Carpet
Max Welton
Max Welton is offline
PostPosted: Tue Oct 08, 2024 11:19 am    Post subject: Carpet Reply with quote
I'm starting to lay out the carpet kit I got from Sewfine. On the underlayment ... does it basically go only on the horizontal surfaces? Or should it also go over the tunnel and up the sides?
Max
1967 Type-3 Fastback
Bobnotch
Bobnotch is offline
PostPosted: Tue Oct 08, 2024 2:43 pm    Post subject: Re: Carpet Reply with quote
Max
It actually goes over all 3 surfaces. I normally start up on the front wall, then do the sides, (working my way back) followed by the rear kick plates, then the main floor last. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Max Welton
PostPosted: Tue Oct 08, 2024 3:51 pm    Post subject: Re: Carpet Reply with quote
Thanks! I've never done this before.
Here's a walk-around of the kit.
https://youtu.be/MsmDu5L_HO8
Some questions to start.
Does the padding get glued to the back of the carpet?
On some (particularly vertical) pieces, do I glue the pad to the painted car? I'm looking particularly at the piece at the rear of the frunk.
What kind of glue? 3M super99?
Max
Erik G
Erik G is offline
PostPosted: Tue Oct 08, 2024 4:28 pm    Post subject: Re: Carpet Reply with quote
I'm not sure what the current preferred product is, I'm sure some 3M glue I used to use can't be had any more. Also originally there were tiny nails.
WCM has them www.westcoastmetric.com/i-22964315-carpet-nails-fo...odels.html
Max Welton
PostPosted: Tue Oct 08, 2024 4:36 pm    Post subject: Re: Carpet Reply with quote
Yeah, not going with nails. Spent too much effort sealing things up to start poking holes.
Max
Ossipon
Ossipon is offline
PostPosted: Tue Oct 08, 2024 4:54 pm    Post subject: Re: Carpet Reply with quote
So when I did it earlier this year, I used 3m Super 77 initially. I would not use that. I ended up using vinyl carpet adhesive for almost every location. That actually seems to work even for the verticals and under the dash bits. I did use props and braces to hold the verticals and slants in place while the adhesive set.
That said. I did not use adhesive on the floor sections. I wanted the ability to lift them up if they get wet.
I did not use the OG fiber sound deadening for the floor but the same foil/rubber deadening I used in the door and other locations.
No carpet nails. I did use Velcro strips for that section behind the foot pedals to hold the slope and verticals in place. It seems to work okay thus far.
Ossipon
--Two truths in life: Volkswagens Rust and everything will die at some point --
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 /Taos 24... And don't about me and my experiences with my Dasher and Quantum
Max Welton
PostPosted: Tue Oct 08, 2024 5:03 pm    Post subject: Re: Carpet Reply with quote
Velcro sounds like a great idea in several places.
Max
squaretobehip
squaretobehip is offline
PostPosted: Tue Oct 08, 2024 5:08 pm    Post subject: Re: Carpet Reply with quote
I left a few comments on your video before watching you figure it out. Laughing
It's weird that they make all the pieces separate like that. My kit from TMI years ago has a the front floors + the tunnel, same with the rear floors + tunnel. This makes it easier in my opinion, as I just velcro'd those floor pieces and the weight of the floor pieces held the tunnel down. Also, the rockers being separate from the front wheel wells is a new one to me too.
I glued the front firewall, front wheel well + rockers, and the rear seat kick panels. The floors+tunnel were just laid in there with velcro. I have not done front frunk carpet, or rear trunk carpet. I've always tried to keep the original trunk liner or that style.
1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Max Welton
PostPosted: Tue Oct 08, 2024 5:10 pm    Post subject: Re: Carpet Reply with quote
Thank you sir!
What would you use for adhesive?
Max
squaretobehip
PostPosted: Tue Oct 08, 2024 5:12 pm    Post subject: Re: Carpet Reply with quote
Max Welton wrote:
Thank you sir!
Max
In my Notchback that I just did, it only uses 3 pieces...which made it way easier than yours! Laughing I used some Gorilla glue spray adhesive. The vinyl pieces on the front wheel well pieces get glued to the door channel opening, then held down with the pinch welt. You were on the right track on the video.
Follow ISP West on:
Max Welton
PostPosted: Tue Oct 08, 2024 5:23 pm    Post subject: Re: Carpet Reply with quote
Very helpful. Thanks! I like my carpet, just trying not to screw it up.
