Wrdiver Samba Member
Joined: November 26, 2024 Posts: 2 Location: Oregon (Willamette Valley)
Posted: Wed May 07, 2025 1:00 pm Post subject: Rear Brake drum hitting shoe retaining spring |
First off… 1963 Ghia. Car new to me, sat for 25 years, brakes were seized. I redid the brakes with new hardware and had drums turned as they are original and just needed cleaned up. It’s new shoes, springs, cylinders. OE drums that I has turned by a reputable machine shop.
Now after putting it all back together and torquing the castle nut to 253lb (then slightly backed off so cotter pin could go in) , the drum is hitting the retaining spring when I spin the drum. I noticed the new hardware pins are slightly longer than OE originals so I reused the old ones (pins and springs) and they still hit the spring. It’s hitting where the wheel stud hole bulges out inside the drum. Also hit original “oil slingers”. Once again OE drums (decent shape)….
I have taken the brakes apart like 5 times and get the same result…. I also tried with the shoes fully adjusted in and also set properly (slightly rubbing drum)….. I need advice…. |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 716 Location: germany
Posted: Wed May 07, 2025 9:47 pm Post subject: Re: Rear Brake drum hitting shoe retaining spring |
Make sure, you have original short pins for 30 mm rear brake shoes and original springs.
Some aftermaket pins and springs are junk. (assuming, your old pins already can be aftermarket) |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6201 Location: 37.5N 77.1W
Posted: Thu May 08, 2025 8:11 am Post subject: Re: Rear Brake drum hitting shoe retaining spring |
Quote: |
drum is hitting the retaining spring |
I've had this happen before. What I did was use #8 washer, or was it #6 washer, whatever fits around the pin but smaller than the pin head. Put the washer on the pin before putting the pin through the backing plate. I fixed mine with one washer on each side but it may take stacking two washers to pull the locking cap back enough not to hit. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Fri May 09, 2025 3:13 pm Post subject: Re: Rear Brake drum hitting shoe retaining spring |
Thanks for the suggestion. A little washer on the pin head seems to do the trick! |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3847 Location: Eastern WA
Posted: Fri May 09, 2025 6:42 pm Post subject: Re: Rear Brake drum hitting shoe retaining spring |
After you have rubbing issue resolved, torque the drums properly. Once you hit torque if the holes for cotter pins don't line up,keep tightening to the next hole, if you back them off to line up like you did, they are no longer torqued. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
