Nitty Samba Member
Joined: July 07, 2003 Posts: 488 Location: Farthest South
Posted: Sun Aug 19, 2007 5:58 pm Post subject: Gene Berg Pulley |
| I'm trying to install a Gene Berg pulley, but tapping it on, it doesn't seem to want to go flush with the end of the crankhaft. It's about 3/16" shy. However, even so, it looks to be prett closely aligned with the generator pulley. Anyone know what's right? Thanks. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80080 Location: Sneaking up behind you
Posted: Sun Aug 19, 2007 6:01 pm Post subject: |
The pulley doesn't fit flush with the end of the crank. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Sun Aug 19, 2007 8:08 pm Post subject: pulley |
| Ditto |
EZGZ Samba Member
Joined: October 10, 2005 Posts: 923 Location: Loveland, Colorado
Posted: Mon Aug 20, 2007 7:05 am Post subject: |
If you heat it up to around 200 degrees F it should slip on with little or no tapping if the engine is stone cold...... You don't have much time to dilly dally, Use winter gloves and move fast.
Berg pulleys are tight. _________________ 64 custom Ghia, 66 Bug, Sandrail, Barrien tub |
Blaubus Samba Member
Posted: Mon Aug 20, 2007 9:49 am Post subject: |
| Quote: |
Berg pulleys are tight |
and they are tight on purpose, dont go sanding the bore to make it easier |
jeff denham Samba Member
Posted: Mon Aug 20, 2007 4:19 pm Post subject: |
they have alwasy fit tight thats what is nice about them.like the guys said above they dont fit flush. make sure you read your famoes gene berg instructions comes with every part dont ya know . jeff d. |
porker buzz Samba Member
Posted: Fri Jul 26, 2024 8:39 am Post subject: Re: Gene Berg Pulley |
| are gene berg pulleys still made as been trying to find one for the last 2 years |
Glenn  Mr. 010
Bus boy 89 Samba Member
Joined: February 24, 2022 Posts: 39 Location: England
Posted: Fri Jul 26, 2024 9:26 am Post subject: Re: Gene Berg Pulley |
| porker buzz wrote: |
Might be best to speak to GBE direct, they are very helpful and I’ve always had fast delivery (I’m in the U.K. too)
However a lot of Berg stuff is no longer produced or is out of stock which is a great shame. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15602 Location: Deep in the 405
Posted: Fri Jul 26, 2024 12:28 pm Post subject: Re: Gene Berg Pulley |
Just because Berg has a current ad here on The Samba does not mean they have it in stock. I waited over a year for a power pulley sized equalizer. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1873 Location: Grass Pants, Orygun
Posted: Fri Jul 26, 2024 8:59 pm Post subject: Re: Gene Berg Pulley |
Have you called the Bergs? I have bought a few from them in the last 2 years. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/ |
Posted: Mon Jul 29, 2024 6:52 am Post subject: Re: Gene Berg Pulley |
| sent over 10 emails to gene berg enterprises never get a reply glenn it was the equalizer 440a pully i was after |
henrym Samba Member
Joined: August 19, 2006 Posts: 1010 Location: Marina Del Rey, California
Posted: Mon Jul 29, 2024 4:07 pm Post subject: Re: Gene Berg Pulley |
I've been trying to get one for almost two years. Allistar at Bergs keeps telling me they are waiting on the forgings, etc. Finally could not wait and went with one of Pat Downs own pulleys. _________________ 1967 Bug (Second owner) |
Posted: Fri Aug 09, 2024 10:53 am Post subject: Re: Gene Berg Pulley |
| do you have a picture of the pat downs pulley henrym they told me a year ago steel was to expensive and was going to make the next batch in stainless but still nothing is available |
John Connolly Samba Member
Joined: September 22, 2015 Posts: 58 Location: Sandy, UT
Posted: Fri Aug 09, 2024 4:13 pm Post subject: Re: Gene Berg Pulley |
https://www.thesamba.com/vw/classifieds/detail.php?id=2698043
This is mine, but it's extremely rare and desirable for someone with a performance aircooled VW. I have 1, and can ship in a day or 2. _________________ it's advice. If you don't like it, ignore it. Don't argue.
If you want no-BS technical advice privately, feel free to DM me. Donations appreciated (food gift certificates, etc). |
Glenn  Mr. 010
Posted: Fri Aug 09, 2024 4:15 pm Post subject: Re: Gene Berg Pulley |
Nice to hear from you, I hope retirement is treating you well. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Aug 09, 2024 4:18 pm Post subject: Re: Gene Berg Pulley |
Thanks Glenn! Riding a lot of mountain bikes and trying to scare myself without crashing too much. Nobody has hit me up for a burger yet either
| Glenn wrote: |
Nice to hear from you, I hope retirement is treating you well. |
oprn Samba Member
Joined: November 13, 2016 Posts: 15074 Location: Western Canada
Posted: Fri Aug 09, 2024 4:45 pm Post subject: Re: Gene Berg Pulley |
What's the fascination with the Berg pulley? If it's so hard to come by, anyone with a lathe can turn up a weight. Bolt to a stock pulley then go get it balanced.
In fact if you have a lathe, turn up a pair of cones with a wee set of bearings on the end of the cone shaft and you have a high point balancer for your pulley. Open your vice, set the bearings on top the jaws, get a felt marker and away you go. _________________ Our cars get old, we get old but driving an old VW never gets old! |
modok Samba Member
Joined: October 30, 2009 Posts: 27729 Location: Colorado Springs
Posted: Fri Aug 09, 2024 8:37 pm Post subject: Re: Gene Berg Pulley |
It's just a nice steel pulley.
Aluminum sucks, stamped steel works well but can get bent easily and hard to modify, iron works well but can be brittle, billet steel is the best.
Tho just imo, a good ductile iron pulley would be fine too.
Did empi stop selling steel pulleys?
I compared a berg and an empi, not much difference.
But berg was really tops in thier day. |
richparker Samba Member
Joined: November 24, 2011 Posts: 7653 Location: Durango, CO
