Osku's Vans
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
Osku
Osku is offline
PostPosted: Sun Dec 29, 2024 12:33 pm    Post subject: Re: Osku's Vans Reply with quote
I got the T1 in color here in autumn and it looks like this now. Sinse then I got the engine in, and the electrics are almost complete. I still have to mount the fuel line and then I can try to start it I gues that will be in a few weeks when I next get to the garage.
65-T1 1500 45HP
87-T3 Syncro 1.6TD JX 69HP
88-T3 Syncro 1.9TDi ALH 150HP
89-T3 Syncro 1.6TD JX Oettinger Intercooler 90HP
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Dec 30, 2024 10:11 am    Post subject: Re: Osku's Vans Reply with quote
Did you paint it yourself? The paint job looks excellent.
Osku
Osku is offline
PostPosted: Mon Dec 30, 2024 11:02 am    Post subject: Re: Osku's Vans Reply with quote
Yes I did its not perfect and I will let a profecional do it later again but it is definitively good enough for now but it is not show class so It will be re done in a few years. But I need to get it ready now and I did not find a good enough painter in my budjet now so I painted it my self.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Sun Mar 23, 2025 3:17 am    Post subject: Re: Osku's Vans Reply with quote
This started today and moved under own power 10cm front and back under own power all gears seem to be there and the only issue was that the crank pulley seem to be rubbing the engine thin slightly on the left side on the engine blocks side.
65-T1 1500 45HP
4Gears4Tires
PostPosted: Mon Mar 24, 2025 4:58 am    Post subject: Re: Osku's Vans Reply with quote
Is the crank pulley from another motor?
Osku
Osku is offline
PostPosted: Tue Mar 25, 2025 9:24 am    Post subject: Re: Osku's Vans Reply with quote
Its a brand new orginal oldstock.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Thu Mar 27, 2025 7:59 am    Post subject: Re: Osku's Vans Reply with quote
I suspect I have to open the bots on the thin ware and move it arund a bit and re thighten or then take a bit of the sheetmeta and paint the grinding spot. The sheetmetal is from an other engine so that could be it or itsjust slightly bent or something.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Sat Apr 26, 2025 8:58 am    Post subject: Re: Osku's Vans Reply with quote
I drow this the first time with temporary numberplates for a fewbkilomeeters. It seems to run nice the portals w7ne a bit but I gues thet is to be excpected as the gears are straight cut afte all. The breaks squik a bit Ihope itvwill stop when I get a few Kilomeeter more will be driving it 100 km on monday to the oldtimer sertification so that should sort it if not then I gue I have to open them and see whats wrong everythng is new so it must be a spring rubbing or something. The rear ride hight is a bithigh but will drive it first a bit more as they tend to drop during the first weeksof use.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Tue Apr 29, 2025 8:43 am    Post subject: Re: Osku's Vans Reply with quote
Now the car has MOT and Heritage papers for museum cars.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Sun May 04, 2025 10:38 pm    Post subject: Re: Osku's Vans Reply with quote
The Lahti Classic Motorshow was on the weekend and ther was some 10000 wisitors on saturday and almost as many on sunday. All the car clubs I am involved with were there so I had a lot of frieds with whoom spend the weekend chating away. I had my Oettinger T3 Sync3o there.
65-T1 1500 45HP
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon May 05, 2025 10:55 pm    Post subject: Re: Osku's Vans Reply with quote
Oooh, is it a WBX4 or WBX6??
T3messie
T3messie is offline
PostPosted: Tue May 06, 2025 2:06 am    Post subject: Re: Osku's Vans Reply with quote
From öettinger website:
"Oettinger also made diesel vans fast
After all, a VW bus, after all, primarily serves the purpose of a transporter. And if it also needed to be particularly economical, customers of the time often opted for the 1.6-liter turbodiesel with 70 hp. But that didn't exactly pull the wool over their eyes. The VW Bus Oettinger 1600 TD soon provided a solution. An intercooler, increased maximum boost pressure (from 0.7 bar to 0.8 bar), and a modified injection pump – and 90 hp was achieved."
Osku
Osku is offline
PostPosted: Tue May 06, 2025 10:06 am    Post subject: Re: Osku's Vans Reply with quote
Yes but the boost was Riced from 0.6-0.7 to 0.8-0.9 most where 0.9. The main added benefit was beside the 30% Power increase the fact that the engine had a smaller head temp due to the intercooler and hench the engine was also not that prone for cracking the cylinderhead.
And the orginal power was actually 69hp.
The thing with this van is that it is factory tuned and orginal. From power it does not hold a candel to my everyday Tdi ALH converted syncro with its 150 diesel hp. The Tdi can easy make more power but the gearbox on a syncro can handel only 150hp Diesel or 200 Hp gasoline due to the torque.
But 150hp for a syncro is plenty and the 90 that the oettinger makes is enough to keep up with regular trafic nicely.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Tue May 06, 2025 10:59 am    Post subject: Re: Osku's Vans Reply with quote
Oettinger 1.6TD intercooler engine lookslikethis
65-T1 1500 45HP
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue May 06, 2025 11:27 am    Post subject: Re: Osku's Vans Reply with quote
Oh a JX Oettiger, gotcha!
The charge cooler was made of a Peugeot 505 unit, boxed, I recall.
Osku
Osku is offline
PostPosted: Wed May 07, 2025 10:36 am    Post subject: Re: Osku's Vans Reply with quote
Do you have more info on that Peogeot 505 cooler thing as that is new info to me.
65-T1 1500 45HP
Osku
Osku is offline
PostPosted: Sun May 25, 2025 9:39 pm    Post subject: Re: Osku's Vans Reply with quote
Hast du wieleicht ein bild von ben Peogeot LLK?
65-T1 1500 45HP
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon May 26, 2025 10:53 am    Post subject: Re: Osku's Vans Reply with quote
No sorry I don't. That info was passed on to me as well with nothing to back it up.
20 something years ago I got the LDA cone brochure from Oettinger from that same friend, for the Golf 2. I prefer these injection pumps. Funnily the drawing scan still floating around on the internet was from me Laughing
Page 9 of 9
