SGKent  Samba Member
Joined: October 30, 2007 Posts: 42935 Location: at the beach in Northern Wokistan
Posted: Wed Dec 13, 2023 12:09 am Post subject: That damned late bay Oil drain - strainer nut |
Since we have a plethora of new late bay VW owners suddenly making posts - it is time to warn y'all that you never tighten the oil strainer nut more than 9ft lbs if you take it off or a real expensive disaster will occur involving a complete teardown of your motor. DRILL that into your memory now.
This one circled in red:
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
RWK Samba Member
Posted: Wed Dec 13, 2023 5:47 am Post subject: Re: That damned late bay Oil drain - strainer nut |
Always use oil drain plug to change oil, never remove strainer is the rule I would use. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Wed Dec 13, 2023 9:10 am Post subject: Re: That damned late bay Oil drain - strainer nut |
| RWK wrote: |
| Always use oil drain plug to change oil, never remove strainer is the rule I would use. |
I believe in cleaning the strainer every 100-150K miles when I reseal the engine. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Wed Dec 13, 2023 12:25 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
maybe if someone could mfg a nut that didn't have such a big hex portion.
even if it's round you can get 9ft lbs on it with a pair of water pump pliers. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36316 Location: Conejo Valley, CA
Posted: Wed Dec 13, 2023 12:49 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
As a reminder to you and others, maybe impact stamp a big "9" or "9 lb.ft." on the head? Paint it bright red maybe?
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1574 Location: Westfield, MA.
Posted: Wed Dec 13, 2023 2:35 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
| SGKent wrote: |
Was it Ray G that came up with the mod to help avoid this issue? I was thinking of doing the same when I rebuild... but then again I know better than to use 200 ft lbs on the damn thing so  |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 2061 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Wed Dec 13, 2023 3:40 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
| Wildthings wrote: |
| RWK wrote: |
isn't that damn close to never?
and, what's "reseal the engine?"
i've never done that, and can't wait to try. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2260 Location: Vancouver, BC
Posted: Wed Dec 13, 2023 3:59 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
I don't think I've ever come across anyone in the last 40 years who has actually overtightened their strainer nut and had a problem.
This is a similar to the warning not to start your engine without oil in it.
I think that these are old wives tales but I'm sure we will now hear the stories of my brother's sister's friend's brother who did one or the other. _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
timvw7476 Samba Member
Posted: Wed Dec 13, 2023 4:22 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
I cleaned the strainer every 3k on my first bus.
Then this one time I found -0- stuff in there & noticed the spin-on oil filter & asked myself wTf I was doing & gave that bad habit up.
Unless it's a New-To-You bus just clean it once & leave it alone.
......Like that Seinfeld episode where Costanza double-dips a chip....bad form.
SGKent  Samba Member
Posted: Wed Dec 13, 2023 4:27 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
| Shonandb wrote: |
I think that these are old wives tales but I'm sure we will now hear the stories of my brother's sister's friend's brother who did one or the other. |
The error and damage is so common that there is a name for it - Type IV syndrome. The issue is that anyone who owned a type 1 engine VW got in the habit of changing the oil thru the strainer. Along comes a TIV engine and they do the same and hand tighten it. That is enough to break it. Very common problem - and expensive mistake. That is why we remind people about it. _________________
George Carlin:
Posted: Wed Dec 13, 2023 6:30 pm Post subject: Re: That damned late bay Oil drain - strainer nut |
I do in fact know a fella who broke his case, as he came to me for a replacement to rebuild
it not only can, but does happen.
| Shonandb wrote: |
| Abscate wrote: |
