busdaddy Samba Member
Joined: February 12, 2004 Posts: 53256 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat May 25, 2024 10:13 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
A hard stop on gravel usually exposes non working wheels. But a fault in the hydraulics will also make the light come on only when the pedal is pressed, if yours is on all the time it's more likely a switch or the wiring to blame.
Or is the parking brake on? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
dopeboat Samba Member
Posted: Mon Jun 03, 2024 4:23 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
Replaced both brake light switches and nothing changed, but in the end I got it sorted - I had replaced the light module itself, which includes the seatbelt light. I thought I’d gotten an exact replacement - turns out they were slightly different in the way they’re wired. Plugged the old switch back in and voila!
However, now I’m dealing with a few separate issues.
#1 - my valves on the driver’s side head keep getting loose and clacky and I can’t figure out why. They have new adjusters on them. I know it’s bad for valves to get tight after a rebuild, but haven’t heard so much about them getting loose again and again. I’ve put less than 500 miles on this rebuilt engine and I’ve had to adjust the valves three or four times. Prime suspect is #4 exhaust valve. There also seems to be some HOT debate over whether valves are supposed to get tighter or looser as an engine warms up…
#2 - there’s a pronounced CLUNK heard and felt when I let out the clutch when taking off from a dead stop, as well as when going from first to second, and second to third, although each subsequent gear change is softer. No sound from third to fourth. Tribal wisdom indicates this is either a bad front transmission mount or big bad news for the transmission internals. Would love to hear people’s thoughts. _________________ '77 FI Bahama Blue Type 1 |
Posted: Mon Jun 03, 2024 4:48 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
Loosening valves could be the nuts holding the rocker assemblies to the head loosening, or cam or lifter wear, let's all hope it's loose nuts....
For the clunk put it in 1st gear with the engine off and have a couple helpers at each end of the car push it back and forth while you listen for the clunks source. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jun 04, 2024 9:04 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
| busdaddy wrote: |
For the clunk put it in 1st gear with the engine off and have a couple helpers at each end of the car push it back and forth while you listen for the clunks source. |
If it was cam wear, wouldn't #2 exhaust valve also be getting equally loose as the cam wore? That certainly doesn't rule out lifter wear, though...
Sadly it's definitely not the rocker assembly nuts getting loose, I checked them this morning and they are tight as anything. I'd checked my valve lash "warm" yesterday and found #4 exhaust valve to be 0.012. #4 intake was 0.010, and both #3's were 0.008. Out of curiosity I popped the passenger valve cover off and all four on that side were around 0.008 as well. I adjusted #4 exhaust in to 0.008 warm.
Reminder that I'm running stock aluminum pushrods.
This morning, stone cold, we're at:
1) 7/7
2) 7/7
3) 7/7
4) 6/6
So clearly I'm experiencing INCREASED valve clearances when warm, my biggest question is - is that normal??? Isn't the 6-thou cold setting to allow for expansion where the valve clearance decreases as the engine warms up? If not, why wouldn't I just set them tighter on a standard-rev engine knowing I'm never going to be floating valves, especially not how I drive with the engine cold? I've heard of folks adjusting to 0.004 cold to reduce some of the clacking, which I could try, but it's still perplexing to me that the delta between hot and cold clearances is so much just on this one cylinder... _________________ '77 FI Bahama Blue Type 1 |
Posted: Tue Jun 04, 2024 9:35 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
The .006 is to allow for expansion of the aluminum push rods mostly, why aren't yours growing faster than the cylinders?
Do you have a working thermostat?, what temps are the oil reaching when warmed up?, what oil are you running? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jun 04, 2024 10:57 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
Oooooooooooh. I do have a working thermostat, I tested it before reinstalling, although it was disconnected when I bought the car so I had no guidance on placement. I adopted the theory that at full open thermostat, the flaps should be full open, so I adjusted accordingly. I'm running Shell Rotella straight 30, knowing I won't be driving the car any time in winter temps. The oil temperature does indeed not get as high as it should - maybe 130F. That was an issue I'd planned to address in the future, though I thought it might have been due to the placement I chose for the temp sender - front pressure relief plug.
I guess it would stand to reason that if the oil running through the pushrods is not getting hot enough, they won't expand enough, and I'll get clacky valves when the engine gets warm because the cylinders are expanding ahead of the pushrods.
