91 Vanagon cooling fin (pushrod shield) part number?
Mike888
Mike888 is offline
PostPosted: Mon Jun 10, 2024 7:38 pm    Post subject: 91 Vanagon cooling fin (pushrod shield) part number? Reply with quote
I’m looking to replace the part shown. Part number? Source?
zerotofifty
zerotofifty is offline
PostPosted: Mon Jun 10, 2024 7:53 pm    Post subject: Re: 91 vanagon cooling fin part number? Reply with quote
https://www.thesamba.com/vw/classifieds/search.php...ywords=tin
Several sellers here, see above link.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Mike888
Mike888 is offline
PostPosted: Tue Jun 11, 2024 8:02 pm    Post subject: Re: 91 Vanagon cooling fin part number? Reply with quote
Thank you! Now I know what they are called!
Are there any sellers from Canada? I am in Ontario.
Trevor P
Trevor P is offline
PostPosted: Tue Jun 11, 2024 9:40 pm    Post subject: Re: 91 Vanagon cooling fin part number? Reply with quote
I have a used set Id likely part with and Im in Saskatoon, or if you want new ones Concept 1 in Calgary has them in stock
https://store.concept1.ca/store/search.asp?keyword=pushrod%20shield*
53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
dabaron
dabaron is offline
PostPosted: Wed Jun 12, 2024 8:02 am    Post subject: Re: 91 Vanagon cooling fin part number? Reply with quote
i would not buy the VW pushrod protection sheild. GoWesty makes a MUCH nicer product, heavier gauge steel, and it does not require removing the exhaust stud nut to remove. very important if the low pressure oil sender needs replaced.
concept1 sells the GoWesty product. totally worth the money.
https://gowesty.com/products/push-rod-tube-shield-set
1991 Vanagon GL Camper
Mike888
Mike888 is offline
PostPosted: Mon Jun 17, 2024 7:32 pm    Post subject: Re: 91 Vanagon cooling fin part number? Reply with quote
Thank you! I will check out Concept 1.
zerotofifty
PostPosted: Mon Jun 17, 2024 9:28 pm    Post subject: Re: 91 Vanagon cooling fin part number? Reply with quote
At $109.14, it is not worth the money. The stock shield gives plenty of protection, and for that amount of money, I will gladly remove an exhaust stud nut.
Words to live by.
MarkWard
MarkWard is offline
PostPosted: Tue Jun 18, 2024 5:07 am    Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? Reply with quote
Gladly remove an exhaust stud nut till the stud snaps off and actually you may need to slot the one bracket to fit over the stud without removing.
There is a member tencent, his company is intrepid overland or something similar. He had a different design shield. I recall liking its design. The LS one is more critical to be easy to remove for access to the oil pressure switch and wire.
zerotofifty
PostPosted: Tue Jun 18, 2024 8:00 am    Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? Reply with quote
Easy to slot that hole with a hacksaw, and antiseize is very useful on exhaust parts. The aftermarket shield is just too much money.
Heck you can even make a holder like the aftermarket one with a small piece of steel flat bar, two bolts and two nuts and be many many dollars ahead $$$$$$$
Words to live by.
riceye
riceye is offline
PostPosted: Tue Jun 18, 2024 9:36 am    Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? Reply with quote
I still have my originals, but if I needed to purchase replacements I would strongly consider these.
Intrepid Overland (Vanistan) Push Rod Shields
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
