perello Samba Member
Joined: April 15, 2005 Posts: 893 Location: where social security comes for free
Posted: Mon Sep 09, 2024 3:18 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
That roller is definitely pitted. Where'd you get the replacement? |
Got the from beam replacement from Puebla factory of Mexico
also checked suspension arms
and saw there is an offset, however is the same on both sides
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7509 Location: Houston, Texas
Posted: Mon Sep 09, 2024 8:47 am Post subject: Re: 1200 in need of some TLC |
perello wrote: |
heimlich wrote: |
Does it say on the box where it was made? I have mine made by a company that bought the old TRW tooling.
Those are nice beams you have. I have a handful of them (VW Mexico) but someone had drilled and slotted them for adjusters. I have to undo that so I can use them. _________________ www.vwnos.com [email protected]
Posted: Thu Sep 26, 2024 2:26 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
Not really, but looks exactly as the 40 years old one I am replacing (same markings everything)
After many hours of preparation, needed to fabricate myself a missing ring tool on the lathe, I finally was able to remove the lower ball bearings (that and 10 tons of pressing)
1974 German Thing
1978 Bug 1200 |
Posted: Mon Nov 11, 2024 4:48 am Post subject: Re: 1200 in need of some TLC |
some more randomupdates, unfortunately I lost some photos from my phone...
front beam is back in, and mounted all the front
on the meantime I received a refubrished thermostat which allows me to finish the engine
then jumped to the back of the car, mounted the gerbox and replaced wheel cover seals
and started installing new cunifer brake lines
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Mon Nov 11, 2024 9:22 am Post subject: Re: 1200 in need of some TLC |
Nice thermostat. Have you been hibernating? _________________ www.vwnos.com [email protected]
Posted: Thu Nov 21, 2024 3:31 am Post subject: Re: 1200 in need of some TLC |
heimlich wrote: |
Have you been hibernating? |
I wish
but no, just things go slow, but hey I am progressing
after phospho acid, zinc primer and DP40
and figuring out how a will make a reinforcement part at the side as the one that was there...
[img][/img] _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Thu Jan 02, 2025 3:11 am Post subject: Re: 1200 in need of some TLC |
some xmas time updates
After having the top rocker sides done, started with setting up the floor pans (left side)
but I still found some rust that was not under my radar
used the seat to check alignement of the seat rails, the piramid suppor will be welded with the pan in place
so I position the pan to help aligning the bottom side of the rockers previoust to weld.
I am quite happy with the quality of these WW pans, far better to ones I used on My Thing in the past.....[/img] _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Tue Jan 14, 2025 8:53 am Post subject: Re: 1200 in need of some TLC |
some new parts get in
mocking the side runners to make sure all gets properly aligned before welding
I discovered the use of clekos from the samba, how could I live without 'em?
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Tue Jan 14, 2025 9:44 am Post subject: Re: 1200 in need of some TLC |
perello wrote: |
It's like sliced bread. I got close to buying some for one project but just used rivets instead to hold everything in place. For a large project I would definitely buy them. _________________ www.vwnos.com [email protected]
Posted: Mon Apr 14, 2025 5:10 am Post subject: Re: 1200 in need of some TLC |
not much pictures, but I took some time to have the left side floor properly aligned, nw=ow its ok and its a matter of weld, weld, weld
g
also had some fun bluing bolts
1974 German Thing
1978 Bug 1200 |
Posted: Mon May 12, 2025 6:20 am Post subject: Re: 1200 in need of some TLC |
some random updates...
been cleaning and checking the distributor
also renewing all rubbers at the rear z-bar
1974 German Thing
1978 Bug 1200 |
heimlich  VWNOS.com
Posted: Mon May 12, 2025 8:36 am Post subject: Re: 1200 in need of some TLC |
That is a well-used distributor. Looks nice after you cleaned it up. _________________ www.vwnos.com [email protected]
Posted: Wed May 21, 2025 2:11 am Post subject: Re: 1200 in need of some TLC |
engine almost ready
was missing this important bit
1974 German Thing
1978 Bug 1200 |
