Terrawagen Terrapods 2.0 VS Projektzwo lights
16CVs
16CVs is offline
PostPosted: Tue Mar 11, 2025 5:49 pm    Post subject: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
I use my van not as much as I'd like but when I do it's lots of miles and often off road overgrown trails.
I have a set of vintage ProjektZwo drivng lights that are expensive and hard to get parts for. I like the look of them and they are very functional in dark areas. I am always worried about them getting cracked or road worn.
In steps Terrawagen with his new 2.0 version of fog light replacements. They look as good if not better with nice Hella logo and perfect no wavy fit against the body of the housing.
The install was very basic. It comes with printed instructions (Thank you) as well as a link to his install video. As I had lights previous I did not have to do any wiring except add connectors to match my existing wires. I have mine wired as Fog lights and switchable by a factory Fog light switch. The kit comes with wiring, connectors and a relay for any number of ways to wire it.
They look dashing and I can safely put my PZ lights on the shelf for future use or when period correct really matters.
The very best part is that it comes with 2 different treats for when you're done. No not really, one is a Desiccant and you should not eat it.
I will try them at night in a few days. Van is in for some other items, one project at a time.
Samba member # 14980
kevinm
kevinm is offline
PostPosted: Tue Mar 11, 2025 7:41 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projekt zwo lights Reply with quote
The Terrawagen light look good. Thanks for the write-up.
Q: does the install require drilling of holes into the body?
- Kevin
90 Syncro Westy, "Ludwig"
16CVs
16CVs is offline
PostPosted: Tue Mar 11, 2025 9:24 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
No holes in the body, you do have to drill holes in the lower grill. This is one of the advantages over the PZ that over lap the grill either way overly thin plastic.
It does come with all necessary fasteners and is ready to go out of the box.
Stacy
Daehtihs
Daehtihs is offline
PostPosted: Thu Mar 13, 2025 7:48 am    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
I also finished installing mine last night. The fit is very good. Once installed, the beams need to be aligned to each other. Not much in the way of adjustability, going to try to align them again tonight.
One thing I made was a switchback relay. When you use the turn signal switch, say you're making a right turn, the right fog light will go off until the turn signal light goes off. Makes oncoming traffic able to see your turn signal light
pnwkayaker
pnwkayaker is offline
PostPosted: Fri Mar 14, 2025 6:22 am    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Are these true fog lights? I remember the original Terrapods were using some LED lights that people complained were only useful as DRL.
Also, can the lights be replaced/removed from the assembly in case one breaks?
I have the MMT3 fog lights installed, but they’re falling apart (plastic is very brittle), this set looks like an interesting alternative.
87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link)
Daehtihs
Daehtihs is offline
PostPosted: Fri Mar 14, 2025 7:30 am    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
They are true fog lights. And they are replaceable. The difficulty with them is trying to adjust their aim. There is a screw on each end of the lens that holds it to the plastic housing. Not a lot of room for adjustment. And the backside of the H3 bulb is very low profile. If you wanted to use an LED bulb, the ones with a larger base with a fan in it will not work. No room for it in the housing.
16CVs
16CVs is offline
PostPosted: Sun Mar 16, 2025 10:50 am    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Since installing my 2.0s I've finally decided to have my new Aluminum radiator installed.
I've found when removing the lower, grill it is best to remove the grill and the lights as one unit.
Those provided push pins are tight and i think it is less effort to remove it as a unit.
YMMV
Stacy
otiswesty
otiswesty is offline
PostPosted: Sun Mar 16, 2025 10:21 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
That looks great Stacey. Thanks for posting the information.
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
GreggK
GreggK is offline
PostPosted: Mon Mar 17, 2025 4:45 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Anyone have a picture of them installed on a van with round headlights?
'86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
16CVs
16CVs is offline
PostPosted: Mon Mar 17, 2025 5:17 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Get one of your kids to photo shop it for you!
pnwkayaker
PostPosted: Mon Mar 17, 2025 7:28 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Not the same lights, but to give you an idea how they could look, this is pic of my van with the MMT3 lights installed and the Smallcar "South Tacoma" grill.
Some people might be offended by having round lights and the ProjectkZwo kind-of lights, I don't have any issue.
GreggK
GreggK is offline
PostPosted: Mon Mar 17, 2025 7:29 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Looks GREAT! Thanks man!
syncrodoka
syncrodoka is offline
PostPosted: Tue Oct 07, 2025 5:47 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
How did you run the wiring to the light pods? Did you notch the lower grill to fish the wires between it and the body or something else?
I have a couple of deutsch connectors ready to go, just looking for a good path forward.
jyl
jyl is offline
PostPosted: Tue Oct 07, 2025 7:15 pm    Post subject: Re: Terrawagen Terrapods 2.0 VS Projektzwo lights Reply with quote
Those are very nice looking. I want more light and found some Hella pie-plate driving lights in the shop . . . I don’t know that I want that much light, considering the typical modest speed of the van, being able to throw light down a football field seems pointless. A nice tidy driving light would be nice.
1988 Westy, Bostig v2.0
Portland, OR
