redeyeksc Samba Member
Joined: October 14, 2012 Posts: 116 Location: guelph, ON
Posted: Sat Apr 25, 2015 6:07 pm Post subject: |
I'm wishing I had gone Burley after seeing this. My GW bumper and trailer hitch look like a noodle after carrying 4 bikes across the east coast. The way the GW hitch mounts to the vehicle is a joke. _________________ 84 Westfalia, now with Bostig Zetec 2.0L, Manual Transmission
Alex |
madspaniard Samba Member
Posted: Sat Apr 25, 2015 9:25 pm Post subject: |
Howesight wrote: |
... there is a LOT of slack/adjustment room in the attachment points where the fibreglass bumper is fastened to the factory VW brackets. Every installation of Burley's excellent hitch will involve some fiddling with the notching in the fibreglass. His template has to be considered a guide. Measure five times, cut four . . . slowly. |
Absolutely correct and exactly word by word what I was going to say, this was also my experience when I installed mine a while ago. The hitch is really amazing, very very strong attachment to the van's frame. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Vnyd Dog Samba Member
Posted: Fri Aug 28, 2015 12:31 pm Post subject: |
Can the Burley hitch be mounted onto/into an older style GW aftermarket steel bumper? The ones they did before offering the hitch? Has anyone done it or does it require too much cutting up of their bumper? |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Fri Aug 28, 2015 7:07 pm Post subject: |
Vnyd Dog wrote: |
I have not seen the GW bumper mounts..
Burley's hitch replaces the OEM VW bumpe brackets/mounts.. and the OEM bumper bolts onto/over the Burley hiitch brackets.
Can you take some pics of your GW bumper mount?
Where there's a will, there's a way. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
Posted: Sun Jun 23, 2024 9:36 am Post subject: Re: "NEW" Burley behind-bumper hitch |
Buggeee wrote: |
The plan is to carry two e-bikes on the back for me and the missus so I wanted a proper receiver hitch that could bear some weight. Here is my experience installing the
Burley Motorsports Heavy-Duty, High-Clearance Trailer Hitch for Fiberglass Bumper under the fiberglass bumper-shaped body panel that hides the muffler:
It arrived well wrapped, with Grade 10 bolts, and a neato sticker for the tool chest:
Staging the pieces before assembly gave a clear contrast between the stock tow-hook brackets and the Burley receiver hitch. Looking closer at the meager bent-wire tow hooks really confirmed for me that this was the right move - that hanging something off the tow hooks is not the way I wanted to go while carrying stuff off the back of the Westy on the interstates.
The Burley looks worthy of its rating for 350 lbs. tongue weight:
So the first step was to cut a hole in the fiberglass to clear the receiver, and Burley provided a PDF download that prints on a 8x11 paper at real size to use a template, if you like. Its intentionally a tight fit so you can clearance more as you need. I decided right away that this was going to be an exercise in frustration for me so I ditched the paper template in favor of some measuring tools.
I measured the distances involved relative to a known point - the internal bolts for the fiberglass cover, and found that two round molding injection blobs were in just the right place for me. This provided me with some clearance around the hitch penetration, plus reinforcement at the corners of the cut to help avoid future stress cracking.
I drilled two smaller holes towards the bottom inside the injection blobs (as with sheet metal, I'm thinking a rounded edge in the corner helps avoid future cracking). Then I eye-balled some lines using a straight edge and then cut a rough square out of the fiberglass with the little pneumatic hacksaw. From there I used a curved-edge die grinder flap disc to dress the opening to its full size. It all went without a hitch (sorry, had to do that somewhere in this post).
I bolted the fiberglass to the Burley and mounted it to the van. I found that the fiberglass side-caps for the bumper interfered with the wheel opening so I re-assembled it with some spacers between the fiberglass cover and the Burley. These spacers are from a TV wall mount or something, and serve as an opportunity to tell the youngsters why it is that old men save all extraneous hardware bits in a cookie tin on the workbench.
The end result is really satisfying. The Burley fits like the quality American Made Hand-Built piece of Art that it is, meaning all the welds are beautiful, all bolt holes line up perfectly, and the symmetry to the van and bumper cover leave an OEM impression to the system.
_________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
eugenev Samba Member
Joined: November 19, 2018 Posts: 101 Location: Riverside
Posted: Thu Jul 11, 2024 11:47 am Post subject: Re: "NEW" Burley behind-bumper hitch |
Bungee, can you comment on how the van rides with the two ebikes on it? I'm in the market for setting something like this up and worried about the squat it will have. I'm thinking I will still go for air bag helpers.
Got any images of the van with the bikes on it?
TY _________________ 1986 Savannah Beige tin top GL 2.1 manual... sold
1990 White Westfalia 1WD |
fxr Samba Member
Joined: December 07, 2014 Posts: 2646 Location: Bay area CA
Posted: Thu Jul 11, 2024 12:19 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
You'll never notice a couple of e-bikes. We use an electric scooter lift to carry a Vespa with the Burley hitch - no complaints from the van.
