Automatic Transmission, RPM vs MPH
djkeev
djkeev is offline
PostPosted: Sat Mar 23, 2024 9:58 am    Post subject: Automatic Transmission, RPM vs MPH Reply with quote
I just rebuilt my automatic transmission.
It all seems to be working well except the RPM's seem high for the MPH.
I'm talking flat surface and calm winds just keep rolling at a given speed.
At 55 mph I'm spinning at 3500 rpm
At 60 mph 3700 rpm
At 65 mph 3900 rpm
I was freaked out by this so was asking dbaron what he is running on his 2.1 Automatic.
His response is quite similar, almost exactly the same.
That got me to wondering about what others are seeing.
Steven then asked a great question about tire size ..... that will affect the results.
I'm running 195 R 14s
Steven is running 215 R14's
Then I was googling any reference information and I ended up on Kam,s old blue site.
I found a chart about rpm and speed.
I found it unsettling that the rpms on her chart are significantly less than we are seeing
Forgive me Kam but I shamelessly stole your chart.
You have the powers to edit it away or properly insert it with proper credit given......
your site is the only place that I've seen it.........
I will need to take a ride and check my 50 mph rpm's.
Anyway, please post your cruising speeds, rpm at each speed and tire size.
50
55
60
65
70 or faster if you are so inclined....... I'm not.
If you know Transmission code that you have, that would be awesome!
Thanks!
Ghia
Vanagon
Beetle
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 23, 2024 10:32 am    Post subject: Re: Automatic RPM vs MPH Reply with quote
i'm about 4200 at 75 but I have a tall tire in the rear 225/60/17
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
jimf909
jimf909 is offline
PostPosted: Sat Mar 23, 2024 11:46 am    Post subject: Re: Automatic RPM vs MPH Reply with quote
Won't you also need to know the diff ratio? There are at least three, er, four ratios available.
https://countryhomescampers.com/product-category/replacement-parts/transmissions/
- Jim
Butcher wrote:
Guilty as charged.
MarkWard
MarkWard is offline
PostPosted: Sat Mar 23, 2024 11:53 am    Post subject: Re: Automatic RPM vs MPH Reply with quote
Assuming stock ring and pinion and tire, I’d expect to be able to get near redline in drive on the flat, no headwind probably around 80 mph. Don’t have the specific detail you are looking for.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 23, 2024 12:50 pm    Post subject: Re: Automatic RPM vs MPH Reply with quote
correct. I have a stock setup and ran the taller tire as the trans builder had issues with the aftermarket R+P
Jake Raby wrote:
Brian wrote:
Red Ryder
Red Ryder is offline
PostPosted: Sat Mar 23, 2024 2:38 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
Dave,
Our rpm vs mph readings are very similar with 205/70r14 tires on stock alloys. Sounds fine to me.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
djkeev
djkeev is offline
PostPosted: Sat Mar 23, 2024 3:13 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
Red Ryder wrote:
Dave,
Good to hear!
Thanks!
I've most often had Golden Retrievers.
They start life as ambitious curious puppies that fear nothing and get into EVERYTHING!
As they age they get more and more worried and fearful.
By the time our last one was 14 years old the list of his irrational fears was arms length long.
I see myself following this route where as I age, I worry more about things that really don't need worrying about.........
Ghia
Vanagon
Beetle
zerotofifty
zerotofifty is offline
PostPosted: Sat Mar 23, 2024 3:24 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
your old tranny may have had dirt in it causing it to slip less???? Also maybe the clutches in the new one need to bed in, thus they is slipping more now, I dont know nothing about the van automatic tranny however, I only have dealt with an automatic in a Jeep, an AW4 type. My Van is a stick shift tranny.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
kamzcab86
kamzcab86 is offline
PostPosted: Sat Mar 23, 2024 3:49 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
A) I used the calculator that was listed as a source in that document. Online calculators automatically use a standard 0.7 ratio for an auto trans, which I didn't know until now.