I'll adjust my thermostat and see what happens! _________________ '77 FI Bahama Blue Type 1 |
Posted: Tue Jun 04, 2024 11:13 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
Well here's the next conundrum - I'm already out of adjustment on my thermostat. If I disconnect the bracket and pull the whole thing downward until it stops (flaps closed, I assume), here's where I end up. As you can see, I'm outside of the range of the slot on the bracket. Not really sure where to go from here aside from pulling the whole fan shroud to adjust it. I suppose I could try and introduce a new bend in the rod which would shorten it, seems risky though.
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1081 Location: San Juan Islands
Posted: Thu Jun 06, 2024 9:43 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
That's the first time I've ever heard of cylinders out expanding stock pushrods. Biazzare.
As a test, the flaps fail open so you could just disconnect the T-Stat and run the Bug on the freeway for a while. Would hope the valve lash would quiet down.
Curious how this one will get resolved.
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Jun 06, 2024 10:15 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
If the bracket won't slide down far enough to get full flap closure the problem is the U link on the RH flap where the rod attaches, unfortunately it requires removing the shroud to fix. The U gets bent when someone trys to lift the shroud without removing the thermostat first ("why won't this thing come off?"... yank yank YanK), the bend screws up the leverage ratio or in other words moves the fulcrum.
Disconnecting the thermostat and hitting the highway won't make it warmer, it'll keep it from ever warming up properly. For now set it as low as you can and tolerate the clacking valves, at least if they are making noise you know they aren't tightening up and burning.
Слава Україні! |
Posted: Thu Jun 06, 2024 8:37 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
| busdaddy wrote: |
Ugh that’s what I was afraid of. I filed out the hole on the Tstat bracket to allow it to sit lower, I believe I’m getting full flap closure now. I also switched out to 15w40, that seems to have warmed things up slightly, but hasn’t made an order of magnitude difference. I’m still struggling with oil not getting up to temp, which I don’t like. Cooling TOO well was definitely not a problem I anticipated having when rebuilding. I’m running a basically stock engine with a spin on filter mount, the type people say sits too close to the exhaust and frequently makes the oil too hot! I’ve heard of people running smaller crank pulleys to slow the fan down a bit, I may look into that. Otherwise I don’t really understand. What could be causing me to have such ridiculously cool oil? Is it possible one of my relief valves is malfunctioning and constantly sending oil through the oil cooler when it’s not up to temp? How would I test that? _________________ '77 FI Bahama Blue Type 1 |
Posted: Fri Jun 07, 2024 10:07 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
That's a good thought (relief valve). If you're running oil through the cooler 100% of the time, it may only ever get to operating temp on long drives.
Do you see foam on the oil filler and cap like this:
Posted: Fri Jun 07, 2024 10:09 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
My FI Mexi-Bug did that until I installed flaps and T-stat. Hasn't done it since, warms up much quicker, oil temp rises quicker and stays more consistent. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Sun Jun 09, 2024 2:25 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
Not even a bit of foam on the cap or in the filler tube. I'm tempted to pull the sender and relief valve/spring to see what's going on in there. I am however just throwing money away on oil at this point, which I realize is a drop in the bucket compared to running a new engine too cool, but something has to be said about it.
I'm also finding some conflicting opinions out there regarding placement of the temp sender in the front pressure relief port - some say it just gives you the temperature of the case, not the oil, which I think is possibly a fair point given I'm not sure how much "real temp" oil actually gets past the plunger to the sender... I've considered relocating the sender to the sump plug on the chance the "too-cool oil" is really fine.
I suppose at the end of the day, the symptom of the increasing valve lash is still there, regardless of what the oil temp is doing. The oil temp may be a red herring. #1/2 side sounds fine when hot. #3/4 is clacky as hell, and upon pulling valve covers, #4 is the culprit, particularly the exhaust. Maybe I'm getting sticky lifters when hot? Maybe I have some bum pushrods? Now is maybe a good time to mention that while I said I'm running stock pushrods, I'm really running whatever pushrods came on the engine - they were in fine shape, so I reused them, and they are nonferrous, so I've assumed they're aluminum, and therefore, the stock ones.
I'm at a loss, and while the noise is bothersome, I'm really just mostly concerned about the health and longevity of my rebuilt engine, which I've sunk a rather large sum of money into... _________________ '77 FI Bahama Blue Type 1 |
Posted: Sun Jun 09, 2024 2:44 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
That front hole really doesn't see alot of action, but instead of buying more oil invest in a laser thermometer gun, then you can shoot the sump plate, and the best spot which is right beside the oil pump on the back of the sump.
