snaponbob Samba Member
Joined: October 19, 2010 Posts: 8 Location: Kansas City
Posted: Tue Oct 19, 2010 9:04 am Post subject: Rebuilding the front suspension |
| I have a friend with a Type 3 squareback. The front end is loose, with a lot of movement of the suspension arms. (Sorry, don't know all the lingo of these components yet.) What does it take to freshen up the front end, and are all the parts available (needle bearings, seals, other wear items)? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18054 Location: Eugene, OR
Posted: Tue Oct 19, 2010 9:24 am Post subject: |
You probably just need to adjust the upper torsion arm axial play. It's ALL Covered in the VOLKSWAGEN SERVICE MANUAL Type 3 1968 through 1973 Bentley Manual. _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Tue Oct 19, 2010 11:58 am Post subject: |
| Mike Fisher wrote: |
| You probably just need to adjust the upper torsion arm axial play. It's ALL Covered in the VOLKSWAGEN SERVICE MANUAL Type 3 1968 through 1973 Bentley Manual. |
And, if you don't want to buy the book just to loosen one set screw and tighten one bolt... go to the right front of the front beam assembly. Scrape off all the gunk and crap from the upper torsion arm. Loosen the setscrew- locknut on the top, and snug the 13mm bolt head staring at you straight on until there's no slack, about 18- 20 foot pounds. Tighten set screw. Lube 4 zerk fittings on front end until fresh grease comes out between the beam and trailing arms. Road test. Oh, there's a lockplate on the 13mm you'll need to bend.
You may need tie rods and ball joints but these are straightforward bolt- in operations. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
S.coppertop Samba Member
Posted: Fri May 02, 2025 7:07 pm Post subject: Re: Rebuilding the front suspension |
| I know this is years late so I hope you see this... My adjusting bolt is missing, do you know the thread by any chance I cant find it anywhere |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23594 Location: Kimball, Mi
Posted: Sat May 03, 2025 11:45 am Post subject: Re: Rebuilding the front suspension |
| S.coppertop wrote: |
According to the parts book, it's an M8x1.25 by 20mm long. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
