BJT Samba Member
Posted: Mon Mar 11, 2019 8:33 pm Post subject: Pedal activated brake light switch |
Anyone have experience using this or installing in a Thing?
https://www.thesamba.com/vw/classifieds/detail.php?id=2140061
I have slow to light brake lights and was going to swap out OE hydraulic switches for new, quality, ones but this switch just might be a better fix... |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2811 Location: The World's Motor Capital
BJT Samba Member
Posted: Tue Mar 12, 2019 5:28 am Post subject: Re: Pedal activated brake light switch |
Thanks, I tried searching the forum before I posted the topic, not sure why I didn’t see this topic before. Thanks again |
kenj06 Samba Member
Posted: Tue Mar 12, 2019 3:52 pm Post subject: Re: Pedal activated brake light switch |
I installed the kit last year and it worked through the summer. I was happy with it since as others stated, I could stop the car without activating the brake lights and was told several times my brake lights weren't working just to find they were. The addition of the kit allows the lights to come on before you are even applying the brakes, depending on how it is adjusted.
Grabbed some pix:
I kept the wires together from the switch, split the red off and connected to the terminal block near the brake fluid reservoir. You can see the terminal block and red wire - crimped in the other 2 wires that were originally in there. Then ran the black along the harness up to the fuse panel.
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2013 Location: Athens, TN
GI Joe Samba Member
kenj06 Samba Member
Posted: Wed Mar 13, 2019 5:45 pm Post subject: Re: Pedal activated brake light switch |
GI Joe wrote: |
Whoa!! I need to come back to the ol’ Samba more often.... |
Good to see you back! |
GI Joe Samba Member
GearHeadKeith  Samba Member
Joined: January 14, 2003 Posts: 112 Location: Detroit, MI
Posted: Mon May 13, 2019 1:49 pm Post subject: Re: Pedal activated brake light switch |
KenJ06: Thanks for the pictures! I had not installed one onto a Type 181 yet. Thanks for this contribution and sharing your positive experience with my pedal-activated brake light kit. _________________ Keith Gilbert - DdK
1971 Super Beetle sedan, Shantung yellow with black interior. Cosmetically unrestored with over 366k miles.
1776cc: 9.2:1 compression, dual Weber 40DCN on Deano intakes, Primo Petrucci 40mm/36mm round-port heads, Crower VW284F cam, Kymco 1.5" exhaust
SSC trans with 3.78/2.25/1.48/1.04 & 4.12 Gleason R&P, Type IV output flanges, Berg Shifter
Topline front struts/springs/sway bar, Sway-a-Way rear bar, 4-wheel disc brakes
Owned since 1994: 3rd owner since new! |
Posted: Mon May 13, 2019 6:55 pm Post subject: Re: Pedal activated brake light switch |
Just for fun, here's an old drawing of wiring for the aux. brake light switch.
In a Thing, this is very simple; one wire to the brake light fuse, and the other wire to the connector right at the fluid reservoir next to the pedals. The "two-into-one" connector is just like the one Beetles use for the back up lights; you can buy them new, but there's probably one in your junk drawer.
As usual, thanks to Captain Spalding for letting me steal vector objects from his artwork. |
Posted: Mon May 13, 2019 7:10 pm Post subject: Re: Pedal activated brake light switch |
Mondshine: Great minds think alike! Mine kit is wired the exact same way. The benefit of my kit is that it is a bolt-in to the existing pedal assembly and "hides" behind the accelerator. I did not want it to be visible. _________________ Keith Gilbert - DdK
Posted: Tue Jun 11, 2019 8:41 pm Post subject: Re: Pedal activated brake light switch |
I now have a web store where you can purchase this brake pedal activated switch directly: www.aircooledevolution.com/products _________________ Keith Gilbert - DdK
Posted: Tue Jun 11, 2019 9:19 pm Post subject: Re: Pedal activated brake light switch |
Just got mine, will install this week. |
vwbri51573 Samba Member
Joined: August 22, 2007 Posts: 29 Location: Long Island, NY
Posted: Wed Oct 23, 2024 7:44 am Post subject: Re: Pedal activated brake light switch |
Hey, interested in this kit. Can this switch be installed without removing pedal assembly in a 1963 beetle?? |
Posted: Wed Oct 23, 2024 11:11 am Post subject: Re: Pedal activated brake light switch |
Yes.
Only the rear-most bolt must be removed. That's the bolt which holds the switch mounting bracket in place. |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1696 Location: Nebraska
Posted: Sat Nov 09, 2024 5:49 pm Post subject: Re: Pedal activated brake light switch |
My brake lights quit working and it is the sending units. I am cleaning the reservoir, installing all new fluid and changing the sending units. I have discs on the front and ordered a Harley switch to see if the threads are the same. Ghia has discs and uses the same sensors. |
