1954 & 1955 engines whats not correct!
Page: Previous  1, 2, 3 ... 30, 31, 32
RockStock
RockStock is offline
PostPosted: Thu Dec 21, 2023 12:15 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
^Thanks. Appears unstamped
VW logo on oil filler seal
14mm Kamax on the generator strap
I have a Verbus bolt on a second strap I have, off a slightly earlier engine
-StockRocks-
RockStock
PostPosted: Thu Dec 21, 2023 12:18 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
Two holed Bosch TE6A3 coil brackets
The left bracket has two holes to the rear too
-StockRocks-
RockStock
PostPosted: Thu Jan 04, 2024 2:41 pm    Post subject: Feb 55 Bus Engine Build Reply with quote
-StockRocks-
RockStock
PostPosted: Tue Jan 30, 2024 11:47 am    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
-StockRocks-
RockStock
PostPosted: Mon Mar 18, 2024 12:08 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
Setting the points on a 54 Oval
Good picture for detail
Is that a radio suppressor (silver cylinder) to the right of the regulator?
-StockRocks-
PostPosted: Mon Mar 18, 2024 9:17 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
I believe so but it's larger than most I've seen in the past
bavarian1
bavarian1 is offline
PostPosted: Fri Apr 05, 2024 1:25 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
Cleaning up a '54 motor I had sitting and while glassing the tin noticed that the 3 and 4 cylinder top tins had been double stamped? Maybe a mixup at the stamp machine?
'58 Beetle - L245 Bronze
'73 Vert SB - Dove Grey
'74 Sedan SB - Tropical Green
'72 Bay Panel - Pastel White
PostPosted: Fri Apr 05, 2024 5:58 pm    Post subject: Re: 1954 & 1955 engines whats not correct! Reply with quote
Weird but very cool.
I guess they had the numbers backwards?
Page 32 of 32
