rogertj Samba Member
Joined: October 07, 2008 Posts: 522 Location: Tijuana, Baja California. Mexico
Posted: Tue Apr 02, 2024 7:11 am Post subject: Re: 82 WestyRabbit Restoration |
Good progress this is a good feeling to never stop progressing with our vans. Whatever it takes! Keep going! Good job! _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24506 Location: NYC/Upstate/ROW
Posted: Tue Apr 02, 2024 9:00 am Post subject: Re: 82 WestyRabbit Restoration |
Still subscribed - I wonder of that Mechanical ADvantage place is still there in NW CT?
THanks for keeping the pictures almost totally free of T4 Wankers. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17385 Location: Brookeville, MD
82westyrabbit Samba Member
Posted: Sat May 25, 2024 6:52 pm Post subject: Re: 82 WestyRabbit Restoration |
I was finely able to get the van off the lift for the summer
The new brakes work great and make me feel cool 😎
The roof vent I installed started to leak after a few years so I pulled it out and reinstalled it with some modifications
I fiberglassed in some wood to make a ridged mounting on the front and back mounting surface.
I installed a wood doubler on the bottom.
I painted around the vent. Clearly I am going to have to paint the rest of the roof but that will wait until next winter. Now it should be ready for some trips this summer. John |
Posted: Thu Mar 20, 2025 5:58 pm Post subject: Re: 82 WestyRabbit Restoration |
I am working on this winter's van project. I am getting started quite late because I was working on a friend's dune buggy project.
Item one: Installing a Truck TF49 Fridge.
Item Two: Installing a Chinese Diesel Heater under the fridge.
Item Three: Removing the swivel seat base on the driver's side
Item Four: Installing a second battery
Item Five: Installing a powered subwoofer under the driver's seat
Item Six: Installing a 100 watt solar panel in the luggage rack.
As my van started life as a diesel, the main battery is in the engine compartment which required running a full size battery cable from the starter to the auxillery battery with a big fuse at each end of the wire. The seat swivel has already been removed. It was a hard choice to cut that swivel out, but i figured if I hadn't used it since 1988, I wasn't all of a sudden going to start using it. It made it a lot easier to install a big marine battery under the driver's seat. All of the components are already installed leaving me with wiring and trim to complete. John |
Johnoo Samba Member
Joined: June 25, 2009 Posts: 9 Location: Toronto, Ontario, Canada
Posted: Wed Oct 22, 2025 8:13 am Post subject: Re: 82 WestyRabbit Restoration |
| Wondering how the Chinese diesel heater (CDH) under the TF49 worked out for you? Any significant modifications required to make them both fit? |
Posted: Wed Oct 22, 2025 6:42 pm Post subject: Re: 82 WestyRabbit Restoration |
| The diesel heater works great. The fridge has to get pushed all the way to the top. About a 1/4 or a 1/2 inch higher than the Rocky Mountain kit installs it. I have meant to post some pictures of the complete project but havenβt gotten that far. This is my busy season. I have a bunch of stuff to post when I slow down a bit. John |
Johnoo Samba Member
Posted: Thu Oct 23, 2025 3:22 am Post subject: Re: 82 WestyRabbit Restoration |
| Many thanks for the quick update. I'm very interested to see and understand more about raising the fridge more than the Rocky Mountain West install kit (when you have time). |
