Drilling a 36hp crank and flywheel for 8 dowels
esde
esde is offline
PostPosted: Tue Dec 05, 2023 6:29 am    Post subject: Drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I have a stock 36hp crank which I would like to convert to 8 dowels. My understanding is that the 8 dowel pattern used on 356 Porsche is the upgrade. I'm looking all over for a drill jig for this pattern but not finding anything, does one exist and could anyone provide a link? The ones for the later 8mm dowel pattern are plentiful but will not work
If needed I may use a 356 flywheel to make my own jig, but I'd rather just buy the jig and spend my time elsewhere..
Many thanks. SD
modok wrote:
56samba
56samba is offline
PostPosted: Wed Dec 06, 2023 1:49 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I was in the same situation recently during the restoration of my Okrasa engine and couldn't find a drill jig.
Using a 356 flywheel as a jig worked surprisingly well. Subsequent reaming of the holes is recommended.
Robert Chambers
Robert Chambers is offline
PostPosted: Wed Dec 06, 2023 10:07 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
How about using a 356 or 912 metal flywheel gasket as a pattern?
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
esde
esde is offline
PostPosted: Wed Dec 06, 2023 3:54 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Probably not as accurate/ easy as I would like. It's a lot more work to find the center of a hole in the gasket than the actual flywheel. I may use a flywheel, and get some 6mmx8mm bushings. This way I can drill through the flywheel with a 6mm pilot. Then remove the flywheel and bushings, drill to the final size and ream.
modok wrote:
Robert Chambers
PostPosted: Wed Dec 06, 2023 5:27 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I have the flywheel. You can use it if needed. I plan to do the same thing to my crankshaft.
'63 OG 117
IN2VWS
IN2VWS is offline
PostPosted: Sun Mar 03, 2024 12:18 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
TomSimon
TomSimon is offline
PostPosted: Sun Mar 03, 2024 2:24 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Very nice! Replaceable hardened drill bushings, a piece of professional tooling. And that patina!
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
esde
esde is offline
PostPosted: Sun Mar 03, 2024 4:46 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
IN2VWS wrote:
Amazing.
So, it has a VW number. Did any VW have an 8 dowel crankshaft from the factory? I'm wondering what the factory made the tool for?
Is one of the pins offset? Maybe it was to repair a crankshaft that had damaged holes?
modok wrote:
RolandD
RolandD is offline
PostPosted: Mon Mar 04, 2024 7:50 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
There is a description here:
https://www.thesamba.com/vw/archives/manuals/tools/231a-b_1.jpg
Roland
Braukuche
Braukuche is offline
PostPosted: Tue Mar 05, 2024 8:59 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
There’s no need to eight dowl it unless you are building an engine capable of running the same high RPMs as a Porsche 356. In that case why wouldn’t you buy a 69.5 stroker crank that’s already eight dowled?
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
esde
esde is offline
PostPosted: Tue Mar 05, 2024 3:03 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
That's not really accurate.
Drag race starts and hard shift are what usually oval out the dowel holes, but cars that are driven hard are well known to do it also. Especially. cars that are driven with a lot of downshifting/ compression braking. The 4 little 6mm pins are barely adequate for 36hp.
Of course at hight rpm, there is more mass (30lbs of flywheel and clutch assembly!) and that inertia is more likely to kill the pins, but it does happen even on stock street driven cars.
modok wrote:
Iowa Mark
Iowa Mark is offline
PostPosted: Tue Mar 05, 2024 5:48 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I have to agree. Way back in 1968 my 1957 stock bug spun the flywheel. I was just your typical teen-age boy driving up and down Grand Ave on a friday night. No, honestly!
RWK
RWK is offline
PostPosted: Wed Mar 06, 2024 7:41 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Could you drill the 4-6mm pins to 8mm? PM me, I could possibly build a drill jig, do you know the bolt circle, or radius from center, or pin center to center?
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
esde
esde is offline
PostPosted: Mon Mar 11, 2024 5:50 am    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
To jump from 6 to 8mm, there would be .5mm between the dowels and the inside/ outside edges of the crankshaft, probably not enough material. To oversize the existing pins, you could use 1/4" (6.32mm), 7mm, or 9/32 (7.14mm)
I have started to make a jig, based on the pattern that DPR uses. If it works well, I will share the details.
modok wrote:
RolandD
RolandD is offline
PostPosted: Mon Mar 11, 2024 6:09 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Please do share the geometry details.
Roland
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Tue May 21, 2024 6:35 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Don't know if these are for 36hp but here are some for sale 👇👇👇
https://www.thesamba.com/vw/classifieds/detail.php?id=2685161
RWK
RWK is offline
PostPosted: Fri May 24, 2024 7:45 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
I have the 231b I believe it is for the 36, it has a bolt hole radius of 19mm, 6mm drill bushings, someone got a crank to measure? I don't!
The add says those are 231c and I see it has 8mm drill bushings, they are probably for larger 40 and up which is a 20.5mm hole radius, so measuring would be prudent.
I'll post pics of mine at some point, one of which has PN covered in patina Sad
73 Type 181
63 Type 113
RWK
RWK is offline
PostPosted: Sun May 26, 2024 5:59 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
Drill jig I picked up at swap, 6mm holes on a 19mm radius, 36HP Question 4 each drill bushings, for hole size (5.75mm) and follow up 6mm reamer, and jig for flywheel and crank.
Liners are 10mm ID, switch bushings around for each operation drill and ream, little handles make it easy, unlike production style jigs.
73 Type 181
63 Type 113
RolandD
RolandD is offline
PostPosted: Mon Dec 02, 2024 5:06 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
On a damaged flywheel, I was able to measure and confirm the 19mm radius of the bolt circle. The offset pin measured very close to a 5 degree shift.
Can anyone confirm or discredit these numbers before I make a drill fixture?
Roland
dangerous
dangerous is offline
PostPosted: Sat Jan 11, 2025 3:41 pm    Post subject: Re: drilling a 36hp crank and flywheel for 8 dowels Reply with quote
This is what I found and matched a VW crank to an aftermarket flywheel. I used a 38PCD (19 radius as you said) and one dowel is off-set 5 degrees.
