Smileydude Samba Member
Posted: Mon Jul 29, 2024 9:32 pm Post subject: Sliding door rubbing tire |
I have the gowesty lift, tires and rims.
Plus a burley rear disk brake kit.
I seem to have a slight rub on the tire walls from the sliding door now.
Is this normal? Any simple fixes?
E1 Samba Member
Joined: January 21, 2013 Posts: 8328 Location: Westfalia, Earth
Posted: Mon Jul 29, 2024 9:43 pm Post subject: Re: Sliding door rubbing tire |
Too-wide of wheel offset?
(We have same wheels, I think, they take 215/65-16)
Is the overall track width from brake disc face to disc face same as stock?
(It almost has to be)
Combo of both? _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman
Jonathan Weisheit, Race in Peace:
https://www.youtube.com/watch?v=z3dS7xiFn7I&t=500s |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 844 Location: Tucson, AZ
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18834 Location: Retired South Florida
Posted: Tue Jul 30, 2024 5:11 am Post subject: Re: Sliding door rubbing tire |
I purchased GW 16 alloys when I first put our van on the road. They bolted right up. The one measurement I had overlooked was the sliding door. It was close, but cleared the tire. Whew.
Anyhow, adding a brake disc in place of a drum does space the wheel further out. Didn’t click on the link, but I recall there was a do hickie that kicks the rear out somehow. |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 862 Location: Ontario, Canada
Posted: Tue Jul 30, 2024 6:21 am Post subject: Re: Sliding door rubbing tire |
Smileydude wrote: |
Rear disc kits space wheels out an additional 4mm compared to stock drums. That coupled with your GW wheels that have an ET23 offset are the problem.
If it were me, I'd get different wheels. Talk to Chris at T3 for recommendations on offset, etc. _________________ 74 Super
84 Westy |
Posted: Tue Jul 30, 2024 7:22 am Post subject: Re: Sliding door rubbing tire |
Also, rear disc conversions may require longer wheel lug studs. Did you replace those? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10399 Location: Orbiting San Diego
Posted: Tue Jul 30, 2024 7:24 am Post subject: Re: Sliding door rubbing tire |
The needless 7.5 width of the GW wheels makes it even worse.
Too bad we can't get 6" or 6.5" wheels in 16" with ET30-37.
Mark
boxer74 wrote: |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2009 Location: Montreal
Posted: Tue Jul 30, 2024 11:49 am Post subject: Re: Sliding door rubbing tire |
you can
2010 Tiguan |
Posted: Tue Jul 30, 2024 12:48 pm Post subject: Re: Sliding door rubbing tire |
Center bore too small.
Mark |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Tue Jul 30, 2024 1:06 pm Post subject: Re: Sliding door rubbing tire |
The Tiguan alloy wheel does need the center bore opened very slightly.
Very easy to do.
That one operation gives you a perfect bolt on wheel, with a center cap that fits, and a factory VW wheel, not an aftermarket Chinese wheel prone to cracking. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15387 Location: Syracuse, NY
Posted: Tue Jul 30, 2024 1:23 pm Post subject: Re: Sliding door rubbing tire |
some have used a router to open up the center of an aluminum rim.. should be able to find that in a search
I went this route.. a 65mm step drill
https://www.amazon.com/OCGIG-6-65mm-Spiral-Groove-Titanium/dp/B075K5TLN2 _________________
Abscate wrote: |
