64-67 rear hatch hinge-replacement
NOS PARTS
NOS PARTS is offline
PostPosted: Fri Nov 07, 2008 5:12 pm    Post subject: 64-67 rear hatch hinge-replacement Reply with quote
picked up this 13 deluxe and in need of a rear hatch hinge replacement
wondering if anybody has any details instructions to remove,replace
thanks
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
mintonman
mintonman is offline
PostPosted: Fri Nov 07, 2008 5:29 pm    Post subject: Reply with quote
Check these threads out, you may want to PM one of the people that posted in it for more info.
http://www.thesamba.com/vw/forum/viewtopic.php?t=232214&highlight=rear+hatch+spring
http://www.thesamba.com/vw/forum/viewtopic.php?t=240449&highlight=rear+hatch+spring
Hoockd on fonicks werkt for mee?
under the influance "DUH"
bushaus
bushaus is offline
PostPosted: Fri Nov 07, 2008 5:55 pm    Post subject: Reply with quote
This was one of my first repairs, can be kinda dangerous. Also check this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=296278
for more info.
HELPFUL HINTS- 1)post a classified ad, you should be able to find the parts from someone on here (remember to specify which side), 2)take pics of the hinge and pin location before disassembly, 3)wear gloves and be wary of high tension!
1967 13 window walkthru bus
1965 Karmann Kabriolett beetle
hitest wrote:
Even if completed, the abarth's gonna belch spluey all over your Eriba.
NOS PARTS
PostPosted: Fri Nov 07, 2008 6:29 pm    Post subject: Reply with quote
thanks for the info
I was able to find these VW service manual instructions;
http://home.clara.net/hallvw/technical/tailgate.htm
here the needed tool (VW tool 709);
https://erwin.volkswagen.de/workshop/englisch/index.htm?/workshop/englisch/docs_spezial/h631.htm
here the tool;
I already have a donor bus with the parts I need
will make a tool and make time to get it done next week
will remove the parts from donor bus 1st...
thanks
dstefun
dstefun is offline
PostPosted: Fri Nov 07, 2008 6:49 pm    Post subject: Reply with quote
The 709 tool is in the Local Manufacture manual
http://oacdp.freeweb7.com/tools/vw709-3.png
bushaus
bushaus is offline
PostPosted: Fri Nov 07, 2008 7:00 pm    Post subject: Reply with quote
NOS PARTS wrote:
thanks for the info
wish I would have found those easy instructions before I did mine! Wink
NOS PARTS
PostPosted: Sat Nov 08, 2008 11:00 am    Post subject: Reply with quote
bushaus wrote:
NOS PARTS wrote:
thanks for the info
well with the easy instructions and the tool drawings, its easier than the previous info I got before.... "get a BIG screw driver, wear gloves, be careful..."
islandveedub Premium Member
islandveedub is offline
PostPosted: Sun Jan 17, 2010 7:49 pm    Post subject: Reply with quote
Glad I ran across this thread. I did this once before without the instructions and even though we were successful, it was the scariest thing I've ever done. I saw the tool, so I figured out how to make one of my own out of a factory jack handle.
The tool worked like a champ. However, that's still a lot of freakin' tension. With the tool and instructions, this job is now the second scariest thing I've ever done. Very Happy
Alex
60 Doublecab
62 23 Window Walkthrough Bus
View user's profile Send private message Visit poster's website Facebook Twitter Instagram Gallery Classifieds Feedback
tubdub
tubdub is offline
PostPosted: Sun Jul 11, 2010 1:38 pm    Post subject: Reply with quote
picked up the homemade tool from islandveedub and it took about 1/2 hour to pull the assembly from a parts bus roof and install it on my bus. if anyone in the sacramento area needs to use it let me know.
tubdub
tubdub is offline
PostPosted: Sat Nov 20, 2010 7:18 pm    Post subject: Reply with quote
bumping this so chris roop will find the instructions Cool
chris roop
chris roop is offline
PostPosted: Sat Nov 20, 2010 7:38 pm    Post subject: Reply with quote
Most excellent! After 25 years of commercial fishing I still have all my fingers and would like to keep it that way.
SocalRico
SocalRico is offline
PostPosted: Tue Dec 12, 2017 3:24 pm    Post subject: Re: 64-67 rear hatch hinge-replacement Reply with quote
Here is a video how to install the hinge. I know it's in Spanish but it's pretty straight forward. One thing to note, the guy in the video says never try to do this alone, you need 2 people.
[/youtube]
View user's profile Send private message Send e-mail Facebook Classifieds Feedback
sgellis
sgellis is offline
PostPosted: Mon Apr 02, 2018 9:34 am    Post subject: Re: 64-67 rear hatch hinge-replacement Reply with quote
Just installed my hatch hinges and thought I would add a little here as the instructions I found were not that clear. I was dreading the job but it turned out to be quite easy once I figured out how the rods went in.
First I installed the hinges and used some tape to keep them out of the way. Don't forget the clips. Easier to put them in now without the arms in the way.
The rods are different. The end that hooks into the roof support is leaned over a bit. This is the rod for the right side hinge.
The rod can be hooked into the support slot and then the end allined with the hole. Move it around and wiggle it and it should slide in.
On the other end of the rod slide on the arm.
I built a simple tool to wind the bar. I didn't need as much hook on the end. You will definitely need something like this to install the rod safely.
Hook the tool in the rod. Keep some space between the tool and the arm. You will likely need the try it a few time to get the arm lined up with the support.
While standing at rear hold the rod about 6" from the arm with one hand and push down and forward on the tool to rotate the rod. You can guide the rod up into the forward slot in the support. Notice support is between the arm and the tool.
Once in place wind the rod a bit more to insert the arm pin. Insure the pin is all the way in before removing the tool.
Pull down on the hinge to release the tool. Install the clip on the pin so it doesn't work out
After the second rod can be hooked into the support by pulling down on the left hinge a little. You could hook both rods in at the start but I thought it might be easier if it wasn't in the way.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
Danny79
Danny79 is offline
PostPosted: Sun Feb 09, 2025 7:19 pm    Post subject: Re: 64-67 rear hatch hinge-replacement Reply with quote
Ha, now I find this post. Well, it was not here 11 years ago when I bought my bus in Watertown NY and towed it home in a snow storm, back to Pittsburgh.
I got a replacement hinge off a donor bus, and I procrastinated 10 years until today !.. Fixed.
I installed half the hinge first, using a pipe over the one end of the hinge.
Get the hinge on the torsion rod so when you bend it down, it will go inside the fixed hinge part of the roof. That is one very important detail so it fits. Once I aligned it, the pipe brought it down and I could install the rod in that little cut out attached to the roof.
Then I used the big sears screwdriver to bend down the end of the C shape of the rod which dropped the first half of the hinge out of the way, and I got the second half of the hinge in place and put those pins in the proper place and fully seated. The are elongated oval, and have to sit in the hinge it's self.
Had to tell someone ! Then after I did that, I realized the one hinge not bent is a different design than the one I just installed ! ...they were not symmetrical in pointing to the sky. I'll fix that in the daylight...yea, sun had set.
