Pretreating death foam
BMFBMF
BMFBMF is offline
PostPosted: Sun May 26, 2024 1:02 pm    Post subject: Pretreating death foam Reply with quote
All this talk on the other thread about the rear window vents have made me wonder about my 71.
Car lived in a dry salt-free place and so has very little rest, but I wonder if I should preemptively zap inside the death foam cavity with cavity spray from both the inside and from the outside vents?
Can't hurt right?
-----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day.
H2OSB
H2OSB is offline
PostPosted: Sun May 26, 2024 1:13 pm    Post subject: Re: Pretreating death foam Reply with quote
I'm with you. I bought my car in Mojave, where it lived a pampered life out of the Sun's destructive gaze. My death foam is, thus far, healthy and intact. I often wonder if I should preemptively deal with it
H2OSB
(o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you.
baldessariclan
baldessariclan is offline
PostPosted: Sun May 26, 2024 1:23 pm    Post subject: Re: Pretreating death foam Reply with quote
I think the main thing to worry about is water being able to get in along sheet metal seams of the vent area, and/or along edges of the rear window. If both those areas are adequately sealed, water shouldn’t be able to get in and then seep/wick below into the space between the foam and sheet metal.
AZ guy
AZ guy is offline
PostPosted: Sun May 26, 2024 3:33 pm    Post subject: Re: Pretreating death foam Reply with quote
As the guy who started the rear windows posts, would you quit making more things for me to think about/do.
I've got enough on my hands already.
Meanwhile, what is it I should spray in there?
jinx758
jinx758 is offline
PostPosted: Sun May 26, 2024 3:57 pm    Post subject: Re: Pretreating death foam Reply with quote
Maybe start by pulling the rear side panels & shine a light in there, hoping the foam isn't totally obstructing the metal.
Ospho stuff would need to be neutralized.
A quality paint that encapsulates would be best.
Perhaps shoot Eastwood an email.
Good luck ... stay safe
jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
67rustavenger
67rustavenger is offline
PostPosted: Sun May 26, 2024 4:16 pm    Post subject: Re: Pretreating death foam Reply with quote
Didn't VW start using the death foam beginning in 1973?
If so, why is this an issue on a 71 in Europe?
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Tom K.
Tom K. is offline
PostPosted: Sun May 26, 2024 4:48 pm    Post subject: Re: Pretreating death foam Reply with quote
I would leave it alone. The foam is *not* the problem. The rust occurs when a rubber seal under the vent cavity is poorly installed or fails. I would remove the vent cover from the outside and slobber some sealer along the bottom channel of the cavity.
'91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight=
baldessariclan
PostPosted: Sun May 26, 2024 6:37 pm    Post subject: Re: Pretreating death foam Reply with quote
Pretty sure VW started using the foam by 1970 or even earlier (perhaps 1967 or 1968?). My car is a 1971 and definitely has the foam in it.
Before that, they stuffed triangular “pillows” up in there to help combat noise from the engine compartment. The noise level from the back was always an issue, and suspect the foam performed a lot better than the pillows at reducing that.
beetlenut
beetlenut is offline
PostPosted: Sun May 26, 2024 9:20 pm    Post subject: Re: Pretreating death foam Reply with quote
Sounds good in theory, but the foam is bonded to either side of the inner and outer metal. If you're hoping the foam absorbs the ospho or encapsulator, doubt it would absorb enough to stop all the rust. Condensation is the chief way water gets in there.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
vamram Premium Member
vamram is offline
PostPosted: Mon May 27, 2024 5:43 am    Post subject: Re: Pretreating death foam Reply with quote
My '72 had death foam so it definitely began before '73. I cleaned it out as best I could from the engine compartment and reaching from inside the rear seat side panels, sprayed with rust converter, primer, paint, then undercoating. Then stuffed a couple of those chemically expanding packaging foam bags in there. Was fine for 3 years then I sold it in 2018 so I've no idea how that whole thing held up..
Click to view image
Save the Supers!!
empi3
empi3 is offline
PostPosted: Mon May 27, 2024 6:11 am    Post subject: Re: Pretreating death foam Reply with quote
Looks like Aug '65 making it the 1966 model year.
From "Progressive Refinements"
Steven
The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle
1968 Ghia
dopeboat
dopeboat is offline
PostPosted: Mon May 27, 2024 7:44 pm    Post subject: Re: Pretreating death foam Reply with quote
IMO if your car has the foam, you should get it out of there. Sure, you could squeeze some sealant into where the crescent vent seals sit, but you’re kicking a potentially very expensive and annoying can down the road. I just completed my death foam repair and I certainly wish somebody had caught it sooner. Best case scenario, you open up those sides (from INSIDE the vehicle), and once the foam is out of the way, there’s some lovely painted metal staring back at you. Worst case scenario, it’s swiss cheese that a previous owner has filled in with JB weld and painted over. Either way it’s better than waiting for it to rot from the inside out, which as I understand it, is inevitable. Does anybody have a car with death foam that has opened the area up and found it completely unaffected?
'77 FI Bahama Blue Type 1
Multi69s
Multi69s is offline
PostPosted: Mon May 27, 2024 10:03 pm    Post subject: Re: Pretreating death foam Reply with quote
My 69 had the death foam that I removed. However, there is one down side to removing it. If you have dual carbs, it is a perfect sound channel into the interior. I pulled the wiring loom out and cleaned all of the foam out, then sealed it with a good paint, and sprayed polyurethane foam in its place (its water proof).
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
vamram is offline
PostPosted: Tue May 28, 2024 4:15 am    Post subject: Re: Pretreating death foam Reply with quote
As I understand it, water proof foam won't necessarily solve the problem since moisture between the foam and the metal is where the rust happens.
Click to view image
Save the Supers!!
Tom K.
Tom K. is offline
PostPosted: Tue May 28, 2024 11:58 am    Post subject: Re: Pretreating death foam Reply with quote
I opened up that cavity and found zero rust. And now I regret having done it (engine noise in cabin got louder). The seal along the bottom of the vent cavity was installed properly on my car and has kept the moisture out. Here is my process.
https://www.thesamba.com/vw/forum/viewtopic.php?t=738766&highlight=death+foam+tom+k
viiking
viiking is offline
PostPosted: Tue May 28, 2024 6:02 pm    Post subject: Re: Pretreating death foam Reply with quote
My unmolested Euro Feb 68 still had the pillows inside and no-rust.
BMFBMF
BMFBMF is offline
PostPosted: Tue May 28, 2024 9:54 pm    Post subject: Re: Pretreating death foam Reply with quote
Thanks for the input guys.
Multi69s
Multi69s is offline
PostPosted: Tue May 28, 2024 10:58 pm    Post subject: Re: Pretreating death foam Reply with quote
If the surface is painted, and you use expanding foam, there is no gaps between it and the metal.
69 road Bug 2110
My builds
dopeboat
dopeboat is offline
PostPosted: Wed May 29, 2024 5:05 pm    Post subject: Re: Pretreating death foam Reply with quote
Did you have foam or pillows?
vamram is offline
PostPosted: Wed May 29, 2024 5:52 pm    Post subject: Re: Pretreating death foam Reply with quote
Tom K. wrote:
....The "death foam" does not absorb moisture. Once I apply liberal sealant above and below my good seals as a safety measure and then paint the entire cabinet with several coats of Eastman's cavity paint, I plan to simply spray closed cell foam right back in there - but further aft of the vent window (where the pillows originally were placed) to allow me to inspect whenever I want the area under the seals through the inner holes that I cut. I'm also thinking about mounting speakers into those holes.
Click to view image
Save the Supers!!
