1968 Squareback - The Keep-ening
Page: Previous  1, 2, 3  Next
Adoom
Adoom is offline
PostPosted: Wed Sep 25, 2024 9:10 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
busman78 wrote:
Yes, but with a type 3 the manifolds/carbs get a little toasty due to the confined engine compartment and the engine has a tendency to “run on / diesel” when shut down. The idle shut off solenoids solve that issue. You will be happier with them.
"Toasty" is very accurate. I've melted two plastic fuel filters (now being relocated out of the engine bay) in the engine bay. I should get one of those "manifold ovens" and install it in there for some meals on wheels!
1968 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Wed Sep 25, 2024 1:14 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Adoom wrote:
I'm wondering if this valve from CIP would do the trick.
https://www.cip1.ca/vwc-058-129-413-d/
I know it's not good to "just throw parts at it", but sometimes i just want to buy a part instead of dissecting them.
Actually, I think...I've already dissected this valve before now that I think of it. I got it working 6 or so years ago. So maybe I can fix it again, or just get a new one if I can.
I think it will. It looks like it has the correct brass end in comparison with your old one. Give it a try, as at this point you don't have anything to lose.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Adoom
Adoom is offline
PostPosted: Wed Sep 25, 2024 8:57 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Ok, got the choke element sorted and installed. I think it needed some ( a lot) of cleaning. Also, there was an impingement from the spark plug lead running to the rear cylinder causing the choke counter-balance to get stuck. I re-routed the wire, cleaned the element, and re-installed using ...instructions (gasp).
The idle cut-off is toast, so I adjusted the grub screw to "always open". I have ordered a new valve in the meantime.
With those back on the car, I turned the key, and maybe it was beginners luck, but it fired first turn of the key, sat there and idled until it warmed up.
While in there I noticed that both fresh air tubes are busted (new ones ordered). Also it's...just kinda dirty and somewhat rusty. Hoping I can make the time to strip the top-side of the motor one day and just clean/paint things to make it a little nicer.
I noticed the idle sounds...clunky, Like I have a mild cam (I don't). So I am posting a link to some video I took. Mind the vertical filming, I wasn't thinking. I did think enough to walk from side-to-side so you can hear it from all angles.
Feedback appreciated.
https://youtube.com/shorts/PwtqBnZ3dWE?feature=share
1968 Squareback
Tram
Samba Socialist
Tram is offline
PostPosted: Wed Sep 25, 2024 9:32 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Sounds like leaky exhaust and loose valve adjustment to me.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Erik G
Erik G is offline
PostPosted: Thu Sep 26, 2024 9:58 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
and a 009
check your timing, it needs to be about 30degrees at full advance (3200 rpms or so). About 2 1/2 "humps" to the right of TDC. If you need help, ask. I have posted pics here somewhere
Adoom
Adoom is offline
PostPosted: Thu Sep 26, 2024 10:03 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
It's actually not a 009 (thankfully, I did have one of those in my bus for a couple of flat spotactular years), but noted on checking the timing. Looks like I need to dig out my timing light.
1968 Squareback
Adoom
Adoom is offline
PostPosted: Thu Sep 26, 2024 1:02 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Turns out is was just beginners luck. This morning I was back to the same old starting routine. Took 4 tries to fire. I will need to address the timing tonight. Then I will need to wait for a cool morning to adjust the valves. (might as well change the oil then too).
Getting there.
1968 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 27, 2024 12:24 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
It's amazing how well these engines run with a little attention paid to them. It seems like they just need a little love thrown at them and they'll respond in kind. You're gaining on it, and all it's costing is a little time. Wink
Tram wrote:
Tram wrote:
Mike Fisher
Mike Fisher is offline
PostPosted: Sat Sep 28, 2024 11:27 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Getting there.
Don't expect 50 year old cars to start instantly like new computer controlled cars!
I prime my 69 FI/AT square 4 times before trying to start it when cold.
Starts instantly if it's warm!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Sun Sep 29, 2024 12:37 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Getting there.
Sounds like the fuel is either vaporizing when sitting over night, or right after shut down, and you're having to crank it over a few times to re-prime the fuel bowl. If you have a low pressure fuel pressure gauge, you might want to check your output pressure of the pump (tee it in the fuel line). You're looking for 3.5 psi fuel pressure. This is similar to my vapor locking the 3 mechanical pumps on my own car, and why I went to a low pressure electric fuel pump. Just a thought.
Tram wrote:
Tram wrote:
Adoom
Adoom is offline
PostPosted: Tue Oct 01, 2024 6:44 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
I keep getting shocked by this distributor! Which I *think* is a major factor in it's poor running/starting.
When I was 16 I had a '79 rabbit that was misfiring, occasionally, but not always. Drove me nuts. One night my dad suggested spraying a mist of water over the ignition and to look for arcs. My plug leads lit up like Christmas.
So last night I did the same. By ouchy feel cylinder #3 is live to the touch, but by misty eye, cylinder 2 is also arcing.
1968 Squareback
Erik G
Erik G is offline
PostPosted: Tue Oct 01, 2024 11:28 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
there you go, I thought it was distributor related Smile
I do check my cars in the pitch black every once in a while.
