Direction for a '52
Page: Previous  1, 2, 3  Next
type4split
type4split is offline
PostPosted: Sat Aug 24, 2024 12:57 pm    Post subject: Re: direction for a '52 Reply with quote
Does anyone have the ID of the transmission donut hole? I can’t find a replacement mount. So I’m going to buy a section of pipe and slice out what I need.
'67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts
type4split
PostPosted: Sat Aug 31, 2024 4:33 pm    Post subject: Re: direction for a '52 Reply with quote
Backed out of shop under its own power! . Driven for 1st time.
'52 beetle
'55 convertible
'63 "milo" beetle
vw356
vw356 is offline
PostPosted: Sat Aug 31, 2024 5:13 pm    Post subject: Re: direction for a '52 Reply with quote
Congratulations! Have fun in it and keep going on it!
Best of Luck!
Current projects:
1950's Volkswagens!
51,52,54's,55,56's,57,58's,'60's And then a bunch of '60's, but the '50's are my favorites..
Jacks
Jacks is offline
PostPosted: Sat Aug 31, 2024 10:49 pm    Post subject: Re: direction for a '52 Reply with quote
Is the gas tank in backwards?
Jack Staggs
Actual name
maplesyrup
maplesyrup is offline
PostPosted: Sun Sep 01, 2024 1:00 am    Post subject: Re: direction for a '52 Reply with quote
Love it!
Bugger
type4split
PostPosted: Sun Sep 01, 2024 5:30 am    Post subject: Re: direction for a '52 Reply with quote
Yes, gas tank is backward. Don’t know what happened there. Gotta flip it.
Still a lot to do:
I missed my local show by 2 weeks☹️, so a lot of projects over the winter. I need to lower rear a little. Probably need to order a new beam. Current one is -6” and too low.
'52 beetle
'55 convertible
'63 "milo" beetle
finster
finster is offline
PostPosted: Sun Sep 01, 2024 6:13 am    Post subject: Re: direction for a '52 Reply with quote
doesn't the donut give you the id of the hole if you use a profile gauge? or am I missing something...
looking great, a great view from your front garden! (with or without the car) Cool
type4split
PostPosted: Sun Sep 01, 2024 6:41 am    Post subject: Re: direction for a '52 Reply with quote
Finster, the donut would, however the body is on and I can’t get to it.
'52 beetle
'55 convertible
'63 "milo" beetle
robbiecanter
robbiecanter is offline
PostPosted: Sun Sep 15, 2024 10:19 pm    Post subject: Re: direction for a '52 Reply with quote
I had to repair the same thing on mine, I'm Sure it's under my name somewhere on here. But right after I did, I found someone who was making the metal mount piece. I will see if I can dig that up.
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
robbiecanter
PostPosted: Sun Sep 15, 2024 10:24 pm    Post subject: Re: direction for a '52 Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?p=8989460&highlight=#8989460
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
robbiecanter
PostPosted: Sun Sep 15, 2024 11:04 pm    Post subject: Re: direction for a '52 Reply with quote
Bbt and Gerson makes them: https://www.bbt4vw.com/en/catalogue/body-panels/chassis/chassis/torsion-tube-kit-5pcs/
52' Split
59' lowlight ghia
64' Bug-turbo
68' Notch
84' westfalia 1.8t
91' 2.9 vr6 coupe
my3bugs
my3bugs is offline
PostPosted: Mon Sep 16, 2024 9:24 am    Post subject: Re: direction for a '52 Reply with quote
im my 51 the heater cable wouldnt go thru the tube on one side , i hand filed the end to make it more rounded , sorta took the corner off the end piece and it made it thru .
type4split
PostPosted: Sat Sep 28, 2024 5:17 pm    Post subject: Re: direction for a '52 Reply with quote
Wiring tonight. Ugh…..
Could someone please give me details on the routing of the horn wiring and the electrical for brake master cylinder ?
