My 87 syncro build
Page: Previous  1, 2, 3  Next
chillzombies
chillzombies is offline
PostPosted: Mon Nov 25, 2024 6:28 am    Post subject: Re: My 87 syncro build Reply with quote
So unfortunately the previous owner seems to have done quite a few upgrades that are nice such as stainless steel coolant pipes BUT they were installed with wire and these weird twist clamps I do not trust. How are these usually secured? I have P clamps but I’d liked secure them the OEM way if possible, if not I’ll throw P clamps on the pipes and hoses.
Also I ordered the BMS billet front control arms as they had a Black Friday sale so that’ll be a nice upgrade to fix my alignment issues.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Nov 25, 2024 7:14 am    Post subject: Re: My 87 syncro build Reply with quote
I used zip ties. Wires are probably fine too in terms of holding the pipes in place, but I don't like getting stabbed in the eye with a wire end while I'm looking under my van.
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon Nov 25, 2024 1:35 pm    Post subject: Re: My 87 syncro build Reply with quote
These are the best pics I have of the two clamps that hold the main coolant pipes to the body:
Up front it's a stiff wire that hooks into holes in the structure.
And in back it's a screw band clamp around a cradle type mount on the frame.
My new pipes are aluminum so I painted them and used a rubber sleeve to protect, but here's another view of the rear clamp.
P.S. I would get rid of those cheap worm clamps and replace with stock constant pressure spring clamps for your hose/pipe connections.
https://www.buslab.com/product-p/n0164091.htm
Currently:
chillzombies
PostPosted: Fri Nov 29, 2024 10:57 am    Post subject: Re: My 87 syncro build Reply with quote
Yeah I’m not a big fan of that style of clamp especially this cheap one with the knob attached. I like the spring style clamp you showed (OE style) but sadly those can’t be installed without taking the whole coolant system apart. I have access to really nice high end silicone style worm clamps, so I may just swap those on for the time being as I’m not draining my coolant anytime soon, but when I do, I’ll go thru and replace all of the sub par clamps.
I found an AHU engine from a friend upstate, so
Hopefully I’ll be picking that up after the holidays. Also found a guy somewhat local with TD syncro mounts, which apparently bolt up to an AHU. So while my goal was an ALH swap, I think this might be the cheaper, easier and more direct swap to at least get me running and driving on diesel power. Down the line if I have time and the motivation I can upgrade to an ALH, or a common rail even.
chillzombies
PostPosted: Mon Apr 07, 2025 7:05 pm    Post subject: Re: My 87 syncro build Reply with quote
It’s been a couple months since I’ve updated and that’s mainly bc it’s been cold and I’ve made zero progress since I don’t have a garage to work in sadly. Regardless I have some funds to purchase a mount kit and I need to figure out which engine I’ll be running. I want to do an ALH TDI as I’m very familiar but can’t help but think a 1.8t would be great as well. The 1.8t apparently doesn’t fit under the engine lid which I’m not a fan of. Wondering if a short runner intake manifold could remedy that or not.
Currently deciding on which big brake kit to purchase and I think I’ve landed on small car performance’s kit. I like the Wilwood kit but unsure if it’s really necessary. Seems like the girling kit should stop really good as well.
Went out to Vegas to see Dead and co at the sphere, saw this in the hotel parking lot amongst other vans and RV’s.
chillzombies
PostPosted: Fri Apr 18, 2025 5:37 pm    Post subject: Re: My 87 syncro build Reply with quote
Ordered the front big brake kit and rear disc conversion from small car performance today.
I didn’t get the Wilwood kit as much as I wanted to, it would’ve been about double the cost which I’d rather buy the engine mount kit and an engine swap and get that going even tho wildwood’s would feel quite nice I’m sure. Found a set of Mercedes CLK wheels I’m hoping to pick up this week as these brakes require 16’s. Also found a 1.8t so I’m hopefully making that trip to pick that up soon.
chillzombies
PostPosted: Sun Apr 20, 2025 5:14 am    Post subject: Re: My 87 syncro build Reply with quote
Drove up to Massachusetts and grabbed this set of 4 Mercedes wheels, ordered a 5th off eBay when I got home. Ordered center caps and lug nuts from t3. Gonna have them powder coated bronze and then throw some 215/65/16 fallen wild peaks on them.
chillzombies
PostPosted: Wed Jun 11, 2025 9:25 am    Post subject: Re: My 87 syncro build Reply with quote
Due to multiple delays for one reason or another I’m finally picking the wheels up from powder coat today. Gonna to throw them on the van when I get them home. I also got the t3 center caps for them powder coated as well so should look nice.
Now that I finally have the 16’s, I’ll be able to install the small car big brake kit and rear disc conversion. Lots of work to be done this summer. Hoping for a bunch of camping trips this spring in upstate NY, so I gotta get cracking.
chillzombies
PostPosted: Thu Jun 12, 2025 5:30 am    Post subject: Re: My 87 syncro build Reply with quote
Picked up and installed the wheels after work. I like them, I think they’ll look even better after I have the van painted green. The ride was much smoother and quieter too.
Now that I finally have the 16’s on I can do the front big brake kit and that will much improve the braking/drivability of the van. Rear disc conversion after that and then I’ll do all the suspension work. Found my springs were a lot rustier than I thought so I’m going to just order a new set to be safe to install with the new bilstein b6 suspension.
TomInAlaska
TomInAlaska is offline
PostPosted: Thu Jun 12, 2025 9:37 am    Post subject: Re: My 87 syncro build Reply with quote
Those wheels look fantastic! Cool
And I've got the same tires and have been very happy with them.
