Heat Exchangers - Rebuilt but unhappy
edhnb
edhnb is offline
PostPosted: Thu May 09, 2024 2:18 pm    Post subject: Heat Exchangers - Rebuilt but unhappy Reply with quote
I rebuilt my heat exchangers, but am unhappy with the finished product. Between all of my brazing, and how dinged up they were to start with, they look like sh!t.
Does anyone have experience with the Bus Depot heat exchangers? If they are quality I might just bite the bullet and buy them.
1977 Asi Riviera
busdaddy
busdaddy is offline
PostPosted: Thu May 09, 2024 3:06 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
Planning on showing at Pebble Beach?, looks aren't everything, function is more important.
Sounds like they are "pretty good, more good than pretty".
Слава Україні!
edhnb
edhnb is offline
PostPosted: Thu May 09, 2024 4:47 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I'm going to try spot welding the rough areas and grinding smooth.. I'll post pictures if the result is not too embarrassing.
1977 Asi Riviera
69BahamaYellow
69BahamaYellow is offline
PostPosted: Thu May 09, 2024 7:27 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I understand your dilemma as I tried brazing an old set of heat exchangers for a Porsche 911 that just never looked right. They were fully functional, but were never as pretty as OEM. The heat from brazing just warps everything. Get yourself a wire feed MIG welder and forget about brazing and you will have much better results
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 09, 2024 10:21 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
the set I had went to a professional welding shop. They used pieces of welding rod bent to the curve of the heat exchanger in curved areas, and filled them in. Used sheet metal where applicable. I ground with a dremel to smooth and painted. Count not see the welds. Later sold them and replaced with a NOS genuine VW set from BusOk DE. Like Mark said, unless you are going to show, function is premium. Do pressure test them.
Also the original F-tube and U-tube were covered with tin, and had asbestos in them. Unless you have those, what difference does the look of the heat exchanger matter? Be sure to leave the drain holes on the bottom open.
George Carlin:
Skills@EuroCarsPlus:
orwell84
orwell84 is offline
PostPosted: Fri May 10, 2024 6:16 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I spent a lot of time rebuilding stock heat exchangers. 3 sets to make 1. Lots of fiddly welding and grinding. Painted them with high heat paint as ceramic coating would have taken forever. They work really well. They looked amazing when I installed them. After 600 miles of driving in winter salt, they look like crap. I usually donโ€™t drive in the winter, but I needed to that one time.
Regular bus maintenance will now include cleaning up the heat exchangers and touching up the paint. No way to keep them beautiful unless you put your bus in a museum.
Whaanga
Whaanga is offline
PostPosted: Sun May 12, 2024 9:30 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I've also been working on replacing the heat exchangers for my 73 bus - luckily, I've found a person an hour from me that has a boat load of original VW parts (including at least 20 type IV engine cases, with tons of accompanying engine parts) - but I digress. In the stash, I found a very solid set of heat exchangers as seen here:
I've been working on them for a while and just sand blasted them yesterday in prep for painting as seen here:
BUT - I saw the post by Orwell84 with the heat components painted gray - (including the heat riser pipes, heater valves, etc:
Is this how these parts would have come from the factory in terms of paint color? I've never seen heat riser pipes and heater valves painted gray.
Thanks.
Late 1973 Bay w/a transplanted 914 Engine
Abscate Premium Member
Abscate is offline
PostPosted: Mon May 13, 2024 3:32 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
A more matte dull grey than that. Looking good.
orwell84
orwell84 is offline
PostPosted: Mon May 13, 2024 9:35 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
Heat risers and flapper valves are usually a satin black. The shiny light gray is my preferred color for everything around the engine. Makes everything easier to see.
wildDogPizza
wildDogPizza is offline
PostPosted: Mon May 13, 2024 5:08 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
If it's the Dansk ones you are asking about, my experience was that they are terrible parts. The set I had I purchased a long while ago, in 2007, but they are likely the same as what they are selling now. I had a set of the early oval port type 4 ones. They never wanted to seat right at the head. I was new to buses/vw's and drove around for months with exhaust leaks not knowing any better. I later found a sequence to torque them where I could get them to seal, but it was tweaking the pipes to do it. The strain led to the brazing cracking and more exhuast leaks. I fixed them several times, braze welding the castings back onto the pipes, but they kept cracking. The first time I took the cast flanges off the pipes I was appalled at how horribly they are fitted to the pipes. The pipes don't really flow smoothly to the flange and there's a big old kink where they connect. Just terribly made parts. I'll never buy another Dansk product if I can help it.
