schwim Samba Member
Joined: May 18, 2008 Posts: 312 Location: Coastal VA, 'Murica
Posted: Wed Nov 27, 2024 9:19 am Post subject: question regarding starter wiring |
Hi there everyone,
I am hoping to get the start/charge connections made and I've forgotten the wiring between the starter and gen. I've got the two connections made from the front of car to the regulator and I've got the run from the regulator to the starter connected at the reg but I'm confused about two connections. First, the start wire female spade: there are two male spades on the starter relay. Does it matter which one the start wire connects to? Second is the wire from pos on regulator to starter relay: should that be on the same post as the positive battery terminal or on the other post active only during start?
Thanks for your time!
_________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1296 Location: GILROY, CA
schwim Samba Member
Posted: Wed Nov 27, 2024 10:00 am Post subject: Re: question regarding starter wiring |
| Wayne S. Johnson wrote: |
| The wire in the second picture goes to the top solenoid terminal with the 13 mm nut. |
Thanks for the help!
So same as positive battery cable, sending power to the regulator all the time?
Also, do you happen to know if it matters which of the two spades I connect the start trigger wire to? The old starter only had one spade if I remember correctly. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33407 Location: Hot Arizona
Posted: Wed Nov 27, 2024 10:49 am Post subject: Re: question regarding starter wiring |
| schwim wrote: |
| So same as positive battery cable, sending power to the regulator all the time? |
Yes.
| schwim wrote: |
| Also, do you happen to know if it matters which of the two spades I connect the start trigger wire to? The old starter only had one spade if I remember correctly. |
Fine where your photo shows it now. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
wdfifteen Samba Member
Posted: Wed Nov 27, 2024 11:52 am Post subject: Re: question regarding starter wiring |
| schwim wrote: |
Actually, it's sending the power the generator created from the regulator to the battery.
| schwim wrote: |
I assume you mean the two male connectors on the solenoid. It makes no difference. |
.65vw Samba Member
Joined: August 06, 2008 Posts: 133 Location: Washington - East of Seattle
Posted: Wed Nov 27, 2024 12:14 pm Post subject: Re: question regarding starter wiring |
Hey Schwim!
Good to see you are still bugging around. Me too! |
schwim Samba Member
Posted: Thu Nov 28, 2024 12:26 pm Post subject: Re: question regarding starter wiring |
| .65vw wrote: |
Hey Schwim!
Well, hello there
I'm working on ending my reign of the title of longest disassembled driver(in my zipcode).
Hope you're doing well, it's great to see you still having fun. _________________ Zippy the Wonderbug's achingly slow meandering toward roadworthiness |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1054 Location: South Florida
Posted: Thu Nov 28, 2024 6:03 pm Post subject: Re: question regarding starter wiring |
| wdfifteen wrote: |
| ... the two male connectors on the solenoid. It makes no difference. |
Don't be so sure about that. Solenoid can have 2 male spade terminals that are electrically identidal (VW #50); like here:
But the solenoid in the picture posted by schwim has its 2 male spade terminals far apart, probably not electrically the same. At least one of them is the VW #50 connection from Start position of ignition switch. The other could very well be VW #15a, which connects to positive terminal of ignition coil. I call it a "quick start hot wire" because of the effect it has had upon starting my engine since recently installing a starter solenoid that has this extra terminal. I love it, and posted about it here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=10121633&highlight=#10121633 |
