WVDriver Samba Member
Joined: May 18, 2024 Posts: 10 Location: West Virginia
Posted: Mon Aug 19, 2024 9:26 am Post subject: 63 VW Beetle |
Thought I had an alternator issue because the idiot light was coming on periodically. Turned out that the idiot lights were wired up backwards. Corrected that problem but that left me with an oil pressure issue. Installed a new oil pressure relief valve and spring to fix that issue. One of the idiot light bulb holder electrical legs was broken, so I ordered a used speedometer off of ebay. The plastic portion on the ordered holder fell apart in my hand when I removed it but the electrical connector was good. I drilled out the rivet holding the connector in and transferred it to the plastic holder on my speedometer. |
TOTSKI Samba Member
Posted: Tue Aug 20, 2024 2:34 pm Post subject: Re: What did you do to your Beetle this week? |
I drove it to the beach. Perfect weather here at SF 😎🌞
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 1113 Location: Yuba City CA
Posted: Tue Aug 20, 2024 3:37 pm Post subject: Re: What did you do to your Beetle this week? |
far rider wrote: |
Nice work. When you paint the car will you do interior and exterior at the same time? |
Yes I did
can't really tell in the pic though
_________________ Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
indianpeaksjoe Samba Member
far rider  Samba Member
Joined: August 30, 2005 Posts: 935 Location: Rutland, VT
Posted: Thu Aug 22, 2024 6:57 am Post subject: Re: What did you do to your Beetle this week? |
Used a cable, long enough to reach the far end of the tank , to Roto
rooter my ‘61 tank. You can see some of the crud and scale knocked off after one pass. _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
trektider60 Samba Member
Joined: October 30, 2012 Posts: 78 Location: SE Indiana
Posted: Wed Aug 28, 2024 5:36 pm Post subject: Re: What did you do to your Beetle this week? |
Not many miles on the new carb; runs great on the road. Last two trips to town with a few different stops and the carb was flooded after setting 5 minutes. So I finally got a fuel pressure gauge and found 4.5 psi. Got the pressure down to 3.0 psi with the addition of 3 more gaskets. Seems much better now. _________________ 1960 Indiana Red T1 |
Posted: Sun Sep 01, 2024 7:27 am Post subject: Re: What did you do to your Beetle this week? |
I loaded up the mountain bike and hit the trail.
-Joe _________________ Adventures in owning a 66 beetle |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71483 Location: Phoenix 602
Posted: Sun Sep 01, 2024 6:05 pm Post subject: Re: What did you do to your Beetle this week? |
Thanks Everett. This is the furthest I drove the beetle since I (yes, totally me) caused a stalling issue with a mod I made incorrectly. So you know, the bike wasn't only for riding the trail, but possibly to ride home if it broke down
Everything went great, only peddled on the singletrack !
Posted: Mon Sep 23, 2024 5:44 am Post subject: Re: What did you do to your Beetle this week? |
Got it painted. I’ve been stressing but it came out pretty decent. I can only add- the work is in the prep. Hours and hours of sanding. Also I sprang for the Harbor freight black widow HTE gun- $180. But glad I did
Posted: Wed Sep 25, 2024 8:37 pm Post subject: Re: What did you do to your Beetle this week? |
Awesome work far rider.
I painted my lower fenders with bed liner, the rocks on my road are destroying them. So far this is working.
Posted: Wed Sep 25, 2024 8:53 pm Post subject: Re: What did you do to your Beetle this week? |
I parked it the other day to walk out the next morning with oil leaking from the passenger side trans area. I tightened the hose clamps on the boots and hope that’ll fix it. Ordered new ones too, because I have a hunch that won’t work
bandi Samba Member
Joined: August 24, 2005 Posts: 1100 Location: Campbellford, Ontario, Canada
Posted: Tue Oct 08, 2024 8:01 pm Post subject: Re: What did you do to your Beetle this week? |
Well, haven't had much time to work on my own Beetle(s) but I did realize the Fuchs wheels from my daughter's Playmobil Carrera 2.7RS fit on her Beetle.
I feel like this is important stuff.
If only they could bring out a 356 so I could put some slotted steelies on a Bug. _________________ '60 Canadian Standard, '64 Bug, '66 Bug, '66 Bus, '69 Sunroof Bug, '71 Super, '72 Super, '73 Canadian Custom, '73 Super, '74 Love Bug, '83 Mexi Bug, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S. And some Fieros. |
Posted: Wed Oct 16, 2024 12:14 pm Post subject: Re: What did you do to your Beetle this week? |
Ran a new wiring harness. Didn’t go smooth but it’s in. _________________ 67 zenith blue sunroof
Posted: Thu Oct 31, 2024 10:14 am Post subject: Re: What did you do to your Beetle this week? |
Painted the gas tank. Used Max-Flex Victory blue satin. Closest I could find to a blue-grey. It’s actually a little lighter in color than it appears _________________ 67 zenith blue sunroof
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 613 Location: Triad Area NC
Posted: Thu Nov 14, 2024 6:54 am Post subject: Re: What did you do to your Beetle this week? |
Added a backup wire for the front hood latch release in case the primary wire ever fails or jams. The new wire is under the car, tucked away in the wheel well but can be pulled out through an existing drain hole when needed. |
benthere7575 Samba Member
Posted: Mon Nov 18, 2024 1:06 pm Post subject: Re: What did you do to your Beetle this week? |
rewired for 12v, but I can't find a diagram of how to wire the potentiometer that's mounted behind the speedo. I also can't find a diagram of how to wire the oil pressure gauge. It looks like the previous owners cut the wires to these devices and pulled the leads, so I can't even match wire to for the voltage reducers. |
shum Samba Member
Joined: January 03, 2012 Posts: 46 Location: santa cruz
Posted: Sun Nov 24, 2024 11:14 am Post subject: Re: What did you do to your Beetle this week? |
Time to replace the original front shocks, only 57 years on these. Nice Sunday project.
_________________ 57 rag top, 67 bug, 73 Thing
70 Bronco U14, 73 Bronco U15
61 R69S/2 BMW, 73 R75/5 BMW |
