Side Air Scoops
66bus
66bus is offline
PostPosted: Mon May 13, 2002 6:46 pm    Post subject: Side Air Scoops Reply with quote
I was wanting to know the pro's and con's with the side air scoops
budmanbusfan
budmanbusfan is offline
PostPosted: Tue May 14, 2002 12:03 am    Post subject: Side Air Scoops Reply with quote
A fine mechanic explained once; the scoops are actually limiting the amount of air into the compartment rather than forcing more air as you drive. ie: the opening to the scoop compared to the opening of the side vent. There is also the idea that the VW engineers probably had alot of testing to support their final design. Then again... the '68 up has high mounted scoops built into the body. I guess I didn't help much.
23window
23window is offline
PostPosted: Tue May 14, 2002 12:18 pm    Post subject: Side Air Scoops Reply with quote
I personally don't like their appearance, which to me is a "con". my opinion though.
chiroracer
chiroracer is offline
PostPosted: Mon Jan 06, 2025 11:08 am    Post subject: Re: Side Air Scoops Reply with quote
Just got a bus with them and hacked rear arches and an external oil cooler . I am going to rock them and am open to some 70s style glass flares as well. I would never do this to a bus without them but they stay for now.
66 bajawestfalia
2/1600 buggy Kreger chassis 4 baja 1000(waiting to re emerge)
71 911 track car
65 kombi EZ camper (sold to OG owner in oregon)
69 class 11 racecar Sold to GH racing now the famous Dora SCOREchampion
70 class 11 prerunner
Stocknazi
Stocknazi is offline
PostPosted: Mon Jan 06, 2025 11:31 am    Post subject: Re: Side Air Scoops Reply with quote
Wonder how much $$$ VW spent on the research/development of the engine intake vents back in the 1950's?
Why create a solution to the problem if it doesn't exist?
PS they look like hot garbage. Sick
WANTED:
Thomas Jefferson
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jan 06, 2025 12:28 pm    Post subject: Re: Side Air Scoops Reply with quote
If you use them be sure to place the safety decal in front of the intake.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Clara
Clara is offline
PostPosted: Mon Jan 06, 2025 1:57 pm    Post subject: Re: Side Air Scoops Reply with quote
Good for catching peanut shells you chuck out the window
This bus is now OG paint, and the scoops and flares have been binned, but still haven’t gotten around to fixing the wheel arches and the rust repair. But it’s taken us a lot of miles.
Fwiw, To make your engine run cool, install all the tin and pieces supposed to be there. To make it warm up properly, ditto.
Clara
Clara is offline
PostPosted: Mon Jan 06, 2025 1:59 pm    Post subject: Re: Side Air Scoops Reply with quote
Are you interested in some Cragars?
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Mon Jan 06, 2025 5:46 pm    Post subject: Re: Side Air Scoops Reply with quote
as the bus engines got bigger, they made OG scoops.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
pyrOman
Fire Master
pyrOman is offline
PostPosted: Tue Jan 07, 2025 2:48 pm    Post subject: Re: Side Air Scoops Reply with quote
IMHO, cut wheel wells should be fixed...
or rock on some phat ass tires on the back! Razz
Malokin Martin
Malokin Martin is offline
PostPosted: Tue Jan 07, 2025 9:22 pm    Post subject: Re: Side Air Scoops Reply with quote
I can’t remember who posted a thread on this… it was like a decade ago on here. I want to say it was Clara or Amskeptic. But I can’t remember. They actually did road tests with cardboard “scoops” and without using a CHT. I’m way too lazy to search for it.
I do remember that they significantly lowered engine temps.
The con is they look lame and put holes in the bus in a noticeable area when the next owner wants to rip them off.
velvetgreen
velvetgreen is offline
PostPosted: Wed Jan 08, 2025 7:00 am    Post subject: Re: Side Air Scoops Reply with quote
wanna say that Clara posted something say a decade or so back but that was a long time ago.
Clara
Clara is offline
PostPosted: Wed Jan 08, 2025 10:42 am    Post subject: Re: Side Air Scoops Reply with quote
Yes, it was with actual real plastic scoops, and using a thermocoupler on the head. and various other sensors.
It dropped the temp in the engine compartment to match the outside air temp, and dropped the head temps by the same amount. ( w/o scoops the air temp in engine compartment is warmer than outside)
https://www.thesamba.com/vw/forum/viewtopic.php?p=900179&highlight=#900179
so yes they work, but they are ugly. if your engine is actually overheating, first install all the missing tin.
a few threads on scoops:
https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
velvetgreen
PostPosted: Wed Jan 08, 2025 11:49 am    Post subject: Re: Side Air Scoops Reply with quote
^^^Thanks Clara- wow that was two decades ago- where does the time go?
chiroracer
PostPosted: Wed Jan 08, 2025 3:38 pm    Post subject: Re: Side Air Scoops Reply with quote
LOL no cragars but I would love some vintage flares if they havent picked up the trash yet.
Will def be using some oversize meats on rear and I have a 68 bay beam .
Needs to be able to drive on beach.
66 bajawestfalia
71 911 track car
Samba YardMan
PostPosted: Wed Jan 08, 2025 4:39 pm    Post subject: Re: Side Air Scoops Reply with quote
I liked this post.
https://www.thesamba.com/vw/forum/viewtopic.php?p=150862#150862
If you have the stock engine and all original tin then you shouldn't ever need one.
1600 or larger, you could do a few tricks to keep the engine bay pressurized.
