doublecanister Samba Member
Joined: September 23, 2008 Posts: 1222 Location: Richmond, Va
Posted: Sat Dec 30, 2023 8:36 am Post subject: Re: Krylon close matches to factory colors |
| doublecanister wrote: |
Hey Folks, I did some searching around and I'm not finding much on trying to match the 1973 Thing Blizzard White in a Krylon or Dupli color match.
T |
Well I did find a very close match in "Chiffon Cream" Behr paint but it's a chalk or matte finish. it's "so close" but is a tad lighter.
I found the VW paint code chip's on the Samba, had that open on one screen and tried to match various shades that way, it got really close surprisingly.
https://www.homedepot.com/p/BEHR-PREMIUM-12-oz-SP-...ds#overlay
I may try it with some red primer or maybe black primer as a base to see if it darkens it up a bit, shot some on a piece of test metal for affect using No primer. Of course in the engine bay
compared with the rest it does show lighter/brighter than the rest being it's fresh.
I really was just not ready to do an entire engine bay strip sand and repaint but with the engine dropped, all the bad spots are showing now especially
after cleaning up and removing the old engine to body gaskets and degreasing everything, figured it was time to replace that dern rubber seal.
Anyways, I'll try this in an inconspicuous area and see how it goes,
Plan b, it's off to the paint shop to probably pay big money for a quart of the correct color that wont match anything I have!
Well just thought I'd share what I found in case anyone else decides too look or give it a try.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 3011 Location: Thornton, CO
Posted: Mon Mar 25, 2024 8:15 am Post subject: |
| W1K1 wrote: |
Funny story about L456 ruby red, i got a can of ZeroRust red to do some repair jobs on my square , when i was running low i ordered another can. They shipped me safety red. I didn't car it was going under the car anyways, But i was spraying one day and used up the last of the red and mixed the safety red in 50/50.
Body panels are stock L456, as is inside of the trunk lid, but top of the fender, inside the trunk are 50/50 zero rust reds. It made a very good match for touch ups on the original color too.
In the sun
That's a great look. Something I would drive, for sure.
Here is my situation.
I have a '63 Beetle in Ruby Red. The paint is not in the best condition but I have been able to bring out a shine on it.
I was thinking to get some close-match red for touch-ups.
You had mentioned Zero Rust Red and Safety Red. When mixed together 50/50 you said they were very close. I assume that these were not spray cans if they were mixed. I will be using spray cans only. is this stuff available in spray cans?
How was the match with either red before the mix?
For everyone else, regarding the wheels:
I want to paint the wheels. I have have achieved very good results with spray cans on other cars' steel wheels, so I will be using spray cans.
Although the body is red, I want the wheels to have black outers and white inners. I have seen pictures of wheels on Beetles in this pattern with L41 black and L87 pearl white.
As I am not matching body colors, I only want reasonably close matches for both of these colors.
It has been mentioned here that Rustoleum Canvas White is the closest thing anyone has found to L87 pearl white.
I have seen no mention here of a close match for L41 black.
It may seem that black is black is black, but I have seen black VWs from my car's era and that's the black I want.
I have searched the spray paint bays at my Home Depot, and have found limited selection of anything that might be close to these colors. This is been difficult to match because I have nothing to compare them to.
So, to recap,
1. Which red for Ruby Red, including or besides what reds are mentioned above?
2. Anything new and closer than Rustoleum Canvas White for L87 pearl white?
and 3) anything at all for L41 black?
Thanks muchly. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
n2wheelies Samba Member
Joined: May 31, 2006 Posts: 88 Location: newport beach, ca
Posted: Fri May 03, 2024 7:18 pm Post subject: Re: Krylon close matches to factory colors |
I went to Ace Hardware and they have two different gloss enamel Regal reds. A 15 oz for $7.99 that is indoor outdoor and slightly more orange. And a 12 oz can for $9.99 that seemed a little more red. I hope this one is the right one. Personally because I like the color better. It's hard to tell with fluorescent lighting and my cell phone camera. Thanks to those who put this thread together and contributed _________________ '87 Vanagon Weekender 'ELNINYO'
past vw's...