_________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Oct 08, 2024 5:27 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
eugenev wrote: |
TY |
fxr wrote: |
This is correct. There are pictures of the bikes on it in my Big Time Westy thread in my signature block.
For a real test, check it out with a 1984 Yamaha BW200 with a transplanted 2-stroke engine out of a Blaster quad. The Westy rolled a steady 70 mph for hours in each direction without difficulty. Felt good in corners too, not getting pulled around.
Buggeee wrote: |
Enhanced with a Burley Motorsports heavy duty receiver hitch, Westy and I stole away for an indulgent weekend together.
It's my understanding that the hitch is rated at 350lbs at the ball, which would be 6 inches off the face of the receiver. I cut down my motorcycle rack to center the bike at 10 inches from the face of the receiver, and loaded it up. My bike, fully wet, plus the the rack, weigh about 320 if I recall. Anyway, it worked.
After getting it loaded for the trip, I had about an hour of sunlight left to play with so hit a little cruise in spot.
Saturday morning I met a new friend while waiting for my buddies a rest stop
Then tore it up all day before heading home. Left everything on the trail!
4Gears4Tires Samba Member
Posted: Tue Nov 12, 2024 9:43 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
Nice job. How much weight do you think that you were pulling? 2500lbs? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
alexvbugman1 Samba Member
Joined: July 18, 2005 Posts: 37 Location: Crown Point, Indiana
Posted: Wed Nov 13, 2024 2:15 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
Buggeee wrote: |
Well it's no bug hunting rig, but the Burley Hitch and my Vanagon got the bug home on local country roads after breaking a fan belt.
Is that a Rathbun enterprise trailer? Looks like one I bought back in the early
90s out of Michigan. |
Posted: Thu Nov 14, 2024 3:08 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
4Gears4Tires wrote: |
Nice job. How much weight do you think that you were pulling? 2500lbs? |
I don't know what the trailer weighs, but I would imagine 2,500# wouild cover the situation. It's balanced pretty good with the engine out back - so not a lot of tongue weight.
alexvbugman1 wrote: |
I did pull this trailer out of Michigan a while back, but was told by the guy that he and his buddy built it to pull small English sports cars to road courses. One was an engineer with a CAD system used to draw it up, and they welded it together. It does look professionally built, has trailer brakes, a nice low deck height on a dropped axle, and is perfectly proportioned for what we do. I've pulled buses on it too, but a Bay is as big as I would go, would think a Vanagon is just over the line (hope to never find out that Ha Ha!). _________________ Big Time 1988 Vanagon Westy
Matt & Stan the Van ' Samba Member
Joined: June 04, 2022 Posts: 15 Location: NOVA SCOTIA, Canada
Posted: Wed Jul 16, 2025 6:32 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
Has anyone posted a reverse engineered fabrication design/plan for this Burley hitch? I live in Halifax and to get the Burley hitch delivered from California, after taxes, shipping, USD exchange rate, is about $2600 CAD +, which feels a bit crazy and beyond my budget. With a drawing I could get it fabricated locally.
Any leads, anyone? Thanks very much. _________________ 1988 Vanagon named Stan the Van, purchased by my mom new, then I got it from her in 1996. Finally learning to take care of him now!... |
Posted: Wed Jul 16, 2025 8:18 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
What I am planning on doing with my Westy is welding a 2x2 steel beam across the bumper supports. Then welding a 2" hitch to the bottom of that. Then adding 2 triangle gussets. Functionally it should be very similar to the Burley hitch and should be relatively easy to make. I see that Burley slotted and slightly bent their 2x2 beam, but unless that's 100% necessary I don't plan on doing that.
The extension to reach the 3rd bolt hole is nice, but it's not needed. On my Syncro I welded a Jeep bumper to the Vanagon bumper supports and put my dirt bike on it. I added soft straps around the tail gate hinges and then ratchet straps to the rack. If you wanted the 3rd bolt hole, it's just flat bar stock with a nut welded to it. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12304 Location: Santa Cruz, CA
Posted: Fri Jul 18, 2025 11:10 am Post subject: Re: "NEW" Burley behind-bumper hitch |
The factory tow bars that I am aware of all use the 3rd hole |
kamzcab86 Samba Moderator
Posted: Fri Jul 18, 2025 1:10 pm Post subject: Re: "NEW" Burley behind-bumper hitch |
Matt & Stan the Van ' wrote: |
Any leads, anyone? Thanks very much. |
What about shipping it to a Maine location (perhaps even to a Vanagon owner who lives there), then picking it up, or even installing it, there? That would save roughly CA$1000. Just a thought. _________________ ~Kamz
2016 Golf GTI S
