Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23611 Location: Kimball, Mi
Posted: Mon Mar 17, 2025 2:45 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
Looks good. Keep getting after it a little at a time. Progress is progress.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
No_name4aday Samba Member
Joined: May 23, 2024 Posts: 56 Location: Northwest Kansas
Posted: Wed Apr 02, 2025 1:17 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
| My garage door was up and didn't want to go down. Both rollers unwound, took everything apart to get the door down tried to reset the tension rolled it up and lost it again. Has me lost ordered a fender stand and got all my flower gardens ready for summer. Back to sanding soon |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4091 Location: San Jose, CA
Posted: Wed Apr 02, 2025 4:44 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
I would suggest hanging your dash by the clock hole, vertically. That way you don't deform the speedo pod. I have a pipe and fitting from Home Depot with pool noodle around it and have a couple dashes hanging on it. It's the only way I've found to store them that avoids damaging or deforming them. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Thu Apr 03, 2025 5:41 am Post subject: Re: My 71 squareback...fixing up a classic vw |
| I actually have the speedometer in it tried to prop it up flat with the glove box. I didn't want it flexed or warped, that spray on dye did better on old bits, the area around the speedometer needs touch up after I put it in, it already sat 9 months was quite snug. That is a soild tip thanks been keeping new bits inside the house for climate control gets pretty cold or hot in the shop |
Posted: Mon Apr 14, 2025 6:15 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
| Hand Sanding the curves and tight spots definitely not my favorite part so it's slow ha hahaha |
Posted: Tue Apr 15, 2025 11:10 am Post subject: Re: My 71 squareback...fixing up a classic vw |
| No_name4aday wrote: |
Wait until you get to the louvers on the rear fenders, or the front fresh air vents. Those are a real PIA to do. Ask my wife, she hated doing them.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Tue Apr 15, 2025 7:30 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
I'm not married  |
Posted: Wed Apr 16, 2025 12:40 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
I'm not married  |
So much for "cheap labor". My wife does it so we can spend some time together. For the dash vents (cowl section) wrap some sand paper around a paint stick. That works for me. Then you can roll the used sand paper for the curved corners (kind of the easy part of doing them). The rear fender vents are just a PIA to do, so I use my 90*angle grinder with some of those 3M roloc discs on them to strip the paint off (not true sanding pads, but rather stripping discs). They also work on the cowl vent, but then you have to blend the bare metal out, which can almost result in stripping the entire section. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Fri Apr 18, 2025 4:33 am Post subject: Re: My 71 squareback...fixing up a classic vw |
I'm plugging away at it try to get at least a couple hours a day. I got a big yard and all the spring setup has been the priority. That is almost done after the first weekend in May ill be free to hit it hard. Never sanded a car before but by the end part of a front I learned what it will be. I have some round foam tube, it's like the core they cut out of bike pads, in various sizes was thinking it may work on the vents. Paint stick sounds easier. So far it was 1x paint so I'm not sanding 10x layers. I just wanna do a wheelie still sanding |
Posted: Mon May 12, 2025 6:27 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
I sprayed the front fender with rust encapsulater plus from east wood then filled the holes with metal epoxy and sanded that. I will spray the whole fenders with that. Not much filler required. The inside has a globby coating that will need chipped away in some places most looks solid. The fenders are in good shape for what it is overall. Got one ready about to coat on the outside. Figured out what blocks to use in the corners ect. So should be ready to flow on progrees again. I am not sure wtf I'm doing but this seems like a logical way to go and this be what it will be eventually primer and paint. |
Posted: Thu May 29, 2025 6:57 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
| Still sanding fenders this may take awhile not fond of this part haha woosh woosh woosh |
Posted: Fri May 30, 2025 12:34 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
More than likely the inside portion of the front fenders is coated in "rock guard" to keep stone chips from breaking thru the paint causing rust. A heat gun and a scraper will remove that stuff easier than trying to sand it. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Sun Oct 05, 2025 1:38 pm Post subject: Re: My 71 squareback...fixing up a classic vw |
| Been awhile since I work on it. It's about the season for getting busy. |
