What Radio are you using that DOESNt require cutting dash
Page: Previous  1, 2
raygreenwood
raygreenwood is offline
PostPosted: Sat Mar 08, 2025 10:21 am    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Here is a used Blaupunkt CR-2001 ....late 70s through 1982. Am/Fm/cassette with volume and tuner knob. Very basic but good units. I think these were actually produced in Japan.
https://www.ebay.com/itm/124802154325
But dang...used...untested....as-is....$200
Ray
Type2_Personality
Type2_Personality is offline
PostPosted: Sat Mar 08, 2025 11:44 am    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
I installed this Alpine with removable face plate about 25 years ago after another break in and car stereo theft. This installed with no dash cutting. Looks like there are some similar, smaller type units available at Walmart and other retailers, but I don't know if they are a direct fit. Hope this helps.
1971 Type II ~ Adventure Camper
2nd Owner For Over 40 Years
Back To Stock ~ 1600 Dual Port ~ Single Carb
400,000+ West Coast USA Miles
Too Many Dead Shows To Remember
raygreenwood
PostPosted: Sat Mar 08, 2025 12:18 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Here is another really cool updated release.
Blaupunkt Franfurt RCM82 from Classiccarstereos.com
https://www.classiccarstereos.com/blaupunkt-frankf...GiEALw_wcB
All modern guts, late 1980's copy of the Blaupunkt Frankfurt AM/FM/ cassette deck with phone mic and bluetooth.
Thats a good looking deck! Very classic late 80's, Notice what is under where teh cassette would have been. But dang...$623
Ray
ALLWAGONS
ALLWAGONS is offline
PostPosted: Sat Mar 08, 2025 12:24 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Awesome!
That's what I am talking about.
Thanks Again Guys!
Martin
allwagons
ALLWAGONS
PostPosted: Sat Mar 08, 2025 6:31 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
My dash is flat and not padded. The radio opening measures 7” across and 1 3/4” top to bottom. I currently have a radio delete plate that fits like a glove, making me believe, that opening has not been altered with.
metahacker
metahacker is offline
PostPosted: Sun Mar 09, 2025 1:24 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
i also faced a similar dilemma...and decided to make my own....
at first, i started somewhat out of necessity.... when the original blaupunkt died....i took it out and used the faceplate to hack up a quick solution with a circuit board i was playing with.
then i thought it would be fun to model a real solution like it.
it uses a class D amplifier chip so 98+% power efficient unlike the class A MOSFET that most use (typical for those is 25% efficiency up to 50% theoretical...which is why almost all car audio amps are mostly giant heat sinks)....
class D is perfect for playing music in a camper for hours and hours without wasting your battery.
it has a dedicated subwoofer amp in addition to the stereo amp..... so i get a full "aftermarket stereo" style setup equivalent to installing a bluetooth head unit and 2 dedicated amplifiers..... but it's just a tiny board on the back of the panel i made.
i'm working on a new version with a much higher power board
theoretical power on the new one is >200W stereo + >300W sub-woofer...
uses a Class D amp chip design from a U.S. company....
going to use multi-filament printing tech (e.g. colored labels)....
^ just playing around (probably will stick to black).
have been experimenting with some cool new knobs that should make it look nice (both some printed multi color ones and some others like Moog replicas)....should go well with the colored inset labels...
planning make a Vanagon version too.. since i built a T3 recently, it's going to need a cool stereo, too..
i thought about making more for other people, not sure whether anyone would want to buy something like this, though.
personally, i think it's really cool, though....the minimally invasive installation combined with ultra-power-efficiency and the equivalent performance of a head unit + 2 separate amps in such a tiny space really makes me happy.
raygreenwood
PostPosted: Sun Mar 09, 2025 3:54 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Very nice!
I know the pain. While its not hard to find good automotive amps with class D amplifiers....it can be $$$ and space and form factor becomes an issue.
Its why I am always shopping and comparing on the move toward what eventually goes into my system in my 412. I have a great head unit already, a whole range of excellent speakers I can mix and match with, finally settled on a DAC unit and slowly settling on my amp(s). Ray
71whitewesty
71whitewesty is offline
PostPosted: Sun Mar 09, 2025 4:04 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
JBL bluetooth speaker. Throw it on the dash and you're done. Seriously, that's the best option. Doesn't use your battery, sounds great, awesome for campsites and even other vehicles. Cool
71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer"
raygreenwood
PostPosted: Sun Mar 09, 2025 5:43 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Sure nothing wrong with that at all....if all you want is basic sounds and connection to your media. It would not really work for me. But, If you want better sound quality and other functions....there are other ways.
It really comes down to what you want and need in your audio system. I think there are numerous philosophy. None are better than any other.
Other than just fitting in the dash or just being "some" level of music or audio (and I realize the bus has some special issues with ambient noise, interior volume and speaker placement options).....it is unbelievable what is available function and quality wise if one were to shop around for it and is willing to do a little work.