Adoom
Adoom is offline
PostPosted: Wed Oct 02, 2024 8:51 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
I hate "throwing parts" for the sake of throwing parts, but a lot of this car is "pre-me" so I don't know the actual age or condition of a lot of it. SO, I just ordered a new cap, wires, condensor, and coil.
Coil: the spark is super weak when it IS in the points. I've had this coil for a long time as a spare for my old bus, so I think grabbing a new might be a nice-to-have.
Cap: when I was turning the distributor for timing, I was initially getting mostly shocked by #3 & 4. The cap *looks* ok, but for $15 its peace of mind.
Wires: see photo, also I don't know if the shocks are coming from wires or cap. Actually, now that I think of it, I replaced the wires 4 (ish) years ago with a set from Rock Auto. You'd think they would last longer than this.
Consdensor: the weak spark thing got me wondering. I know there's been a production issue in the past with condensers, AND I know the condenser I have won't seat in the distributor hole properly or securely. I'm willing to try a new one in hopes of getting some blue or white spark instead of orange.
Hoping everything will be in by the weekend (wishful thinking) so I can get this thing running properly.
I will say that when it's running on all 4 and *NOT shorting out, it sounds pretty nice. I put the new fresh air hoses on, changed the oil and adjusted the valves.
Now I just need it to...run properly.
Oh I also upgraded the seat belts.
1968 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Wed Oct 02, 2024 1:17 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Sounds like you've been busy. I've had several condensers fail from sitting. but they've also been non Bosch units. Jim Adney says the older Bosch ones last the longest, and since you're getting bit by the plug wires, I'd say they're working just fine. Maybe you need to replace the plug wire boots at the cap instead.
Tram wrote:
Tram wrote:
Adoom
Adoom is offline
PostPosted: Sun Oct 06, 2024 4:13 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
It's a good thing my hair falls out on its own, otherwise I would be pulling it out.
New day, new parts. Installed a new cap, wires, and condenser. Also a new coil.
Same sh!77y routine. Fires right up.. when cold. Moment it's been running for a bit it has no interest in firing.
I'm really scratching my head here. I've replaced all the "sparky stuff". Adjusted the valves, timing is on point. Changed the oil in the bath.
I think this might be where I'm headed next. I don't own a fuel pressure gauge, and have no experience switching from mechanical to electric fuel pump.
Here's why I **think** it may be fuel related. I was taking it for a drive today, me and the dog went up some pretty big hills (for around here). The car was really displeased with going up any thing hill related. I thought "huh, seems weaker than usual". But on the way home, going down some big hills, it was acting like we were running out of fuel. At a stop light I had to continuously feather the throttle to stop it from dying, and then shortly after...it sputtered to a stop on the side of the road.
After much feather, cursing, and turning over, it finally caught, and we were on our way...cautiously. We made it home, but I'm really wondering if we have a fuel issue.
If I go with a fuel pump, I found this, would this be the way to go? How did y'all wire it in?
https://www.cip1.ca/c10-41-2010/
https://www.cip1.ca/c26-127-205/
Thanks in advance!
1968 Squareback
Zwitterkafer
Zwitterkafer is offline
PostPosted: Sun Oct 06, 2024 5:04 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
The fuel tank screen filter is clean beyond suspicion? Sometimes the fuel pump is still OK but can't compensate for reduced flow from the tank.
- Zeuxius, 400 BC
Adoom
Adoom is offline
PostPosted: Sun Oct 06, 2024 5:51 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Good thinking, I think mine dissolved long ago
1968 Squareback
Adoom
Adoom is offline
PostPosted: Sun Oct 06, 2024 8:38 pm    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Call it mild frustration infused obsession, I pulled the mechanical fuel pump.
When I first tried manipulating it manually it was barely moving, and there was a bunch of crud built up in and around the actuating foot.
I sprayed some carb cleaner in the foot area and some chunks of i dunno what, came out. Then I sprayed some cleaner into the inlet and outlets and tried manipulating it by hand and boom it broke free and shot gas/cleaner a good 3 feet across the yard (uh, whoops). Now it pushes, a lot.
Then I measured the rod, on which the tip has slight mushrooming. It comes in at just 106mm, maybe 106.5mm, which is only 1.5-2mm shorter than it should be...but that is still shorter than I expected.
So I think, maybe, it was thirsty. I'm going to order a new $4 rod and see if that was the issue all along.
1968 Squareback
busman78
busman78 is offline
PostPosted: Mon Oct 07, 2024 6:14 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
A quick test is after running the vehicle and you get home, after about thirty minutes pull the #2 spark plug (easiest to get to), if it is wet and soaked with fuel you are either boiling the fuel in the bowl or the needle valve is not seating completely and the residual pressure in the mechanical pump floods the carb(s), or both. Both scenarios will leave the cylinders charged with excess fuel and starting right off difficult.
Things to try, penolic spacer between the intake and carb, electric fuel pump with cut off so fuel will not flow when not running and idle solenoid shut off valves, any and all will aid in the T3 Carb Cook-off Syndrome.
edit - Another quick test is after the vehicle has been turned off for 20-30 minutes wrap the palm of your hand around the fuel bowl of the carb, a good way to test how hot it has gotten.
Erik G
Erik G is offline
PostPosted: Mon Oct 07, 2024 9:31 am    Post subject: Re: 1968 Squareback - The Keep-ening Reply with quote
Make sure your trans ground strap is good and connected the right way too
Page 2 of 3