I see your wiring around the fuse box is about like mine. I've been thinking about making a panel or something to contain the nest a little bit.
Max
squaretobehip
PostPosted: Wed Oct 09, 2024 8:58 am    Post subject: Re: Carpet Reply with quote
Meh, you can only really see that from down low. There's a lot going on there in that corner, I try not to disturb anything.
Follow ISP West on:
Bobnotch
Bobnotch is offline
PostPosted: Wed Oct 09, 2024 12:23 pm    Post subject: Re: Carpet Reply with quote
Max
Keep in mind that VW used Velcro to hold the floor carpet in place on the later cars (69 on for sure).
Tram wrote:
Tram wrote:
akokarski
akokarski is offline
PostPosted: Thu Oct 10, 2024 7:45 am    Post subject: Re: Carpet Reply with quote
Max,
I wish I knew not to use 3m as well. There is an upholstery guy on youtube that covers that as well. But you need a spray gun..
Anton
squaretobehip
PostPosted: Thu Oct 10, 2024 9:08 am    Post subject: Re: Carpet Reply with quote
akokarski wrote:
Max,
Anton
We use this at ISP and it's pretty fantastic. You do need a compressor and a spray gun but contact adhesive like this beats whatever you can buy off the shelf.
Follow ISP West on:
NerdyGunny
NerdyGunny is offline
PostPosted: Thu Oct 10, 2024 9:14 am    Post subject: Re: Carpet Reply with quote
like shown above... contact cement is great!
i have used a Critter Siphon gun before.... they're very cheap and can be used with a a normal small compressor.
here's an example...
https://www.amazon.com/gp/product/B00006FRPJ/ref=a...e&th=1
Tip: the spray tip will occasionally get clogged so you'll need to keep a needle to clear the blockage
Tip: spray on the surface, and spray on the back of the carpet and let it sit... 5 minutes works great... just let it get tacky.
Max Welton
PostPosted: Thu Oct 10, 2024 9:34 am    Post subject: Re: Carpet Reply with quote
Well. Looks like I'll need to get a spray gun. Recommendations?
Nevermind. That critter thing looks OK.
Max
NerdyGunny
PostPosted: Thu Oct 10, 2024 12:02 pm    Post subject: Re: Carpet Reply with quote
Max
i just saw that the one on amazon is about $50... check harbor freight... i bought mine for about $15...
i would check youtube on how it should work.... it doesn't "spray" a mist of contact cement...it sort of spits it in a sort of a fan...
use a test piece of cardboard and fine tune the adjustment.
Bobnotch
Bobnotch is offline
PostPosted: Thu Oct 10, 2024 2:31 pm    Post subject: Re: Carpet Reply with quote
akokarski wrote:
Max,
Anton
When I did my T-34, that's what I used. However I also used a plastic butter container (cleaned of course) and a 2 inch brush, and brushed it on (both the car and the carpet). That seemed to work pretty good for me, and allowed me to fine tune the fit of the carpet. By using the butter bowl like I did, I was able to pour some of the glue into it, as use only what I needed to at a time (controlled the fumes I had to breathe).
Tram wrote:
Tram wrote:
Max Welton
PostPosted: Thu Oct 10, 2024 3:19 pm    Post subject: Re: Carpet Reply with quote
So I've ordered the gun and the contact cement. We'll see how it goes.
For the main interior floor carpet and rear foot well parts my plan is to glue the padding to the carpet and then to sit the combination on the floor with no further securing mechanism. That way I can easily remove them if they ever get wet or just require cleaning. Recall that I applied a type of bedliner material to the top and bottom of the pan.
For the side pieces and the tunnel coverage ... those may get glued down as will the piece up under the steering column and drain hoses. Also the kick-panel sections and the vertical pieces under the rear seat.
Up under the frunk ... I may not even install those. It looks so nice all clean and such. I might change my mind there.
Now for the back. Recall that there's this padded material that also came with the kit. I think it's supposed to go under the roof before the headliner. I'm already past that point. The roof got the same sound-deadening I put on the doors.
But I think this stuff would do nicely on the rear load-deck around the engine hatch, raising the level to just about to that of the cover. Then the carpet/padding combination can be laid over the top and up the bulkhead secured by velcro.
What do you all think?
Max