Looking at pictures and other posts; I’m thinking they might go through tire well ?
'52 beetle
'55 convertible
'63 "milo" beetle
type4split
PostPosted: Fri Jan 03, 2025 9:45 pm    Post subject: Re: direction for a '52 Reply with quote
Just messing around with hood from my convertible ??
Someone cut the hood hinge attachment block of. I need to drill out spot welds and weld in new mounts.
'52 beetle
'55 convertible
'63 "milo" beetle
type4split
PostPosted: Mon Jan 06, 2025 6:09 pm    Post subject: Re: direction for a '52 Reply with quote
Looking for some advice and others experience regarding 6v vs 12v. I’ve installed a brand new (VWLOOMS) wiring harness. New battery cables. Starter is original bosch, but rebuilt Engine is a ‘58. With a 6v battery it hardly cranks.
Next thing is I need to purchase are semaphores. They are a decent size $$ investment. So I want to invest once,
So I’m trying to decide if I go 6v or 12v. The car is not restored, or will it be until I retire probably, so originality is not an issue. I just want to enjoy it and not have any issues if I want to drive it to a show 1-2 hrs away.
I guess my question is if I change to 12v what all do I need to change ? Regulator, bulbs are the obvious things. What else ? Dash pod is from John Henry.
'52 beetle
'55 convertible
'63 "milo" beetle
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Jan 08, 2025 1:05 pm    Post subject: Re: direction for a '52 Reply with quote
type4split wrote:
bolted in with rebuilt starter
Those seamed axle boots need to be turned, so that the seams are at or barley above the 9 or 3 O'clock position. Seam up at 12 O'clock will cause the boots to get torn up all too soon due to the axles flexing up and down.
Also tight the small clamp last on the boots, but just before you tighten those down push the small end of the boots toward the transaxle to keep the boots from over stretching and tearing when you jack the VW up to work on.
In Stereo, Where Available!
Jacks
Jacks is offline
PostPosted: Thu Jan 09, 2025 12:24 am    Post subject: Re: direction for a '52 Reply with quote
The starter bendix support bushing in the transmission may need to be replaced
Jack Staggs
Actual name
esde
esde is offline
PostPosted: Thu Jan 09, 2025 5:54 am    Post subject: Re: direction for a '52 Reply with quote
FWIW, I have been back and forth about the voltage choice for my 52 zwitter.
In the end, I have decided to do the following, which can easily be changed back to 6v if desired.
12 volt system, on a new harness. Running 12v to the stock 6v starter (works fine), 12v coil, bulbs, and 12v 90mm generator. I have Chip's LED kits for the heart taillights and will hide the flasher. I am running a voltage drop to the semaphores, and spent some money getting the correct rebuilt parts from Matt in Canada. Sometimes he can kit bash early parts onto later parts so they look correct but cost a little less. I think I have early arms and lenses, with later solenoids, or something like that. I've tried fussing with a friends car when he had trouble with the aftermarket semaphores, and the quality is not there for what they cost.
I'm hoping for easy to start and drive, and mostly stock appearance. I love my 6v cars but sometimes they are just a pain... the new to me 55 had me pulling my hair out every week.
modok wrote:
Blue Baron
VW Aficionado
Blue Baron is offline
PostPosted: Thu Jan 09, 2025 6:40 pm    Post subject: Re: direction for a '52 Reply with quote
esde wrote:
Running 12v to the stock 6v starter (works fine).
For now.
I chewed up ring gears on two different flywheels doing this. (If it were a good idea, the factory would have done it.)
Heinz Nordhoff
esde
esde is offline
PostPosted: Thu Jan 09, 2025 8:49 pm    Post subject: Re: direction for a '52 Reply with quote
Blue Baron wrote:
For now.
I believe you, but you're the first person I've heard of thats had a problem. Mine has been spinning since the 80's. Might have been through a starter or two since then but the flywheel is fine
Page 2 of 3