If the pushrods weren't magnetic then they are most likely stock, I guess if you have nothing better to do you could swap them into a position on the 1/2 side and see if the noises follow, or just set the #4 valves a few thou tight and turn up the radio.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jun 11, 2024 9:09 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
Well I switched back to SAE30, and pulled my relief and control valves to get a look at them. The relief valve plunger was heavily scored when I rebuilt the engine, and doesn't look any worse now. I had sanded it down slightly to remove any proud spots while I had the engine apart but it moved freely in the bore so I saw no reason to replace it. It still moves freely in the bore so I guess it's fine. Same with control valve.
I went to move my temp sender over to the sump drain plug spot, only to realize that, obviously, the two have different size threads. So I've got a drain plug sender on order.
I did adjust the #4 valves tighter (about 4-thou cold) and it seems to have helped a bit. Will report back on oil temps when my sender arrives. _________________ '77 FI Bahama Blue Type 1 |
Posted: Fri Jun 14, 2024 9:18 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
Well the sender is taking its damn time to arrive - in the meantime, I'm encountering another situation I'm not quite sure what to make of. I've begun to notice a sound on acceleration when the engine is under load, which I immediately assumed was an exhaust leak. Kind of a "chuffing" sound. I'm uncertain if it's new, or been there since the rebuild and gone unnoticed because of the noise on the valvetrain, which I've only just calmed down by gapping #4 valves to 0.004".
Fearing a head was at best loose and at worst cracked, or somehow a burned valve, I did a compression and leakdown test. Compressions were 130 across the board, leakdown also revealed nothing, each cylinder offering a 5 psi running drop from 90 at TDC.
Getting underneath, nothing appears out of order, where I'd expect a compression or exhaust leak between head and cylinder or head and exhaust to present with visible soot spots.
The bottom line is, the engine just sounds a bit "lawn-mowerish" under acceleration, but only under load. Is that just what the FI beetles sound like? Can anybody point me towards a video of a properly running FI beetle for me to compare to? I'm much more used to the typical sounds made by carbureted beetles.
See below a few videos I took trying to capture the noise. It's super hard to capture on video, and again it may literally just be my perception of it. I know I'm becoming a mechanical hypochondriac with the car. Unfortunately the dash speaker is so crappy I find myself driving with the radio off, which prompts me to be listening for noises.
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 494 Location: Rhode Island
Posted: Sat Jun 15, 2024 8:28 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
I listened to your videos a few times. Your exhaust sounds a lot different than mine. Beyond that, there's a hesitation and roughness as your engine revs up. Instead, it should be very smooth. I have a few questions:
1. How long did you run the engine before taking the videos. Was the engine hot or cold?
2. Do you have the cold air intake snorkel in place? If so, does the temperature activated flap work properly?
I'll try to post a video of my engine revving up for comparison. _________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
Posted: Sat Jun 15, 2024 9:14 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
| Lost69Convertible wrote: |
I'll try to post a video of my engine revving up for comparison. |
I thought that hesitation might come up. The engine hadn’t really been warmed up at the beginning of the video, it always does that for a minute or so before it evens out. Otherwise the noise I’m concerned about is present at all states, hot, cold, warm.
I do have the cold air snorkel in - at least what I think you’re referring to. There’s the actual snorkel-lookin thing that comes off the air cleaner and grabs air from the deck lid vents, then there’s the inlet on the underside of the air cleaner that grabs I guess preheated air from underneath the breast plate. Both are present. I did disassemble the flap mechanism and checked that my wax pellet thermostat is functioning, which is it. I GINGERLY tested it with a heat gun, and it expands and retracts as it should. Is there anything else I can test on it? _________________ '77 FI Bahama Blue Type 1 |
Posted: Sat Jun 15, 2024 10:25 am Post subject: Re: 1977 Fuel Injected Standard Project Page |
Have a good close look around the bases of the cylinders, my crappy lap top speakers don't really let me hear anything odd, but a noise under power and growing valve gaps could be a case stud(s) starting to pull out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jun 15, 2024 4:13 pm Post subject: Re: 1977 Fuel Injected Standard Project Page |
| dopeboat wrote: |
| I GINGERLY tested it with a heat gun, and it expands and retracts as it should. Is there anything else I can test on it? |
Sounds like your temperature activated flap is working properly. I asked you about this because mine stopped working last year. The air intake was coming from cylinders 1 & 2 full time. After my engine heated up I was losing power and there was roughness and hesitation. (it's fixed now)
Here's a video of my engine revving while parked. I drove the car for 30 minutes before this video, the engine is fully warmed up. Hope it helps you.
https://www.youtube.com/shorts/jf6R9L-PWaU _________________ 1956 Beetle Ragtop: My Father's car
Last edited by Lost69Convertible on Sat Jun 15, 2024 4:25 pm; edited 1 time in total |
