philippe1 Samba Member
Posted: Thu Nov 28, 2024 2:49 pm Post subject: need help to install AA rockers ratio on 36 hp omd speed |
does anyone had ever had some issues to install AA performance 36 hp rockers shafts 1,15 on a 36 hp engine?
problem is that the pushrods cut to lenght hit the pushrods tubes and make the play adjustment impossible !
the pushrods are 9,6 mm diameter
do i have to use another type of oushrods a bit thinner?
thanks for your help
Joined: June 24, 2015 Posts: 855 Location: Rialto. CA
Posted: Thu Nov 28, 2024 11:07 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
Looks like you may need to machine the heads and the case for the 1600cc pushrod tubes I would buy the spring loaded jaycee pushrods if I were you .......or weld and machine the head tube hole up but the tubes rely on the tubes to drain the oil back to the case so that will be a problem...best bet is just to machine case and head to the later 1600cc tubes ..or look for speedwell rocker arms those seem to have no clearance problems ....looks like these aa 1.25 rockers they just shorten the lower pushrod side up ....without off set mounting ...these aa rockers need the head and case modifications to the bigger wider pushrod tube for clearance....just one headache after another for a person who has there case together you may need to tear the engine apart for the machining or look for speedwell rockers which are offset " pushrod/adjusters are centered to the stock 36hp pushrod tube hole".... |
Posted: Thu Nov 28, 2024 11:52 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
thanks jerry you are absolutely right ! they will finish in the trash hpw can they sell parts that will not fit without warning the potentials buyers? crazy .. do you know where ths Sppedwell rockers are available? best |
Posted: Thu Nov 28, 2024 11:59 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
That's new product with no info ..it's all about the $$ ..sad part is that folks will find out and be like wait I need to do this and that now for this product.... no good ..... speedwell rockers pop up here and there speedwell usa seems to have been long gone website has nothing but try emaing ray from speedwell usa.. maybe he will reply and maybe have a set of rocker arms .. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7662 Location: europe
Bengt H Samba Member
Joined: September 11, 2005 Posts: 334 Location: Sweden
Posted: Fri Nov 29, 2024 1:17 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
I had the same problem. I made pushrods from the 8 mm tubs of the 36hp pushrods. They cleare the pushrodtube with a minimum. |
Posted: Fri Nov 29, 2024 1:22 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
This do not work, they are narrower than the originals  |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7824 Location: Videbaek Denmark
Posted: Fri Nov 29, 2024 5:30 pm Post subject: Re: need help to install AA rockers ratio on 36 hp omd speed |
philippe1 wrote: |
You are using 3/8" cromemoly pushrods. That is a no go, and no need for anyway, unless you are reving it to 6 grand or more... You need to cut and shorten a set of stock pushrods and they will clear. But as Bengt says, it is tight. Another solution is to cut the heads for 34 hp pushrods. But most people don“t like to have to do that. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
KOMBI NIKO Samba Member
Joined: February 03, 2013 Posts: 323 Location: Australia
