How Much Power Can a 1600 Dual Port Make? We’re Finding Out!
Page: 1, 2, 3 ... 13, 14, 15  Next
Fun With VDubs
Fun With VDubs is offline
PostPosted: Wed Dec 18, 2024 2:05 pm    Post subject: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
We’ve teamed up with the air-cooled experts at Seward Speed Shop to find out how much horsepower and torque can be squeezed out of a well worn 1600 dual port. Without splitting the case apart at all!
After each adjustment or part installed we’re running it on the dyno to see exactly how much power we gain, if any. We’re starting with a simple tune-up and carb adjustments. Then we’ll be testing everything from a “power pulley”, different type headers, two different ratio rockers, dual vs. single carb, anything we could possibly do to get more power out of it. There’s even talk about eventually building a “homemade” turbo system for it!
If you have any suggestions or comments on adjustments or parts that might help, please let us know! We’d really enjoy your input.
The pilot episode was filmed three days ago. Spoiler alert: we had some hurdles to jump over but the first dyno results were amazing! This project is going to be tons of fun!
We’ll be posting updates here from time to time, so stay tuned. Our plan is to have the first 30-minute episode ready by the beginning of February 2025.
Swing on over to our YouTube channel. There we post work we're doing on our VWs, and the adventures we take them on.
@FunWithVDubs
View user's profile Send private message Send e-mail YouTube Gallery Classifieds Feedback
vwracerdave
vwracerdave is offline
PostPosted: Wed Dec 18, 2024 2:25 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Include the retail cost of each part added for a financial comparison.
Also do several exhaust systems.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Dec 18, 2024 2:30 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Well, that exhaust is setting the bar low, so things can only get better.
Try ratio rockers.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Fun With VDubs
PostPosted: Wed Dec 18, 2024 2:33 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
For exhaust our plan is to test a completely stock system to see the difference between the slightly odd one that came on the engine. Smile Then we'll test a stinger and probably a couple of others we have at hand.
We're going to need to figure out if we want to do exhaust before or after we put dual carbs on. Probably before so we can get better use out of the intake breathing better.
@FunWithVDubs
Root_Werks
Root_Werks is offline
PostPosted: Wed Dec 18, 2024 2:47 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Always like threads like this. It'll be fun to see your results!
When I set my timing, why do I flush, then take a pee?
veedubcrazy
veedubcrazy is offline
PostPosted: Wed Dec 18, 2024 3:01 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
This will be fun! Very Happy Edit: Subscribed to channel...
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
vamram Premium Member
vamram is offline
PostPosted: Wed Dec 18, 2024 3:31 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Popcorn
Click to view image
Save the Supers!!
oprn
oprn is offline
PostPosted: Wed Dec 18, 2024 4:47 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Back in the late '60's and into the '70's every VW performance magazine did this multiple times. Always heavily sponsored by their advertisers of course...
One does wonder if much has changed since then. A lot less options now to be sure. Be sure to list your sponsors too please!
BFB
BFB is offline
PostPosted: Wed Dec 18, 2024 4:56 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Will OP be posting the results here or is this just a shameless plug for the YouTube videos?
Most experts aren't.
Mr. 010
Glenn is offline
You already know the answer, it's in their signature.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Fun With VDubs
PostPosted: Wed Dec 18, 2024 5:02 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
We'll be discussing the results here as well.
@FunWithVDubs
Fun With VDubs
PostPosted: Wed Dec 18, 2024 5:04 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
We have no sponsors but are open to offers. Very Happy Razz
@FunWithVDubs
Rome
Rome is offline
PostPosted: Wed Dec 18, 2024 5:24 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Will you remove the original heads and rework them with 3-angle valve jobs, maybe bore for 88 mm cylinders that fit into the stock case opening; and flycutting them to raise the compression ratio slightly? And per Glenn, adding 1.4:1 rocker arms?
Or will you install larger-valve new heads and keep the 85.5 mm pistons/cylinders?
I'm looking forward to your progress and updates.
Dauz
Dauz is offline
PostPosted: Wed Dec 18, 2024 5:44 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Add 50 shot nitrous, dry
oprn
oprn is offline
PostPosted: Thu Dec 19, 2024 6:09 am    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Good deal! I always take the "sponsored" results with a grain of salt knowing that the results will be skewed in favor of the said product!
I will be watching on your YouTube channel. You do a good job of them and they make for very pleasant viewing! More please especially your road trip adventures!
halfassleatherworks
PostPosted: Thu Dec 19, 2024 9:59 am    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Make up headers for a Tri Y 1 3, 2 4 vs 4 into 1
oprn
oprn is offline
PostPosted: Thu Dec 19, 2024 10:06 am    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Yes please! If we were closer I would lend you mine in a heart beat to try out!
nsracing
nsracing is offline
PostPosted: Thu Dec 19, 2024 10:20 am    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Oh for petesakes - this horse had been dead and kicked many times already.
We want to see how wet it gets when it rains too? Laughing
mikedjames
mikedjames is offline
PostPosted: Thu Dec 19, 2024 10:58 am    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
Generate enough horsepower to melt pistons in a 1600 DP bus on a hill?
Ancient vehicles and vessels
NJ John
NJ John is offline
PostPosted: Thu Dec 19, 2024 2:54 pm    Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! Reply with quote
14:1 CR and everything else stock!
Can’t wait, actually. I stream a lot of content everyday, and most VW related videos are short. I don’t like to stop what I’m doing to find another video.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Page 1 of 15
