Steve M. Samba Member
Joined: July 30, 2013 Posts: 6926 Location: Fort Lauderdale, Fl.
Posted: Thu Nov 25, 2021 6:29 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Vintage Cibie Iode AIRPORT 35 fog lites fit the original Projektzwo as if they were made for it
Only drawback is finding a good set and they use H2 bulbs.
_________________ This free advice is worth exactly what you paid for it.
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2427 Location: Der Vaterland
Posted: Thu Nov 25, 2021 11:47 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Ok, that is interesting!
I'm going to need a breakdown of parts used (and numbers!), plus multi-angle pictures of the entire build (to include the unboxing of said parts!).
Hope it's not too much trouble.
Thanks!
THE SAMBA _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Crankey Samba Member
Posted: Thu Nov 25, 2021 11:48 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Team WorldTour wrote: |
Crankey wrote: |
What are these worth NOS ? |
NOS- Several hundred euros\ dollars.
TerraPodz- $200?
@Red Ryder- No, the Originals or the new TP, are only good at DRLs. (but, they look damn good doing it!)
@tsrhines- YES! Exactly as I meant! |
So you think the Facebook add for slightly used terrapods @ $380 is pie in the sky ?
I wonder which is made of more durable plastic.
I have the SA lower grill mounted. I got terrapods just because and to reward Eric's efforts to bring them back but they don't look as clean (the terra or projezwo version) as the SA grill so I never got around to mounting them. Don't remember the price on the TP lights.
In the city and suburbia I don't feel any need for more than just normal hella h4 but I want something with halos as drl and turn signal.
@Steve M. Nice work there !
Posted: Thu Nov 25, 2021 11:53 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I don't have a clue what is happening over on Facistbook.
I am also unaware of actual current prices.
What I can say, is that I've owned both. The originals sucked as far as build quality. The TPs are leaps and bounds better.
The TPs have polycarbonate lenses and ABS housing.
The originals don't. Also, impossible to find replacement parts for.
Which is exactly why, I suspect, the TPs were created. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Thu Nov 25, 2021 12:57 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Which is exactly why, I suspect, the TPs were created. |
I was referring to the link of the Facebook add for a pair just a couple posted beforehand.
For now I feel like I'll keep my pods in case the sa grill gets broken. The pods look better than just the standard short lower grill. For me they are mostly an appearance thing. |
Posted: Thu Nov 25, 2021 2:42 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I agree 100% it's an appearance thing.
They also do a fair job of DRL. I love mine. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
tsrhines Samba Member
Joined: September 03, 2021 Posts: 13 Location: Arkansas
Posted: Fri Nov 26, 2021 12:22 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Any idea where I can find new lenses? Mine are kinda rough… |
Posted: Fri Nov 26, 2021 2:08 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I don't, sorry.
I'm not personally involved with them, I'm just a satisfied customer. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Mon Nov 29, 2021 8:25 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
My TP are still working fine after probably 6 or 7 years (bought them when they first came out), but the driver's side lens has a wicked cataract. Guess the lens quality was different between the two lights. Too bad because they look pretty trashed now. All the LEDs are still working tho. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
maco70 Samba Member
Joined: March 16, 2011 Posts: 490 Location: Montréal, Québec
Posted: Wed Jun 08, 2022 4:24 am Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Hi to all,
Is someones know Where can I buy a replacement LED for my repros of Projektzwo, which as one side burnt
Thanks in advance ! _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
Timwhy Samba Member
Honuak Samba Member
1988M5 Samba Member
Joined: January 23, 2016 Posts: 843 Location: Tucson, AZ
Posted: Fri Jun 23, 2023 2:59 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Heads up, the stock while ones were only 5 watts, the amber you linked are a whopping 40 watts! I doubt there is enough space to dissipate all that heat. _________________ 1991 tin top GL
Some BMWs. |
Honuak Samba Member
Posted: Fri Jun 23, 2023 3:01 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
1988M5 wrote: |
Heads up, the stock while ones were only 5 watts, the amber you linked are a whopping 40 watts! I doubt there is enough space to dissipate all that heat. |
Ooops
wrong link
fixed it |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 205 Location: Molde, Norway
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1768 Location: Portland
Posted: Thu Sep 07, 2023 9:44 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
What type of bulb does the MMT3 Fog lights use? _________________ 1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy |
Tristar Eric Samba Member
Joined: July 25, 2004 Posts: 1262 Location: Portland, Or
Posted: Wed Jul 03, 2024 2:04 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I think this should get you guys excited. We are working on a glass lens TerraPodz V2. Using a Hella 550 lamp. Easy to find replacements if ever you should need one. Uses an H1 bulb or LED equivalent.
This is our proto test fitting right now. We've got a little tweaking to do then hopefully live in a month or two. Best part is that we manufacture our parts and have 100% control on quality and availability.
_________________ Vanagon/Transporter flares here: www.terrawagen.com
[email protected] |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12300 Location: Santa Cruz, CA
Posted: Wed Jul 03, 2024 2:21 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
I like the new design.
I have those lights mounted above the bumper on a bracket but don't like the look of them just hanging out there. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1936 Location: Vancouver Island, BC
Posted: Wed Jul 03, 2024 2:33 pm Post subject: Re: TerraPodz: Vanagon Projektzwo auxiliary light repros |
Looks great. Using off-the-shelf light source is awesome too. Especially given that the hella 550 is available in fog, driving, white, amber... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