"Sliced Bread" 68โ€“73 Bus Part Finder
orwell84
orwell84 is offline
PostPosted: Tue May 14, 2024 5:37 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I ran j-pipes (from EMW) for a long time before I repaired my heat exchangers. Fit was good. I would run these or naked heat exchangers. The first priority is gettting a good seal to the heads. Thatโ€™s often not easy even with stock boxes. The stock heat is nice, but just nice. I spent a lot of time restoring my whole heating system, but it was more out of curiosity and for fun. There are easier and better options if you want actual heat.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Tue May 14, 2024 8:08 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
Whaanga wrote:
...I've been working on them for a while and just sand blasted them yesterday in prep for painting as seen here:
Props to you for doing a thorough job - I don't know if that's the final state before paint, or if you were going to do more prep -? There is still quite a lot of rust left; if you're going for a thorough job, you really want to get every bit of rust blasted out of the craters. It comes back, even under epoxy, if you don't completely eliminate it.
Another good option would be a phosphoric acid wipe down - depending upon your primer choice, that is.
Robert in Memphis
Dรผnkelgrรผgen 1967 Java Green bug thread
Engine rebuild thread
airkooledchris
airkooledchris is offline
PostPosted: Wed May 15, 2024 5:44 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
if how your heat exchangers *look* is the problem on your radar currently - run em
Whaanga
Whaanga is offline
PostPosted: Wed May 15, 2024 5:48 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
Thank you - yes, there is still more work to do. I have a container of phosphoric acid ready to go.
Abscate is offline
PostPosted: Thu May 16, 2024 3:30 am    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
Gloves and goggles with that stuff. Goggles, not glasses.
ghiaghia67
ghiaghia67 is offline
PostPosted: Sun Sep 22, 2024 12:15 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I bought a set of these last year $179 a each. Was replacing my original ones with the ends cracked and I had them taped them with Muffler tape but the heat was good. I got more heat out of them being original than Danke. Not worth to buy. I researched for 2 to 3 months before I bought these. I am now looking for some old new stock for good used ones
metahacker
metahacker is offline
PostPosted: Sun Sep 22, 2024 1:33 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
if you want them to look nice and stay that way, then you need to have them ceramic coated.
motor runs better with dansk boxes (less restrictive/turbulent) but proper fitment is challenging (had to cut and reweld on mine) and heat output is reduced
vwwestyman
vwwestyman is offline
PostPosted: Mon Sep 23, 2024 2:30 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I redid the exchangers on my '73 probably 10 years ago. Didn't crack 'em open then, but now that I really need to take them off and clean them up well, I think I may open the shell and remove that mat that is inside that folks think may have asbestos in it.
My engine has leaked enough oil in there that they were getting pretty stinky; enough that at some point last winter, I removed the couplers and blocked the heat tubes to the front, and just used the BA6.
All that to say, I'm following along with interest.
Dave Cook
1973 Wild Westerner
My Thing
Alan Brase
Alan Brase is offline
PostPosted: Wed Sep 25, 2024 1:48 pm    Post subject: Re: Heat Exchangers - Rebuilt but unhappy Reply with quote
I've said before: Dansk is Danish for "junk".
I can't believe they are now making all sorts of Porsche 911 stuff.
If you can find a dry country salvage yard, the heat exchangers will be very much better. Occasionally Bus Depot would find small stock of original German ones, but I think it' a pretty rare find.
I think originally they were zinc plated steel?
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
