The Lazy person's stupid Split Bus questions thread
70bus Premium Member
70bus is offline
PostPosted: Sat Jul 20, 2024 5:16 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
What sound does it make when you pull it?
and how many clowns roll out of the bus after the 'ahOOgah' sound?
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jul 20, 2024 6:25 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
LBSEA wrote:
What is this long black knob on my 64 bus?
Here's a Mini Cooper water squirter version.
https://www.7ent.com/products/washer-pump-manual-aftermarket-gww0102e.html
Stocknazi
Stocknazi is offline
PostPosted: Wed Aug 07, 2024 8:21 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Are the 64-67 split and early bay window (68-73ish) under dash heater trees interchangeable?
WANTED:
Thomas Jefferson
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Aug 07, 2024 9:18 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I'd say no! The Plump Truck is a very early '68 and the difference is considerably. However, being a hack myself, anything can be done! Razz
Pau
Pau is offline
PostPosted: Sun Sep 08, 2024 3:10 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Good night.
Even if seen many times, now that I need the information, I don’t find the answer.
How should be the cargo area of a '67 deluxe painted? Top color or below color? In my case cumulus white over seablau. Floor and bulkhead white and panels blue?
Thank you.
Pau
P.s. I have the example of my former 21w, but it was so poorly restored that I don’t trust that pattern.
Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!!
Malokin Martin
Malokin Martin is offline
PostPosted: Sat Nov 02, 2024 10:16 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I didn’t check the torque on the wheels often enough and wheel almost fell off the other day. Yadda yadda new drum and new lugs.
However now I’m wondering if I should chase the threads with the die instead of throwing them out. They’re originals. Maybe I’m just being crazy and need to let go. Thoughts?
70bus is offline
PostPosted: Sun Nov 03, 2024 12:24 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
A chase is different than a die; a chase just tries to re- form the thread profile, and a die cuts new ones. I think a die would mean a thinner, slightly smaller thread, which has less grip. I see lots of bolts with squared threads, and wonder how much holding power they’ve lost; I also hate tossing an OG part, but on the wheels… maybe find some nicer ones.
Only the threads up by shoulder look really bad, so maybe take to local shop for an opinion. Mine has a chase set and has redone a spring plate bolt for me (as opposed to new shiny garbage bolts they didn’t trust). Still holding tight.
Ps - there’s a fantastic book about fasteners by a racing guy, Carrol smith, that discusses threads and holding power. Pretty sure he’d advocate tossing for new, though.
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Sun Nov 17, 2024 11:07 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Rather than take mine apart, I am hoping someone knows this off the top of their head:
How deep are the headlight buckets in the nose of a 63 - 65?
Didn't find the info in a brief search.
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL is offline
PostPosted: Sun Nov 17, 2024 6:37 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I don't know but isn't '66-'67 allowed in that question?
70bus is offline
PostPosted: Sun Nov 17, 2024 6:49 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I wasn't sure if the shape changed in 66. Just wanted to make sure the measurement matched my 65.
Craig K
70 Neunsitzer
65 Pritschenwagen
Kb65single
Kb65single is offline
PostPosted: Mon Nov 18, 2024 5:59 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Deepest point 5 3/8". Both passenger and drivers' side matched. Straight edge used along the outer rims of the buckets. measured from a 65 SC
Ken
70bus is offline
PostPosted: Mon Nov 18, 2024 9:18 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Thanks Ken - I figured someone out there had their buckets empty. Sorry it was you :) Any progress on truck recently?
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Sun Nov 24, 2024 6:25 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I didn't get a good answer on the bay window 'stupid questions' thread, nor in searching - I'll try being stupid here:
will the 1/3 - 2/3 front seat covers I have from a 67 work on the 1/3-2/3 front seats in my 70? OK if not perfect, as what's on their now is shredded fabric and springs. I also have a decent set of backrest horsehairs, if they are similar enough...
Having spent too much on the 65, the 70 is getting any hand-me-downs that work.
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Dec 09, 2024 2:02 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
To place an answer for the next chea - ah, thrifty! - person wanting to know this: yes, the seat covers and pads from a mid-60s-up 1/3 -2/3 bus will fit an early bay (71 or so?), but the pads may need some trim work and the covers may not look factory.
If I get around to it this winter I'll post pics.
Craig K
70 Neunsitzer
65 Pritschenwagen
Who.Me?
Who.Me? is offline
PostPosted: Sun Feb 09, 2025 4:39 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Can you safely stick a sturdy round metal bar in the jacking point to lift with a trolley jack?
I started to try it with an old idler pin from the front beam a few weeks ago and it seemed to work OK, but I needed to raise the truck quite high at the rear on one side, so I chickened out and raised it on the rear torsion tube.
Would it have been safe to lift it like that, or is there a point at which a bar just slides out of the jacking point? The idler pin seemed to be a perfect fit (or as much as a round peg in a square hole can be), and it would have saved some faffing around.
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
BonTonRoulet
BonTonRoulet is offline
PostPosted: Sun Feb 09, 2025 11:05 am    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Search online for a "Porsche Jack pad" or the sorts; it's just a solid metal disc welded to a piece of square bar that fits in the factory Jack tube on the chassis of these old German vehicles. That being said, if I had access to a floor jack and a block of wood I'd rather lift the rear of the bus by the hoop under the transmission.
Never argue with an Idiot. They'll only bring you down to their level and beat you with experience.
70bus is offline
PostPosted: Sun Feb 09, 2025 12:12 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Many of the aftermarket jack points look more decorative than functional to me; OGs are often rusty shells. If i have a flat on firm ground I'd use one in a pinch but not to work on the car any length of time, and certainly not at any height.
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL is offline
PostPosted: Sun Feb 09, 2025 6:50 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
I made these and the gravity seems to always be down on them without a tendency to pull out.
Years later.
Malokin Martin
PostPosted: Thu Feb 13, 2025 3:16 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Less of a question and more of an observation:
It’s funny how I search for a specific part for a couple years and then, once I find it… 3 show up in the classifieds. Maybe it’s just me but… every… time.
PostPosted: Thu Feb 13, 2025 4:27 pm    Post subject: Re: The Lazy person's stupid Split Bus questions thread Reply with quote
Yes! Also the ones that show up later are in better condition for less money
Page 7 of 8
