Livens Samba Member
Joined: September 10, 2005 Posts: 555 Location: Louisville, KY
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80683 Location: Sneaking up behind you
Posted: Thu Sep 15, 2005 7:02 am Post subject: |
It says your's is a 72 engine (AE 606 761)
1972 112 2000 000 AE-0-558-001 (USA) _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Livens Samba Member
Posted: Thu Sep 15, 2005 8:47 am Post subject: |
Thanks Glenn  |
jgaudiello Samba Member
Posted: Sat Sep 17, 2005 1:34 pm Post subject: Chart |
| I am also trying to figure out the year my engine was made. I have a 72 standard with an engine # of AE 912 149. If I am reading the chart correctly, its a 72 engine as well????? Can anyone verify that for me? Thanks! |
rayzor30 Samba Member
Joined: February 04, 2005 Posts: 177 Location: Western NY
Posted: Sun Sep 18, 2005 9:13 pm Post subject: Serial # doesn't seem to fit the chart |
I hate to seem so stupid but I cannot make heads or tails of this. My engine number does not seem to fit the chart located in the post above. I could use some help with this one. Here is the number from the small plate attached to the flange below the alternator stand. To the left of the number there appears to be a circle with some lines coming out to the left, something like the reverse of a Detriot Red wings symbol. Its been partly removed so I cannot make out what it is but I thought it might help ID the thing. Its followed by the stamped numbers below.
# B 5561 AD 337781
Its in a 79 SB vert #1592036475 but I do not know if its original to the car. I suspect it is not.
Thanks for helping me track down the items in my frankenbug. |
sguarcello Samba Member
Joined: October 04, 2016 Posts: 3 Location: St. Petersburg, Florida
Posted: Fri Jul 04, 2025 10:01 am Post subject: Re: Engine Serial numbers? Whats it mean? |
I know this is an older post and I am wondering if you are still out there? I have the same question about serial number. I too have the little plate rivetted to block and a simlar serial number. Do you have any info to share???
Thanks in advance. _________________ 1979 Convertible Super Beetle completely rebuilt |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1058 Location: Eastern north carolina
Posted: Fri Jul 04, 2025 10:37 am Post subject: Re: Engine Serial numbers? Whats it mean? |
| I believe that to be a rebuilt engine case tag put on by vw at sometime in the past. |
