DIY Wheel Alignment
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
StellaBlueWesty
StellaBlueWesty is offline
PostPosted: Thu Jun 06, 2024 6:41 pm    Post subject: Reply with quote
rubbachicken wrote:
Bassyaks wrote:
Great write up, but spend the $40 and have it done on a Hunter Machine
You have too much free time Very Happy
Steve
FNGRUVN wrote:
Sure, you can take it to a tire shop where some dude that's probably hung-over, making $10/hr and hates your stupid foreign car will beat on it.
Do it yourself and you at least know you tried to do it right. That's more than I can say about a lot of "professional" alignments I've seen.
X2 i've paid out for someone to do an alignment in the past, it came back little or no better, i argued they said i must have hit something to knock it out of alignment
money wasted Sad
now i have seen how, i will be happy to do the job myself
and know it's done right
thank you loogy
I suppose it depends on the shop you use and the technician in the shop, but we have definitely been fleeced on alignments for more than one vehicle.
I am very appreciative that someone would dedicate their time to help the masses have the choice.
Respect 🙏🏻 gratitude,
RicMcK Premium Member
RicMcK is offline
PostPosted: Mon Jul 29, 2024 6:19 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
I've read most of the this thread, and I have a few questions. I'm about to do the front and rear bushings, ball joints, tie rod ends springs, and shocks all the way around.
My questions:
After the installation of new bushings, springs and shocks. Do I do an alignment, then drive it for a bit, then redo the alignment? Or is there a "preferred method"?
I have a pretty flat gravel parking area. Can I do the alignment on this surface? I'm thinking I could put pieces of plywood or concrete pavers under each tire that the vinyl squares can sit on.
How do I set up the rear end adjustments? I do not see any details on Samba.
I'm planning on doing the front castor via the cube level on the steering knuckle, (from T3TRIS) , and check it with the +- 20 degrees method. Then I will make a triangle rim jig from some scrap rectangular tubing and bolts, with digital levels. For the camber /castor. Should I get one of those alignment level tools or are 2 digital levels on the wheel jig ok?
I've read different ways to do toe in. What's the "best" method ?
Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window (first car)
58 split window bug - long gone.
RicMcK is offline
PostPosted: Mon Aug 12, 2024 10:24 am    Post subject: Re: DIY Wheel Alignment Reply with quote
Another question. Do I need to lift the tire off of ground to make caster or camber adjustments on the front, and toe / camber on the rear?
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
RicMcK is offline
PostPosted: Sun Aug 18, 2024 6:17 am    Post subject: Re: DIY Wheel Alignment Reply with quote
THANK YOU FOR ALL THE ADVICE. Did an alignment yesterday, and it went great except for the vinyl floor tiles did not spin. I used fine grain salt. Next time I will try regular size salt.
My question is about rear wheel camber. One side is at max camber adjustment and I'm still at 0.75°. Prior to the bushing R&R, it was at 0°. What's my solution? Elongate the out side holes some more?
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
RicMcK is offline
PostPosted: Sun Aug 18, 2024 5:08 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
More questions:
#1. When putting in driver and passenger weights on the seats, do I need to put weigh both seats (about 150-180lb in each seat), or can I weight only the seat on the side I'm adjusting?
I'm asking because I really don't want to have to go buy 6+ bags of concrete or sand, that I will have no use for after doing the alignment.
#2. How much gas should I have in the tank?
#3. Should I adjust/match the ride height with the seats weighted?
Thanks.
Rick McK
Seattle
2006 TDI Jetta
1936 Ford Pick up
jlaudin
jlaudin is offline
PostPosted: Fri Dec 13, 2024 3:02 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
My Syncro has a big brake kit on the front end, this adds about 3/4 inch of width. I wanted to eliminate as many points of error in squaring up my strings, so I used welding magnets attached to the rear hub nut and I can eliminate that portion of squaring up the strings.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Dec 15, 2024 12:07 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
I'm not sure I follow how your big brake kit adds 19mm by itself. The rotor hats are usually around 7 to 9mm thick, so is the stock rotor hat. The stock track width shouldn't be impacted by a big brake kit on a Syncro.
jlaudin
jlaudin is offline
PostPosted: Sun Dec 15, 2024 1:37 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
Must be the wheel adaptors then. Has 17" Jeep Wheels.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Dec 15, 2024 5:27 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
Well, definitely then, the big brakes are not guilty Laughing
Steve M.
Steve M. is offline
PostPosted: Wed Dec 25, 2024 7:05 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
Just saw this gadget and APP using a smartphone to check wheel alignment.
I've got my alignment tools so no interest in getting it. Just fyi for modern times!
https://gyraline.com/products/the-case?campaign_id...6628470111
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Dec 25, 2024 10:05 pm    Post subject: Re: DIY Wheel Alignment Reply with quote
Sounds pretty cool, but is a cell phone reliable for that, I always wondered about using them for tilt and level...?
Steve M.
Steve M. is offline
PostPosted: Thu Dec 26, 2024 5:55 am    Post subject: Re: DIY Wheel Alignment Reply with quote
I've had photography APP's that had tilt & level features for setting up cameras and they were very accurate.
Christopher Schimke
PostPosted: Thu Dec 26, 2024 7:06 am    Post subject: Re: DIY Wheel Alignment Reply with quote
I have that tool. I bought it right when it came out because I thought it might be a cool tool for DIY Vanagon owners, but I wanted to try it out first.
I'm not super happy with the results, to be honest. I've tested it several times and it's not all that accurate. However, I will say that it could be accurate to buy a little time before doing a full blown alignment, but I wouldn't rely on it for the long term use.
Page 8 of 8