'09 Jetta Sportwagen 'Pearl'
'60 Deluxe Beetle
'09 EOS 'petal'
'78 scirocco
'66 T2 panel dead tour vehicle, 'mr bus'
'67 13 window
'95 eurocamper 'charlie' (phish tour vehicle)
'03 Mk4 TDI 'steve'
'04 W8 Phaeton 'david' |
jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 492 Location: GALWAY,IRELAND
Posted: Fri Jun 21, 2024 9:38 am Post subject: Re: Krylon close matches to factory colors |
I tried a few colors but none available in my store matched marinablau so I made my own custom mix,
50 per cent White
30 per cent Green
20 per cent Blue.
AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1114 Location: Massachusetts
Posted: Thu Jun 27, 2024 12:45 pm Post subject: Re: Krylon close matches to factory colors |
| It looks like Krylon no longer makes Hosta Leaf. Other than the flat Camo paint has anyone else come across another substitute for L312 Palm Green? I haven't got anything suitable here to bring for a color match. |
Thehate916 Samba Member
Joined: February 04, 2016 Posts: 55 Location: Sacramento, CA
Posted: Wed Sep 04, 2024 8:51 pm Post subject: Re: Krylon close matches to factory colors |
Any luck with L620 Savanna Beige? I went and bought a can of the Krylon Khaki color recommended in this thread and it must have changed formula because it wasn’t even close! _________________ '68 Beetle project |
zodlaw Samba Member
Joined: July 27, 2005 Posts: 581 Location: Battle Ground, Wa.
Posted: Sat Sep 07, 2024 7:26 pm Post subject: Re: Krylon close matches to factory colors |
My brother in-law tried to get a paint match for Volkswagen Oliv Green Code L319. I guess they just laughed at him. I was wondering if you guys could point us in the right direction. The car is supposedly painted L319, which is RAL 6014 50% or satin. Looking to find a place that either has it in bulk or in cans.
Thanks for any help with this.
_________________ 68 build that had been sitting for 18yr in a garage.
https://www.thesamba.com/vw/forum/viewtopic.php?t=657472&start=0
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0 |
Heiferman Samba Member
Joined: February 28, 2024 Posts: 421 Location: Georgia, USA
Posted: Wed Apr 23, 2025 3:49 pm Post subject: Re: Krylon close matches to factory colors |
I have a 1970 Ghia that was clipped up front so the paint is a bit of a mystery. Both the front and back are 1970. The front seems more L30E Bahia Red but the rear engine bay seems more darker Bloodorange L21E. (The entire outside of the car was sand blasted.)
We just got a can of Rustoleum 2X Gloss Apple Red and sprayed it inside the frunk against what we think is Bahia L30E and we can barely even tell the difference with what we think is peeling OEM paint. Hard to say given the history of the car.
I thought the L21E was not used until 1971 model year so this is a a little odd. _________________ - 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance |
Willin Samba Member
Joined: October 10, 2019 Posts: 345 Location: Bozeman Mt
Posted: Wed May 28, 2025 12:04 pm Post subject: Re: Krylon close matches to factory colors |
Hi
What is the name of the interior paint, cargo floor, for a 73 Microbus?
Pastel White/ Kasan Red exterior.
I looked and could find that split bus interior is Silver Beige. Is that correct?
So Silver Beige for bay interior? Or what?
Krylon Almond,I saw was a match for SB
Or is there a better rattle can match you've found for bay bus interior?
TIA _________________ 73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit". |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72043 Location: Phoenix 602
Posted: Wed May 28, 2025 12:47 pm Post subject: Re: Krylon close matches to factory colors |
I don't know on the paint match but if the Bus "White" color is Pastel White I believe the interior paint is also Pastel White.
This is how Split Buses with light colored roofs work - The white interior color is the same as the exterior light/white color. _________________ How to Post Photos
Willin Samba Member
Posted: Fri May 30, 2025 9:43 am Post subject: Re: Krylon close matches to factory colors |
I had thought of that.
The exterior of the bus has been repainted different white and red. There is only a little Pastel White on the roof where the new paint has flaked off. I guess that matches the interior, which is original.
My wife says I have male color blindness, so I'll ask her if she thinks they match.
I made and welded in a patch to fill a hole a PO cut in the cargo floor. My first attempt at this kind on repair. It came out pretty good. If I match the paint it will be (almost) un-noticeable.