B) I used 25.6" for tire diameter, which is slightly off from the 25.3" it should be.
C) Online calculators do not factor in the torque converter. According to Roadkill Garage, a torque converter can add anywhere from 3 to 12%, depending on condition.
D) I've now redone those tables using Excel for a more accurate calculation, based on each transmission's stock final drive, the revised stock tire diameter and adding 3% for torque converter (manual trans section also updated).
Those figures should be more in line with the VW transmissions in stock form. Those figures, obviously, do NOT take into account road conditions, tire condition, tire tread, weather condition, vehicle weight, and so on. The tables are based on mathematical calculations of when the vans were new, NOT an average of what drivers are seeing 30+ years later, after hundreds of thousands of miles, after untold rebuilds, after modifications, after installing larger tires, with worn out gauges (or reassembled), etc. In other words, math is being used to get set parameters, instead of using multiple variables resulting in multiple parameters.
To answer your question, my 1990 Westfalia with rebuilt (in 2008) transmission and 205/65-15 Cooper Discoverer tires, which have a diameter of roughly 25.5":
68-70 mph = 3850-4000 rpm
^That's using GPS for speed & the tach has never been taken apart. Note that RPM is basically in line with the revised table. Who knows what it was reading back in 2008 after its rebuild (didn't buy the van until 2010).
~Kamz Anxious
2016 Golf GTI S
djkeev
djkeev is offline
PostPosted: Sat Mar 23, 2024 5:15 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
Thans for your mathematical numbers Kam.
While they do not make me feel better, your real life numbers do.
I'm beginning to see that if you want to travel @ 65-70 mph..... you are going to be spinning close to or a tad over 4000 rpm's with an automatic transmission.
Ghia
Vanagon
Beetle
kamzcab86
PostPosted: Sun Mar 24, 2024 12:21 am    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
That's the name of the VW game until more modern times... including the manual transmissions. A common question in the Cabriolet world, particularly new owners who have never owned an old VW: "On the highway, is xxxx RPM at xx MPH correct, or is my trans about to blow up?" Yep, normal.
~Kamz Anxious
2016 Golf GTI S
AceTaylor
AceTaylor is offline
PostPosted: Sun Mar 24, 2024 5:10 am    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
I don't know if it is coincidence, or there's a mechanical reason for it, but my 4 cyliner bus runs about 4000 rpm +/- at 70 mph. My 6 cylinder car runs about 3000 rpm +/- at 70 mph and my 8 cylinder car runs about 2000 rpm +/- at 70 mph. Do the math and it works out to be about the same piston pulses (power strokes)
AndyBees
AndyBees is offline
PostPosted: Sun Mar 24, 2024 8:49 am    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
Subscribed for good reading...
Not an automatic, but my 215/75/15 tires drop the RPMs by about 150 vs the OE size tires.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
Wildthings
Wildthings is offline
PostPosted: Sun Mar 24, 2024 9:01 am    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
In stock form for a US model you should see about 4000 rpm at 70 mph. The longer gearing was for the higher compression motors sold in Europe and elsewhere. FWIW, with a 2.2 Subaru, I find the factory gearing works well up to around 6000' elevation, while above that it gets wimpy.
djkeev
djkeev is offline
PostPosted: Mon Mar 25, 2024 3:48 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
I cannot express how relieved I am to find out that my RPM to MPH is not out of the ordinary!
Thank you all for your feedback!
Ghia
Vanagon
Beetle
Shonandb Premium Member
Shonandb is offline
PostPosted: Mon Mar 25, 2024 4:29 pm    Post subject: Re: Automatic Transmission, RPM vs MPH Reply with quote
I have the 010 Vanagon Auto in my Bus with 225/75/16 LT Tires and was out on the Hwy yesterday and was running:
~3400 rpms at 60mph
~4000 rpms at 75mph
My rpms are about 500 rpms lower now than with the stock 185R14 Load D tires which was approximately 3900rpms at 60mph and 4500rpms at 75mph
Previous 1973 Panel Bus:
Click to view image
