sblu Samba Member
Joined: April 08, 2019 Posts: 219 Location: Austin, TX
Posted: Fri Jun 14, 2024 6:55 pm Post subject: Red Light ON -> How to tell if its the alternator or Regulator |
Folks
I need to diagnose if its the alternator or regulator. Any pointers or suggestions beyond the steps in Muir? Once I have the steps and figured out which part I need, I'll come back to ask where best to source.
thanks again! _________________ 1978 Westfalia Champagne Edition Project |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17661 Location: San Diego, California
Posted: Fri Jun 14, 2024 7:33 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
I’ll send this to telford but as I told you before, you probably fried your alternator diodes. That said, Telford can tell you what to do. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3625 Location: San Diego (Encinitas)
Posted: Fri Jun 14, 2024 9:48 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
To diagnose, we remove the regulator from the circuit and run the alternator unregulated. Caution: to avoid damage, follow instructions EXACTLY!
1 - unplug the regulator
2 - make up a jumper wire about 4" long with a male spade terminal on either end.
3 - using the jumper wire, connect the red and green regulator connector wires together.
4 - connect a voltmeter across the battery.
5 - start the engine - DO NOT REV!
6 - while watching the voltmeter, slowly increase the engine speed. The battery voltage should increase. Do not let it exceed 15 volts. If it increases, there's a problem in the regulator. Otherwise, problem in the alternator. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Posted: Fri Jun 14, 2024 9:51 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
I knew that but needed to confirm, I’m kidding _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
KaiTown Steve Samba Member
Posted: Sat Jun 15, 2024 2:04 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
I’m sure the above troubleshooting will reveal a culprit.
However, I chased a no-charging issue back and forth between the alternator and regulator for several days. (Mine was no ALT light.) Troubleshooting indications on different days would send me different directions; bad alternator one day, bad regulator the next.
I would recommend you re-check ALL the connections, wire by wire to make sure they are where they belong and making good connections.
I double checked the alternator twice and bought a new regulator only to find that it was a bad connection (behind the dash) that was the problem.
I now re-lug anything suspect and verify every connection with a multimeter and in accordance with the wiring diagram. _________________ 1975 Bay Window w/ FI and Automatic Transmission |
sblu Samba Member
Posted: Sat Jun 15, 2024 10:57 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
telford dorr wrote: |
6 - while watching the voltmeter, slowly increase the engine speed. The battery voltage should increase. Do not let it exceed 15 volts. If it increases, there's a problem in the regulator. Otherwise, problem in the alternator. |
Finding:
Reving did not increase voltage (steady at 12.6V); so alternator is shot:
Its a camper, so first I need to pull the alternator to find out amperage/part number.
What is my best option now:
1. Replace with aftermarket -> saw a thread about B+ shorting through the alternator housing, so lots of concerns here
2. Repair mine -> Seems complicated, not sure I can source the diodes easily
3. Get mine repaired -> anyone providing this service on thesamba?
4. Get a used replacement -> who would have one?
Thanks folks!
PS, i'm having trouble removing the tin around the alternator (single slotted screw from the bottom, its stuck! trying different things: fun never ends  _________________ 1978 Westfalia Champagne Edition Project |
sblu Samba Member
Posted: Sat Jun 15, 2024 4:21 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Update: I was able to remove the alternator!
1. its an AL75X
was this the Factory Installed one? I believe campers had the higher amperage one? so want to make sure
2. I need to order the rubber boot as well, seems like it cracked, hopefully I can find a replacement
3. I noticed another 'wire' see regulator below, i believe its non-factory, can someone confirm? I had removed the Blue one as that was connected to the previous owner circuitry that caused a short a week ago, this particular one is going into the firewall, not sure where...
4. I lost the nut where the alternator pivots; I believe its 13mm. Hopefully its just a normal nut, and not 'square'...someone please confirm.
5. Here's the starter connection of the cable going to the alternator, hope all's legit and ok!
6. While removing the alternator, I found a broken wire cable that goes through a pulley, i believe...I'm not sure what that is, I'll start a separate thread on that, since its unrelated to the generator
Looking for some answers on my previous post to help with direction on what to do next. thanks everyone! _________________ 1978 Westfalia Champagne Edition Project |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1937 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Sat Jun 15, 2024 4:37 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
here’s the boot for the 55-amp alternator.
https://www.buslab.com/product-p/021903655b.htm
other vendors have it as well.
some buses came with the al108x (70-amp). i think those with eberspacher heaters. my ‘78 champagne westfalia had a 55.
upgrading mine to a 70 required some different tin, wiring, and plastic gasket.
as to the pivot-bolt nut. pretty sure it’s a 8mm hex. it just fits a 13mm wrench. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13534 Location: West Coast, USA
Posted: Sat Jun 15, 2024 9:36 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
That extra blue wire is the charge warning light wire to the dashboard. Without the idiot light coming on with the key, the voltage regulator won't get the signal to start regulating voltage.
