on this '74, I'll take a closer looksee..... |
Posted: Wed Sep 07, 2005 4:36 pm Post subject: |
Anyone know a guy named Donny Reade ? I hear he used to work for Ralph Meaney VW Repair Shop in Framingham, MA around 1980.
I just got word he is the guy who put this rear end together........ sure would like to hear from him what he had planned. His workmanship is excellent ! |
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Thu Sep 08, 2005 1:22 am Post subject: |
you are correct that those are 356C rear brakes and axle tubes, YES the porsche parts are a direct "bolt on" to a swing axle beetle! since 356's have the shock mounted to the rear of the axle you cannot "bolt"
shocks directly in a beetle when using this setup...BUT you can fabricate brackets to replicate the stock type beetle shock mounts then sandwich/bolt them in place using the 3 12mm springplate bolts ! .. you can cut off the un-needed porsche hangers ..or just leave them in place as they wont really be in the way. just remember, IF you decide to cut the no longer needed 356 shock hangers off of your axle tubes you will be making them useless to any potential 356 owner ..IF you ever decide to sell them! 356C brakes are pretty desireable and valuble(porsche guys often use them to "upgrade" earlier drum brake 356 cars) _________________ DON'T SHIT WHERE YOU EAT! |
Teeroy  Samba Member
Posted: Thu Sep 08, 2005 9:47 am Post subject: unusual rear suspension need help |
Looking at the pics again and reading everones posts , the holes won't line up swaping sides or twisting the tubes (sorry brain fart). If the brake brackets will bolt to beetle tubes fine , you could go that route or build some upper shock mounts like Cameron said . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Thu Sep 08, 2005 10:54 am Post subject: |
Hi Teeroy....... I agree that swapping and twisting won't work, but what I got from reading Camerod's post is the fabbed bracket would be the Bottom mount, not the top ....... ie: Use the top stock VW mount that's there and Fab a new bottom mount that goes out towards the front like stock, to replicate what's missing. This would allow you to cut off the 356 bottom mount going to the rear if you had a mind ( or no mind ) to do so. ( NOT recommended ) |
camerod Volksfab
Posted: Thu Sep 08, 2005 11:35 am Post subject: |
| Tee Dubber wrote: |
..you got it!
troy, the caliper brackets are cast into the bearing housing so you unfortunatelly cannot bolt them to the beetle tubes.. _________________ DON'T SHIT WHERE YOU EAT! |
Teeroy  Samba Member
Posted: Thu Sep 08, 2005 3:21 pm Post subject: unusual rear suspension need help |
Wasn't sure , the only 356 tubes I have had were drum brake . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Thu Sep 08, 2005 4:40 pm Post subject: |
Camerod, thanx for coming to the rescue with the right answers ! At the risk of of asking too much of your time, what have you got for ideas for said fabrication with support and asthetics in mind ? I don't have the skills for the job, but would like to bring some ideas to the welder....... I do have a stock rear end at hand, can some of that be used ?
For those interested, from another site, here's what a stock 356 C set up looks like.
Posted: Fri Sep 09, 2005 4:01 pm Post subject: |
| Hey....... Just a note to tell everyone THANK YOU for your help and ideas, before this thread dies and is forgotten |