A few pages up, I think there was a match for Pastel White.
Thanks _________________ 73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit". |
Posted: Fri May 30, 2025 12:36 pm Post subject: Re: Krylon close matches to factory colors |
Yes, here's the post:
https://www.thesamba.com/vw/forum/viewtopic.php?p=6018755#6018755
| WestyMan1971 wrote: |
I see a number of people looking for L90D Pastel White. My bus is this color and I've done a bit of research and planning on testing a couple soon. The two closest matches I've narrowed it down to based on info I've found is:
Rustoleum Painter's Touch Ivory Bisque
Rustoleum Antique White
I'm going to try both soon and report back. |
I don't think he reported back.
I did 2 quick Google searches and both those colors still came up from various sources like Home Depot so they should both still be available _________________ How to Post Photos
Willin Samba Member
Posted: Mon Jun 02, 2025 6:54 am Post subject: Re: Krylon close matches to factory colors |
Thanks Everett!
I will look for those two. _________________ 73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit". |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1062 Location: Eastern north carolina
Posted: Wed Jun 11, 2025 6:52 am Post subject: Re: Krylon close matches to factory colors |
| I just finished using up an older can of that rustoleum antique white on the outer rim of some bug wheels. When I looked for it locally in the big stores(Lowe's, Walmart, tractor supply) I could not find any on the shelves. You may have a hard time finding it. Has anyone seen it in the stores? |
Willin Samba Member
Posted: Wed Jun 11, 2025 12:11 pm Post subject: Re: Krylon close matches to factory colors |
The "Ivory Bisque" I found was Satin.
Still looking around. Every store has different colors, even within brands. _________________ 73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit". |
CoastalBug Samba Member
Joined: June 15, 2025 Posts: 141 Location: TX Gulf Coast
Posted: Sat Aug 16, 2025 12:07 am Post subject: |
| dubllyou wrote: |
Not a bad match. A little playing with the undercoat and I think it could be even closer.
The light's funky in the shot and I can't roll it out yet but it looks darn good in person.... after five cans of "test" paint.
Looks close enough to me! I know what I'm doing tomorrow. _________________ Chris - 1968 Beetle Sedan, a book, and a lot of determination. |
RobE30 Samba Member
Joined: June 30, 2009 Posts: 102 Location: Coopersburg PA
Posted: Thu Aug 21, 2025 9:55 am Post subject: Re: Krylon close matches to factory colors |
Has anyone found anything that's an acceptable substitute for IndigoBlau? Bright Blue from Ace hardware is too bright. _________________ 1960 Ragtop bug- work in progress |
WestyMan1971 Samba Member
Joined: March 27, 2008 Posts: 693 Location: The Granite State
Posted: Thu Aug 21, 2025 4:54 pm Post subject: Re: Krylon close matches to factory colors |
| EverettB wrote: |
| I don't think he reported back. |
Too funny that I happened to run across this after so many years.
My apologies for not reporting back! I had to step away from the Bus for a while unfortunately. But now I’m back to getting stuff done again.
I did try the Rustoleum Antique White, as it was the only one I could find at the time. It turned out to be too off white/beige to match L90D.
I’m currently trying to find a match for Pastel White in the Eastwood/Summit product line. Has anyone used their off the shelf paints? _________________ Visit the Vintage Volkswagen Parts & Tech Wiki today!
'71 Westy "Maggie" - M-Plate
Parts for sale! |
Posted: Thu Aug 28, 2025 8:23 pm Post subject: Re: Krylon close matches to factory colors |
Rustoleum Colonial Red is a close match to Royal Red. I bought a can of it and did a few test spots on the fenders. I'm kind of thinking the matte paint with a *light* clear coat might be better than the gloss though.
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1637 Location: San Diego
Posted: Tue Sep 16, 2025 10:29 am Post subject: Re: Krylon close matches to factory colors |
This is very close to L87 Pearl White. I originally bought it for my headlight restoration. The can says "Ultra Matte", but it dries with a low sheen and looks much closer to Pearl White than the cap color on the spray can would suggest. You'd probably need to spray a gloss clear coat over it to make it work next to Pearl White body panels, but it's definitely worth a try.
This is how it looks on my headlight assembly:
_________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