Ray
ALLWAGONS
PostPosted: Tue Mar 11, 2025 2:20 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Has anyone tried the Memphis Audio headless unit. It is app based, am/fm/bluetooth. AUX for front and rear amp. $299 and come with one simple 5 button remote.
raygreenwood
PostPosted: Wed Mar 12, 2025 9:43 am    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
That looks liek a pretty good method. I looked around for a little while and can find a lot of people who sell the unit but mayber a total of 8 reviews...cumulative average of about 3.5 to 4.0.
Found one install video from some hot rod guy on YouTube. He has an earlier version without the rotary knob on the five button control.
A couple of items, the USB is a charger line only. It does have a headphone jack type plug in but not sure if its a line in. The USB line is a charger only so it looks like its entirely Bluetooth. The in-app volume only goes in notches/steps and is not infinite adjustment (some complain too loud some complain not loud enough).
Looks fairly complete for the basics though. I wnted to see more of what adjustments are in the app but the buy just showed what tabs there are and not what is under the tabs for adjustments.
The price is decent if it does what it says. Ray
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Mar 13, 2025 8:48 am    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
On my 1975 single cab, built to European spec, the radio model was specified on the M-code plate, as Blaupunkt Ingolstadt. I managed to find one for sale from Germany, and it fits just fine, even on the non-padded dash.
Funny story: When I got the radio, I first tested it on the bench, with 12 V input and a speaker. I kid you not that the first thing to come out of this German radio was Wagner's Ride of the Valkyries! That was a special moment.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
tonysantacruz
tonysantacruz is offline
PostPosted: Thu Mar 13, 2025 9:18 am    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
I got this cheapo option in Amazon last year, replaced the stock radio, which got ungodly amounts of interference.
https://www.amazon.com.mx/EBTOOLS-Bluetooth-Est%C3...b&th=1
No need to cut the dash, fits perfectly within and the guy installed it in less than 30 minutes.
ALLWAGONS
PostPosted: Thu Mar 13, 2025 12:20 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Thanks for the suggestion. But that unit is 7" by 2". Your installer or the previous owner probably enlarged the opening. Yes, I have seen those too! Maybe just maybe I will have to do the same.
Martin
allwagons
Shonandb Premium Member
Shonandb is offline
PostPosted: Thu Mar 13, 2025 1:28 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
I found that a 20 year old single DIN Sony with a removable front plate slid right in and sounds decent. I have 2 speakers in the front kick panels and a Retrosound dual tone in the original speaker space under the dash as well as 2 speakers in the rear cabinet under the bed.
Something mello
or something a little more lively...
Previous 1973 Panel Bus:
Click to view image
metahacker
PostPosted: Thu Mar 13, 2025 8:27 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
SO awesome!
NASkeet
NASkeet is offline
PostPosted: Sat Mar 22, 2025 2:35 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
Another option is to create a bespoke bracket to mount an audio unit beneath the dashboard, which is easier to reach without leaning forward or stretching; especially if wearing a static lap & diagonal seat belt. One can then use the centre aperture for three 52 mm accessory gauges.
I personally favour a Blaupunkt Toronto SQR46 or SQR48, which when new in the early-to-mid-1980s cost about £300.
They feature an audio-cassette player with auto-reverse, plus long, medium &SHORT wave band plus FM-VHF radio; all with output to four speakers, with balance controls front to rear & side to side.
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
ALLWAGONS
PostPosted: Sun Mar 23, 2025 12:28 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
So after much Teslaing, I went a different route. I had a everything I had removed from my type 34 30 yrs ago, and had stashed it away. I installed a 4 way 100W amp and a 10" JBL sub under the rear seat, ran the wires through the grooves into the spare tire well under the seat to a pre amp with 2 aux inputs and a front jack input and onto some Pioneer 100w shelf speakers that fit into the parcel trays under the dash. Since I don't have a head unit, I power it on with an on/off small push button that fit in a hole on the dash under the radio plate cover that the PO had made.
Now I have clear sharp high treble, low vocals that sound clear and nice deep low bass. The shelf speakers aim up, so I can clearly hear all music. Anything from Dire Straits "Sultans of Swing" to Patrick Hernandez's " Born to be alive" No drilling except to affix a board for the amp and the fuse boxes. I installed a Bluetooth receiver with AUX outputs, but it had a lot of static. I was very disappointed that Bluetooth music cannot be adjusted with an eq. I went around that with the Apple lightning plug to 3.5 mm jack plug adapter.
I was surprised that my old 64G Ipod had better sound and more volume than my Iphone 14, both streaming and in phone music. My dash still looks nice and plane and I have great sound. Total add on cost $20 Just FYI.
Thank You all for all your input.
Martin
allwagons
raygreenwood
PostPosted: Thu May 22, 2025 6:13 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
A cool modern/retro stereo.
https://www.thedrive.com/news/the-cassette-deck-on...tvEDNuXFjA
Ray
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 22, 2025 9:11 pm    Post subject: Re: What Radio are you using that DOESNt require cutting dash Reply with quote
adjustable shaft Pioneer super tuner with other things plugged in thru the aux.
Page: Previous  1, 2
Page 2 of 2