'73 Super Beetle (formerly resto-mod/rally look with a healthy 1776, currently in another round of resto with a 1641)
'84 GL adventure van project [sold] (1.9L, 4speed) https://www.thesamba.com/vw/forum/viewtopic.php?t=755844&highlight=
'86 Syncro tintop (2.0L Eurospec/ABA engine swap) https://www.thesamba.com/vw/forum/viewtopic.php?t=800194&highlight=
4Gears4Tires
PostPosted: Thu Jun 12, 2025 8:38 pm    Post subject: Re: My 87 syncro build Reply with quote
That wheel color and wheels look awesome!
chillzombies
PostPosted: Sat Jun 14, 2025 9:23 am    Post subject: Re: My 87 syncro build Reply with quote
Thanks! I’m really happy with how they turned out, I haven’t driven on them much but the quick ride I took they were super quiet and smooth, van felt different in a good way!
Thanks! I’m happy they’re back so I can get the big brake kit installed and start driving it more!
chillzombies
PostPosted: Mon Jul 14, 2025 8:47 am    Post subject: Re: My 87 syncro build Reply with quote
Finally had a day off where the weather cooperated. Pulled front brakes off to inspect, passenger side was metal on metal which I suspected from
The grinding that started just after buying the van. And the drivers side the pads just crumbled. I think this van was sitting a bit longer than I was told, which is whatever at this point just gotta roll with the rust, I mean punches. After pulling it apart I saw my disc shields crumbled so I ordered 2 new ones from small car performance. I also have 2 front axles on the way so I’ll sway those out too since I’m here. So this has become a full overhaul quickly. I have the burley control arms, new upper and lower ball joints, and new bearings. Trying to bang all this out at once so I don’t have to deal with it again for a little while at least.
chillzombies
PostPosted: Tue Jul 22, 2025 7:47 am    Post subject: Re: My 87 syncro build Reply with quote
Well before I install the new big brake kit from small car I wanted to paint the calipers so they don’t rust within a week. Found this nice dark green paint kit on Amazon and gave it a shot. Needless to say the colors not even close but at least the calipers won’t be rusty.
New front axles came in a few days ago, the new stainless dust shields came in yesterday. I didn’t love how rusty my lower control arms were so I ordered a new set from Gowesty. So now I’m just waiting for the new front lower control arms and then I’m going to try and install everything at once.
dougnlina Premium Member
dougnlina is offline
PostPosted: Tue Jul 22, 2025 8:44 am    Post subject: Re: My 87 syncro build Reply with quote
Popcorn
"Grover" a '87 Syncro Poptop 1.8T
"Olive" a '60 Ragtop Beetle (retired)
"Kermit" '79 Westfalia (retired)
"Patches" '72 Beetle (retired)
"Wilbur" '69 Camper (retired)
"Bernice" 67 Beetle, My first love, (Also Retired)
chillzombies
PostPosted: Tue Jul 22, 2025 4:29 pm    Post subject: Re: My 87 syncro build Reply with quote
So funny enough basically right after posting this morning I received an email from my apartment complex stating that my van in jackstands was a safety hazard and had to be off stands immediately. I informed them I was waiting for parts and would take it off asap.
So I got home and figured I’d just put the new brakes on the front and put the wheels back on for the time being so they leave me alone.
And here’s some pictures of the crusty control arms that I’ll be replacing soon.
I didn’t put the calipers on fully just mocked it up for a pic. I need to bring home a 22mm wrench to tighten the carrier bolts a bit more to be happy. I wish I had all the parts so I could just do this all at once as planned but such is life.
4Gears4Tires
PostPosted: Tue Jul 22, 2025 10:59 pm    Post subject: Re: My 87 syncro build Reply with quote
Oof, those do look pretty crusty. But that metal is seriously thick. If you can grind/blast them down to good metal, they'd probably clean up just fine. Are you going with GW repros?
Painted calipers look good!
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jul 23, 2025 12:07 am    Post subject: Re: My 87 syncro build Reply with quote
I was just looking for some inspiration of colors for doing a set of CLK wheels, and thought to myself, how would it be copper color? No later than this morning driving to the shop.
How perfect, thanks for sharing your build!
chillzombies
PostPosted: Thu Jul 24, 2025 7:31 am    Post subject: Re: My 87 syncro build Reply with quote
Thanks for coming by and taking a look! Happy to inspire people, happy to motivate anyway to get out and wrench a bit and happy to shoot the shit with other van people! Just added you on Instagram this morning!
Yeah I gotta the go westy repro’s en route to me now. Exterior doesn’t look too bad but I know they rot from the inside out too so whatever I’d rather have newer more durable parts anyway, especially since I’m doing the billet burley upper arms anyway. They’re definitely not great but I wonder if someone would want them.
chillzombies
PostPosted: Sun Aug 03, 2025 6:19 am    Post subject: Re: My 87 syncro build Reply with quote
New GW lower control arms came in, they’re pretty nice. I wish burley still made lower arms I would’ve like to have burley upper and lower but these will certainly do the trick. I got new lower ball joint inserts just to be safe as everything on this van is pretty rusty or beat, but that’s life.
Hopefully be able to get some stuff done next weekend, as the is weekend I was busy.
After inspecting the rear trailing arms, they’re not great either so I may just replace them too so the suspension will be “done” and hopefully not need to be revisited for a while.
Page 2 of 3