Looks like disconnecting the batteries and polishing the starter connections would be time well spent, but congrats on having all good factory connections. Nothing like those ten cent plastic crimps on the biggest electrical junction on the car.
Count every terminal as they come off, so you don't forget one and start a fire. No need to disturb the other dirty 13mm nut on the starter unless you're rebuilding the whole thing.
Once the ring terminals are off, hold the crimped part of the wire with needle nose pliers while using a wire wheel in a Dremel on the ring faces. Nice and shiny? Put them back largest wire to smallest wire. And DON'T lose that 13mm M8 nut, it's thin, to remind you not to overtorque the starter connection.
I wire brush the upper spades, and use a pipe cleaner inside the push-on connectors. Do not connect any wires to a lower push-on lug. Some starters have an extra connection here and no VW uses them.
New Bosch AL75's are trickling onto the shelves. The X means rebuilt, I think. I would go that route for the warranty if you can get one. Otherwise, find the old stinky electric motor shop in town and ask around. It pays dividends to have local collaboration.
There is no concern about B+ shorting out, because you will check your replacement alternator regardless and adress it in one of two ways:
1) Cut the threads with a Dremel wheel after installing the wire and nut.
2) Drill a 1" hole in the backing plate exactly over the B+ terminal. Install a waterproof rubber plug in the hole, and now you're future-proof! Also go back and do step one.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
sblu Samba Member
Posted: Sun Jun 16, 2024 6:03 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Thanks Airscooled
Is there a particular plug you used? I really like that idea!
I’ll follow the rest of your post once I get the new alternator, thanks for the pointers! _________________ 1978 Westfalia Champagne Edition Project |
Bnanwel Samba Member
Joined: November 10, 2022 Posts: 308 Location: Ft Lauderdale
Posted: Tue Jun 18, 2024 4:23 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
No need for a separate thread for 6. the broken cable that goes the pulley. That is your thermostat cable which controls the cooling flaps. _________________ ‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe |
sblu Samba Member
Posted: Tue Jul 16, 2024 4:15 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
@airschooled,
thanks for your suggestions, I finally made the modifications to the alternator cover to clearance both B+ posts, also the nice flexible rubber plugs that I got from amazon fits really well https://www.amazon.com/dp/B07B7HHM1Q?ref=ppx_yo2ov_dt_b_product_details&th=1
I do have a question, you mentioned that in the future this might come in handy in case I am stuck and need to use an alternator from a FLAPS. Do you have any pointers on 'equivalent' alternators that cna be used in case I am in such a predicament in the future?
Posted: Tue Jul 16, 2024 5:37 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
There aren't any drop-in replacements that I know of, but most FLAPS will charge your battery for free…
As always, when given a "no," also ask about Porsche 914 alternators and other listings they have for your year VW. Some places list combinations of Campmobile, Transporter, Type 2, Microbus, etc.
www.airschooled.com
sblu Samba Member
Posted: Tue Jul 16, 2024 5:46 pm Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Thanks again
Now as I was putting it back together - ground the posts down and painted the exposed metal for the two holes to prevent corrosion - I need to source the two rubber boots that go around the harness - one that plugs into the alternator housing the other goes into the firewall - they’re falling apart
Anyone know if it’s available someplace?
sblu Samba Member
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24042 Location: NYC/Upstate/ROW
Posted: Wed Jul 17, 2024 12:00 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
That’s a premium rebuilt piece of junk.
Vintage auto electrics are best repaired by hunting for an “ auto electric shop” that caters to English cars, especially. These guys source parts that aren’t pot metal from overseas for armatures, diodes, bearings.
The warranty you get from the parts stores just means you have guaranteed junk in the box, not a good part. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
sblu Samba Member
Posted: Wed Jul 17, 2024 7:59 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Thanks @abscate
The order got cancelled because it was on back order
I’m in Austin, TX…not sure we have such a shop jere
I’ll try the classifieds on here - if anyone else has any tips where I can get one please let me know
Thanks! _________________ 1978 Westfalia Champagne Edition Project |
Posted: Wed Jul 17, 2024 9:01 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Looking at your breaks/discolorations in the original sheath, you're probably better off going new. Like Kyle's FI harnesses, this would take me hours to make and cost hundreds more. Buy it while you can:
https://www.busdepot.com/021971349f
www.airschooled.com
sblu Samba Member
Posted: Wed Jul 17, 2024 10:28 am Post subject: Re: Red Light ON -> How to tell if its the alternator or Regulator |
Thank you! Will do. _________________ 1978 Westfalia Champagne Edition Project |
